[SOLVED] Could not repair PC with SFC.Exe so i am asking for lots of help.
1vincent
Active member
Hello.
2 weeks ago on starting my pc it ran chkdsk and i got a load of errors about bad/corrupt files and it could not fix them.
I ran sfc /scannow and it should errors but also not fixed.
In eventviewer i was getting volumeshadow errors so i ran seagate tools on my hard drive and that was ok but still getting errors and then the pc would hang from a few secs to 5/6 mins before being ok.
I done a restore back a few days but it was still the same so i deleted progs/files that i did not need and done anti virus, malwarebytes and super-spyware and they all came back ok.
I bought a new drive (160gb sata) and cloned to that hd and put in my pc and that also is doing the same.
I remember doing windows update and i think my issues started 3/4 days after that.
I have window 7 ultimate.
I have done sfx.exe a few days ago and it could not fix all the files so i ran it today and joined this forum and i have the file attatched so somebody can give me so advice about it.
Thank you.
Looks like a fair number of corrupt files.
Let's see what SURT says.
System Update Readiness Tool (SURT)
Download and run the System Update Readiness Tool for your version of Windows here: System Update Readiness Tool
NOTE: If you aren't sure if your Windows installation is 32-bit or 64-bit, check here: How to determine whether a computer is running a 32-bit version or 64-bit version of the Windows operating system
This tool will take some time to complete - when it has finished, attach C:\Windows\Logs\CBS\CheckSUR.log with your reply.
Windows Update Package Replacement
  1. Please download the attached file, Packs.zip and save this to your Desktop.
  2. Right-click on the file and select Extract All...
  3. Tick the box labelled Show extracted files when complete then click Extract
  4. A window will open showing two folders, Manifests and Packages
  5. Open the Manifests folder and copy the files into the following folder (if there are any files)
    C:\Windows\Temp\CheckSur\Winsxs\Manifests
  6. Open the Packages folder and copy the files into the following folder (if there are any files)
    C:\Windows\Temp\CheckSur\Servicing\Packages
  7. Run the System Update Readiness Tool (SURT) again.
  8. When the SURT finishes installing, copy (Ctrl + C) and paste (Ctrl + V) the contents of the SURT log into your next post please:
View attachment Packs.zip
I'll also need to trace some of the other components:
View attachment SFCFix.zip
Thank you for helping me.
Binary Version 6.1.7601.22471
Package Version 26.0
2016-11-15 20:00
(f) CBS Catalog Corrupt 0x800B0100 servicing\Packages\Package_2_for_KB3045685~31bf3856ad364e35~x86~~6.1.1.0.cat
(fix) CBS Catalog Corrupt CBS File Replaced Package_2_for_KB3045685~31bf3856ad364e35~x86~~6.1.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab.
(fix) CBS Paired File CBS File also Replaced Package_2_for_KB3045685~31bf3856ad364e35~x86~~6.1.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab.
(f) CBS Catalog Corrupt 0x800B0100 servicing\Packages\Package_43_for_KB3004375~31bf3856ad364e35~x86~~6.1.3.1.cat
(fix) CBS Catalog Corrupt CBS File Replaced Package_43_for_KB3004375~31bf3856ad364e35~x86~~6.1.3.1.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab.
(fix) CBS Paired File CBS File also Replaced Package_43_for_KB3004375~31bf3856ad364e35~x86~~6.1.3.1.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab.
(f) CBS MUM Corrupt 0x800F0900 servicing\Packages\Package_65_for_KB3185330~31bf3856ad364e35~x86~~6.1.1.2.mum Line 1: B:: AddCatalog: Package_3_for_KB3156016~31bf3856ad364e35~x86~~6
(fix) CBS MUM Corrupt CBS File Replaced Package_65_for_KB3185330~31bf3856ad364e35~x86~~6.1.1.2.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab.
(fix) CBS Paired File CBS File also Replaced Package_65_for_KB3185330~31bf3856ad364e35~x86~~6.1.1.2.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab.
(f) CBS Catalog Corrupt 0x800B0100 servicing\Packages\Package_for_KB2984972~31bf3856ad364e35~x86~~6.1.1.4.cat
(fix) CBS Catalog Corrupt CBS File Replaced Package_for_KB2984972~31bf3856ad364e35~x86~~6.1.1.4.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab.
(fix) CBS Paired File CBS File also Replaced Package_for_KB2984972~31bf3856ad364e35~x86~~6.1.1.4.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab.
(f) CBS Catalog Corrupt 0x800B0100 servicing\Packages\Package_for_KB3086255~31bf3856ad364e35~x86~~6.1.1.0.cat
(fix) CBS Catalog Corrupt CBS File Replaced Package_for_KB3086255~31bf3856ad364e35~x86~~6.1.1.0.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab.
(fix) CBS Paired File CBS File also Replaced Package_for_KB3086255~31bf3856ad364e35~x86~~6.1.1.0.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab.
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
(f) CSI Manifest Failed Catalog Check 0x00000000 winsxs\Manifests\x86_e742464b73d34782a6d2831f7fce890e_31bf3856ad364e35_7.6.7601.19161_none_595987e1935c5d14.manifest x86_e742464b73d34782a6d2831f7fce890e_31bf3856ad364e35_7.6.7601.19161_none_595987e1935c5d14
(fix) CSI Manifest Failed Catalog Check CSI File Replaced File: x86_e742464b73d34782a6d2831f7fce890e_31bf3856ad364e35_7.6.7601.19161_none_595987e1935c5d14.manifest From: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab
(f) CSI Manifest Failed Catalog Check 0x00000000 winsxs\Manifests\x86_netfx-mscoree_dll_31bf3856ad364e35_6.2.7600.16513_none_7daed23956119a9f.manifest x86_netfx-mscoree_dll_31bf3856ad364e35_6.2.7600.16513_none_7daed23956119a9f
(f) CSI Manifest Failed Catalog Check 0x00000000 winsxs\Manifests\x86_microsoft-windows-a..atibility-assistant_31bf3856ad364e35_6.1.7601.18741_none_35aa6c61818436f2.manifest x86_microsoft-windows-a..atibility-assistant_31bf3856ad364e35_6.1.7601.18741_none_35aa6c61818436f2
(f) CSI Manifest Zero Length 0x00000000 winsxs\Manifests\x86_22b657062893a091f8671c303a6a1007_31bf3856ad364e35_7.6.7601.19161_none_a678bd0d5b94c4d4.manifest x86_22b657062893a091f8671c303a6a1007_31bf3856ad364e35_7.6.7601.19161_none_a678bd0d5b94c4d4
(fix) CSI Manifest Zero Length CSI File Replaced File: x86_22b657062893a091f8671c303a6a1007_31bf3856ad364e35_7.6.7601.19161_none_a678bd0d5b94c4d4.manifest From: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab
(f) CSI Manifest Failed Catalog Check 0x00000000 winsxs\Manifests\x86_b3f0fafee6a52dc6aac8e05c33068495_31bf3856ad364e35_6.1.7601.23338_none_da080f8d700a3738.manifest x86_b3f0fafee6a52dc6aac8e05c33068495_31bf3856ad364e35_6.1.7601.23338_none_da080f8d700a3738
(fix) CSI Manifest Failed Catalog Check CSI File Replaced File: x86_b3f0fafee6a52dc6aac8e05c33068495_31bf3856ad364e35_6.1.7601.23338_none_da080f8d700a3738.manifest From: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab
(f) CSI Manifest Failed Catalog Check 0x00000000 winsxs\Manifests\x86_c444ec17cdeb8c696abb2b35569c3320_31bf3856ad364e35_6.1.7601.19135_none_ef8e89e2c1673d6a.manifest x86_c444ec17cdeb8c696abb2b35569c3320_31bf3856ad364e35_6.1.7601.19135_none_ef8e89e2c1673d6a
(fix) CSI Manifest Failed Catalog Check CSI File Replaced File: x86_c444ec17cdeb8c696abb2b35569c3320_31bf3856ad364e35_6.1.7601.19135_none_ef8e89e2c1673d6a.manifest From: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab
(f) CSI Manifest Zero Length 0x00000000 winsxs\Manifests\x86_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_6.1.7601.23317_none_96613d91c99c7b2b.manifest x86_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_6.1.7601.23317_none_96613d91c99c7b2b
(fix) CSI Manifest Zero Length CSI File Replaced File: x86_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_6.1.7601.23317_none_96613d91c99c7b2b.manifest From: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab
(f) CSI Manifest Failed Catalog Check 0x00000000 winsxs\Manifests\x86_microsoft-windows-t..usbredirectorclient_31bf3856ad364e35_7.2.7601.16415_none_62a66f2852badfc5.manifest x86_microsoft-windows-t..usbredirectorclient_31bf3856ad364e35_7.2.7601.16415_none_62a66f2852badfc5
(f) CSI Manifest Missing 0x00000002 x86_microsoft-windows-i..rendering.resources_31bf3856ad364e35_11.2.9600.18499_en-us_9327d21b6017abb5.manifest x86_microsoft-windows-i..rendering.resources_31bf3856ad364e35_11.2.9600.18499_en-us_9327d21b6017abb5
(fix) CSI Manifest Missing CSI File Replaced File: x86_microsoft-windows-i..rendering.resources_31bf3856ad364e35_11.2.9600.18499_en-us_9327d21b6017abb5.manifest From: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab
(f) CSI Manifest Zero Length 0x00000000 winsxs\Manifests\x86_a4b0c46e466c00832de1f0918b0b3731_31bf3856ad364e35_7.6.7601.19161_none_4c90069c95cfe0d5.manifest x86_a4b0c46e466c00832de1f0918b0b3731_31bf3856ad364e35_7.6.7601.19161_none_4c90069c95cfe0d5
(fix) CSI Manifest Zero Length CSI File Replaced File: x86_a4b0c46e466c00832de1f0918b0b3731_31bf3856ad364e35_7.6.7601.19161_none_4c90069c95cfe0d5.manifest From: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab
(f) CSI Manifest Zero Length 0x00000000 winsxs\Manifests\x86_339643c0cca71ab7295afea64a9f00ec_31bf3856ad364e35_7.6.7601.19161_none_724b41b95dfad0c3.manifest x86_339643c0cca71ab7295afea64a9f00ec_31bf3856ad364e35_7.6.7601.19161_none_724b41b95dfad0c3
(fix) CSI Manifest Zero Length CSI File Replaced File: x86_339643c0cca71ab7295afea64a9f00ec_31bf3856ad364e35_7.6.7601.19161_none_724b41b95dfad0c3.manifest From: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab
(f) CSI Manifest Failed Catalog Check 0x00000000 winsxs\Manifests\x86_22444edb7d6c51aa2dbbc1ac5549c843_31bf3856ad364e35_6.1.7601.23338_none_22ddfc605fd985e1.manifest x86_22444edb7d6c51aa2dbbc1ac5549c843_31bf3856ad364e35_6.1.7601.23338_none_22ddfc605fd985e1
(fix) CSI Manifest Failed Catalog Check CSI File Replaced File: x86_22444edb7d6c51aa2dbbc1ac5549c843_31bf3856ad364e35_6.1.7601.23338_none_22ddfc605fd985e1.manifest From: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab
Summary:
Seconds executed: 814
Found 17 errors
Fixed 14 errors
CSI Manifest Missing Total count: 1
Fixed: CSI Manifest Missing. Total count: 1
CSI Manifest Zero Length Total count: 4
Fixed: CSI Manifest Zero Length. Total count: 4
CSI Manifest Failed Catalog Check Total count: 7
Fixed: CSI Manifest Failed Catalog Check. Total count: 4
CBS MUM Corrupt Total count: 1
Fixed: CBS MUM Corrupt. Total count: 1
CBS Catalog Corrupt Total count: 4
Fixed: CBS Catalog Corrupt. Total count: 4
Fixed: CBS Paired File. Total count: 5
Unavailable repair files:
winsxs\manifests\x86_netfx-mscoree_dll_31bf3856ad364e35_6.2.7600.16513_none_7daed23956119a9f.manifest
winsxs\manifests\x86_microsoft-windows-a..atibility-assistant_31bf3856ad364e35_6.1.7601.18741_none_35aa6c61818436f2.manifest
winsxs\manifests\x86_microsoft-windows-t..usbredirectorclient_31bf3856ad364e35_7.2.7601.16415_none_62a66f2852badfc5.manifest
Start time: 2016-11-15 20:16:46.918
Using .zip script file at C:\Users\Vince\Desktop\SFCFix.zip [0]
Trace::
Successfully traced component x86_netfx-mscoree_dll_31bf3856ad364e35_6.2.7600.16513_none_7daed23956119a9f.
    Package_for_KB958488~31bf3856ad364e35~x86~~6.2.7600.16513.NetFx4
Successfully traced component x86_microsoft-windows-a..atibility-assistant_31bf3856ad364e35_6.1.7601.18741_none_35aa6c61818436f2.
    Package_55_for_KB3033929~31bf3856ad364e35~x86~~6.1.1.1.3033929-302_neutral_LDR2
Successfully traced component x86_microsoft-windows-t..usbredirectorclient_31bf3856ad364e35_7.2.7601.16415_none_62a66f2852badfc5.
    Microsoft-Windows-RemoteDesktopClient-BlueIP-Package~31bf3856ad364e35~x86~~7.2.7601.16415.RemoteDesktopClient81-BlueIP
Finish time: 2016-11-15 20:16:47.527
Script hash: JBvIvufzw8NM/lOk9Z/Gi0Mq4vOiGs/ciKfpGw7gjbw=
I hope these are ok for you.
Perfect, thanks!
Windows Update Manifest Replacement
  4. A window will open showing the folder Manifests
  6. Run the System Update Readiness Tool (SURT) again.
  7. When the SURT finishes installing, copy (Ctrl + C) and paste (Ctrl + V) the contents of the SURT log into your next post please:
View attachment packs.zip
Here is the result.
2016-11-15 21:01
Checking Packages
(fix) CSI Manifest Failed Catalog Check CSI File Replaced File: x86_netfx-mscoree_dll_31bf3856ad364e35_6.2.7600.16513_none_7daed23956119a9f.manifest From: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab
(fix) CSI Manifest Failed Catalog Check CSI File Replaced File: x86_microsoft-windows-a..atibility-assistant_31bf3856ad364e35_6.1.7601.18741_none_35aa6c61818436f2.manifest From: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab
(fix) CSI Manifest Failed Catalog Check CSI File Replaced File: x86_microsoft-windows-t..usbredirectorclient_31bf3856ad364e35_7.2.7601.16415_none_62a66f2852badfc5.manifest From: C:\Windows\CheckSur\v1.0\windows6.1-7601-x86-cab4.cab
Summary:
Seconds executed: 714
Found 3 errors
Fixed 3 errors
CSI Manifest Failed Catalog Check Total count: 3
Fixed: CSI Manifest Failed Catalog Check. Total count: 3
Very good.
Let's check the health of your disk.
GSmartControl
  • Extract the content of the GSmartControl .zip archive and execute gsmartcontrol.exe; To extract you can right-click your mouse on the GSmartControl.zip file and select Extract.
  • Also, go in the Attributes tab and if you have any entries highlighted in red or pink, copy and paste their name in your next reply (or take a screenshot of the GSmartControl window and attach it in your next reply);
Thank you zcomputerwiz.
Here are the result
smartctl 5.43 2012-06-30 r3573 [i686-w64-mingw32-win7-sp1] (sf-5.43-1)
Copyright (C) 2002-12 by Bruce Allen, smartmontools
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Caviar Blue Serial ATA
Device Model: WDC WD1600AAJS-62WAA0
Serial Number: WD-WCAS2A880530
LU WWN Device Id: 5 0014ee 156d016db
Firmware Version: 58.01D58
User Capacity: 160,041,885,696 bytes [160 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: Exact ATA specification draft version not indicated
Local Time is: Wed Nov 16 21:43:33 2016 GMTST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 4380) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 55) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303f) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0003 153 153 021 Pre-fail Always - 3316
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 16
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x000e 200 200 051 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 204
10 Spin_Retry_Count 0x0012 100 253 051 Old_age Always - 0
11 Calibration_Retry_Count 0x0012 100 253 051 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 16
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 2
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 16
194 Temperature_Celsius 0x0022 103 103 000 Old_age Always - 40
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0012 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 051 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 204 -
# 2 Short offline Completed without error 00% 0 -
# 3 Conveyance offline Completed without error 00% 0 -
# 4 Conveyance offline Aborted by host 50% 0 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
There were no red/pink entries highlighted but attatched screenshiot.
Excellent, looks good.
Let's verify that there aren't additional filesystem corruptions:
chkdsk /f
  1. Click on the Start
    chkdsk /f
  4. Reboot
  5. Download ListChkdskResult.exe (by SleepyDude) from the link below:
    https://dl.dropboxusercontent.com/u/12354842/My Tools/ListChkdskResult.exe
  6. Double click on it to run it. It will take a few seconds to scan, then it will open a Notepad window with the log. Copy and paste the contents of this into your next post please!
Thank you for all your help so far.
Here is the result of ListChkdskResult.exe
------< Log generate on 21/11/2016 21:05:00 >------
Category: 0
Computer Name: Home-PC
Event Code: 1001
Record Number: 53680
Time Written: 11-21-2016 @ 21:01:05
Event Type: Information
User:
Message:
Checking file system on C:
CHKDSK is verifying files (stage 1 of 3)...
218368 file records processed.
File verification completed.
767 large file records processed.
0 bad file records processed.
2 EA records processed.
43 reparse records processed.
CHKDSK is verifying indexes (stage 2 of 3)...
269296 index entries processed.
Index verification completed.
0 unindexed files scanned.
0 unindexed files recovered.
CHKDSK is verifying security descriptors (stage 3 of 3)...
218368 file SDs/SIDs processed.
Cleaning up 3850 unused index entries from index $SII of file 0x9.
Cleaning up 3850 unused index entries from index $SDH of file 0x9.
Cleaning up 3850 unused security descriptors.
25465 data files processed.
37300840 USN bytes processed.
Windows has checked the file system and found no problems.
156280288 KB total disk space.
63701712 KB in 127078 files.
83124 KB in 25466 indexes.
0 KB in bad sectors.
331368 KB in use by the system.
92164084 KB available on disk.
39070072 total allocation units on disk.
23041021 allocation units available on disk.
Internal Info:
00 55 03 00 eb 53 02 00 da 28 04 00 00 00 00 00 .U...S...(......
29 04 00 00 2b 00 00 00 00 00 00 00 00 00 00 00 )...+...........
d0 8c 12 00 50 01 11 00 18 1a 11 00 00 00 11 00 ....P...........
Looks good. Now let's verify windows system files with SFC.
SFC Scan
  4. This will create a file, cbs.txt on your Desktop. Please zip and attach this to your next post.
Hello.
I have attatched the zip cbs file.
I think there were some errors from the scannow just like when i 1st started having problems.
SFC Scan
Here we go.
copy %windir%\logs\cbs\cbs.log %userprofile%\Desktop\cbs.txtSFCFix version 3.0.0.0 by niemiro.
Start time: 2016-11-22 19:19:55.235
Successfully took permissions for file or folder C:\Windows\winsxs\x86_wiabr00a.inf_31bf3856ad364e35_6.1.7600.16385_none_c3d5d0f14aac8dfa\brus2sti.dll
Successfully took permissions for file or folder C:\Windows\winsxs\x86_transfercable.inf_31bf3856ad364e35_6.1.7601.17514_none_62a70d1cf019f014\x86\winusb.sys
Successfully took permissions for file or folder C:\Windows\winsxs\x86_prnxx002.inf_31bf3856ad364e35_6.1.7600.16385_none_5ad632810fefc3dc\I386\XRX6180N.PPD
Successfully took permissions for file or folder C:\Windows\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf472.gpd
Successfully took permissions for file or folder C:\Windows\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf4x4.gpd
Successfully took permissions for file or folder C:\Windows\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf6x4.gpd
Successfully took permissions for file or folder C:\Windows\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI1321E3.PPD
Successfully took permissions for file or folder C:\Windows\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI1371E3.PPD
Successfully took permissions for file or folder C:\Windows\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI2192E3.PPD
Successfully took permissions for file or folder C:\Windows\winsxs\x86_prnok002.inf_31bf3856ad364e35_6.1.7600.16385_none_717101322a99525a\I386\OKML630F.GPD
Successfully took permissions for file or folder C:\Windows\winsxs\x86_prnhp005.inf_31bf3856ad364e35_6.1.7600.16385_none_d4cb0a8de67cd3af\I386\hp8500at.cfg
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-w32time-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_adb001e20e51af40\w32time.adml
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-w..ement-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_00992b1dcb117fc1\windowsremotemanagement.adml
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-tabletshell-adm_31bf3856ad364e35_6.1.7600.16385_none_6911904dc15dc8b4\tabletshell.admx
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-tabletpcinputpanel-adm_31bf3856ad364e35_6.1.7600.16385_none_2e452f790c6f2c63\tabletpcinputpanel.admx
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-t..lishing-wmiprovider_31bf3856ad364e35_6.1.7601.17514_none_373fc283f1cb38ca\tsallow.mof
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-sysprep_31bf3856ad364e35_6.1.7601.17514_none_f1860ab056bcfa69\sysprep.exe
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-s..tcard-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_16db4620373b1b5c\smartcard.adml
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-r..orage-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_33d2300b5f9d5439\removablestorage.adml
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-qos-adm_31bf3856ad364e35_6.1.7600.16385_none_d3b9c9c525d3c5b7\qos.admx
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-powershell_31bf3856ad364e35_6.1.7601.17514_none_ff381cd004fd6e1a\powershellcore.format.ps1xml
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-p2p-pnrp-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_2fdd993586b26c0c\p2p-pnrp.adml
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-p..ting-tools-printbrm_31bf3856ad364e35_6.1.7601.17514_none_83c1925fa396acd5\printbrmps.dll
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-ime-korean-hanjadic_31bf3856ad364e35_6.1.7600.16385_none_fad036f66f6e635e\imkrhjd.dll
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-i..hinese-imepadapplet_31bf3856ad364e35_6.1.7600.16385_none_faff6acb5cd29b45\imtcskf.dll
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-directshow-core_31bf3856ad364e35_6.1.7601.23471_none_a8bd2cd5657978f6\quartz.dll
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_hu-hu_d6f0eb51a588d90a\comdlg32.dll.mui
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_hr-hr_d5bcc58ba64b77a2\comdlg32.dll.mui
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_he-il_d3a012aba7980adc\comdlg32.dll.mui
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-com-dtc-tracing_31bf3856ad364e35_6.1.7600.16385_none_17b5a0e65422e9b1\msdtcvtr.bat
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_wiabr00a.inf_31bf3856ad364e35_6.1.7600.16385_none_c3d5d0f14aac8dfa\brus2sti.dll to C:\Windows\winsxs\x86_wiabr00a.inf_31bf3856ad364e35_6.1.7600.16385_none_c3d5d0f14aac8dfa\brus2sti.dll.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_wiabr009.inf_31bf3856ad364e35_6.1.7600.16385_none_ae6af8a55df31d92\brus2sti.dll to C:\Windows\winsxs\x86_wiabr009.inf_31bf3856ad364e35_6.1.7600.16385_none_ae6af8a55df31d92\brus2sti.dll.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_wiabr008.inf_31bf3856ad364e35_6.1.7600.16385_none_ade1e67044d4e129\brus2sti.dll to C:\Windows\winsxs\x86_wiabr008.inf_31bf3856ad364e35_6.1.7600.16385_none_ade1e67044d4e129\brus2sti.dll.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_wiabr007.inf_31bf3856ad364e35_6.1.7600.16385_none_ad58d43b2bb6a4c0\brus2sti.dll to C:\Windows\winsxs\x86_wiabr007.inf_31bf3856ad364e35_6.1.7600.16385_none_ad58d43b2bb6a4c0\brus2sti.dll.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_wiabr006.inf_31bf3856ad364e35_6.1.7600.16385_none_accfc20612986857\brus2sti.dll to C:\Windows\winsxs\x86_wiabr006.inf_31bf3856ad364e35_6.1.7600.16385_none_accfc20612986857\brus2sti.dll.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_wiabr005.inf_31bf3856ad364e35_6.1.7600.16385_none_ac46afd0f97a2bee\brus2sti.dll to C:\Windows\winsxs\x86_wiabr005.inf_31bf3856ad364e35_6.1.7600.16385_none_ac46afd0f97a2bee\brus2sti.dll.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_wiabr004.inf_31bf3856ad364e35_6.1.7600.16385_none_abbd9d9be05bef85\brus2sti.dll to C:\Windows\winsxs\x86_wiabr004.inf_31bf3856ad364e35_6.1.7600.16385_none_abbd9d9be05bef85\brus2sti.dll.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_wiabr002.inf_31bf3856ad364e35_6.1.7600.16385_none_aaab7931ae1f76b3\brus2sti.dll to C:\Windows\winsxs\x86_wiabr002.inf_31bf3856ad364e35_6.1.7600.16385_none_aaab7931ae1f76b3\brus2sti.dll.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_transfercable.inf_31bf3856ad364e35_6.1.7601.17514_none_62a70d1cf019f014\x86\winusb.sys to C:\Windows\winsxs\x86_transfercable.inf_31bf3856ad364e35_6.1.7601.17514_none_62a70d1cf019f014\x86\winusb.sys.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_prnxx002.inf_31bf3856ad364e35_6.1.7600.16385_none_5ad632810fefc3dc\I386\XRX6180N.PPD to C:\Windows\winsxs\x86_prnxx002.inf_31bf3856ad364e35_6.1.7600.16385_none_5ad632810fefc3dc\I386\XRX6180N.PPD.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf472.gpd to C:\Windows\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf472.gpd.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf4x4.gpd to C:\Windows\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf4x4.gpd.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf6x4.gpd to C:\Windows\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf6x4.gpd.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI1321E3.PPD to C:\Windows\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI1321E3.PPD.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI1371E3.PPD to C:\Windows\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI1371E3.PPD.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI2192E3.PPD to C:\Windows\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI2192E3.PPD.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_prnok002.inf_31bf3856ad364e35_6.1.7600.16385_none_717101322a99525a\I386\OKML630F.GPD to C:\Windows\winsxs\x86_prnok002.inf_31bf3856ad364e35_6.1.7600.16385_none_717101322a99525a\I386\OKML630F.GPD.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_prnhp005.inf_31bf3856ad364e35_6.1.7600.16385_none_d4cb0a8de67cd3af\I386\hp8500at.cfg to C:\Windows\winsxs\x86_prnhp005.inf_31bf3856ad364e35_6.1.7600.16385_none_d4cb0a8de67cd3af\I386\hp8500at.cfg.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-w32time-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_adb001e20e51af40\w32time.adml to C:\Windows\winsxs\x86_microsoft-windows-w32time-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_adb001e20e51af40\w32time.adml.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-w..ement-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_00992b1dcb117fc1\windowsremotemanagement.adml to C:\Windows\winsxs\x86_microsoft-windows-w..ement-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_00992b1dcb117fc1\windowsremotemanagement.adml.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-tabletshell-adm_31bf3856ad364e35_6.1.7600.16385_none_6911904dc15dc8b4\tabletshell.admx to C:\Windows\winsxs\x86_microsoft-windows-tabletshell-adm_31bf3856ad364e35_6.1.7600.16385_none_6911904dc15dc8b4\tabletshell.admx.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-tabletpcinputpanel-adm_31bf3856ad364e35_6.1.7600.16385_none_2e452f790c6f2c63\tabletpcinputpanel.admx to C:\Windows\winsxs\x86_microsoft-windows-tabletpcinputpanel-adm_31bf3856ad364e35_6.1.7600.16385_none_2e452f790c6f2c63\tabletpcinputpanel.admx.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-t..lishing-wmiprovider_31bf3856ad364e35_6.1.7601.17514_none_373fc283f1cb38ca\tsallow.mof to C:\Windows\winsxs\x86_microsoft-windows-t..lishing-wmiprovider_31bf3856ad364e35_6.1.7601.17514_none_373fc283f1cb38ca\tsallow.mof.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-sysprep_31bf3856ad364e35_6.1.7601.17514_none_f1860ab056bcfa69\sysprep.exe to C:\Windows\winsxs\x86_microsoft-windows-sysprep_31bf3856ad364e35_6.1.7601.17514_none_f1860ab056bcfa69\sysprep.exe.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-s..tcard-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_16db4620373b1b5c\smartcard.adml to C:\Windows\winsxs\x86_microsoft-windows-s..tcard-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_16db4620373b1b5c\smartcard.adml.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-r..orage-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_33d2300b5f9d5439\removablestorage.adml to C:\Windows\winsxs\x86_microsoft-windows-r..orage-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_33d2300b5f9d5439\removablestorage.adml.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-qos-adm_31bf3856ad364e35_6.1.7600.16385_none_d3b9c9c525d3c5b7\qos.admx to C:\Windows\winsxs\x86_microsoft-windows-qos-adm_31bf3856ad364e35_6.1.7600.16385_none_d3b9c9c525d3c5b7\qos.admx.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-powershell_31bf3856ad364e35_6.1.7601.17514_none_ff381cd004fd6e1a\powershellcore.format.ps1xml to C:\Windows\winsxs\x86_microsoft-windows-powershell_31bf3856ad364e35_6.1.7601.17514_none_ff381cd004fd6e1a\powershellcore.format.ps1xml.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-p2p-pnrp-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_2fdd993586b26c0c\p2p-pnrp.adml to C:\Windows\winsxs\x86_microsoft-windows-p2p-pnrp-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_2fdd993586b26c0c\p2p-pnrp.adml.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-p..ting-tools-printbrm_31bf3856ad364e35_6.1.7601.17514_none_83c1925fa396acd5\printbrmps.dll to C:\Windows\winsxs\x86_microsoft-windows-p..ting-tools-printbrm_31bf3856ad364e35_6.1.7601.17514_none_83c1925fa396acd5\printbrmps.dll.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-ime-korean-hanjadic_31bf3856ad364e35_6.1.7600.16385_none_fad036f66f6e635e\imkrhjd.dll to C:\Windows\winsxs\x86_microsoft-windows-ime-korean-hanjadic_31bf3856ad364e35_6.1.7600.16385_none_fad036f66f6e635e\imkrhjd.dll.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-i..hinese-imepadapplet_31bf3856ad364e35_6.1.7600.16385_none_faff6acb5cd29b45\imtcskf.dll to C:\Windows\winsxs\x86_microsoft-windows-i..hinese-imepadapplet_31bf3856ad364e35_6.1.7600.16385_none_faff6acb5cd29b45\imtcskf.dll.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-directshow-core_31bf3856ad364e35_6.1.7601.23471_none_a8bd2cd5657978f6\quartz.dll to C:\Windows\winsxs\x86_microsoft-windows-directshow-core_31bf3856ad364e35_6.1.7601.23471_none_a8bd2cd5657978f6\quartz.dll.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_hu-hu_d6f0eb51a588d90a\comdlg32.dll.mui to C:\Windows\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_hu-hu_d6f0eb51a588d90a\comdlg32.dll.mui.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_hr-hr_d5bcc58ba64b77a2\comdlg32.dll.mui to C:\Windows\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_hr-hr_d5bcc58ba64b77a2\comdlg32.dll.mui.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_he-il_d3a012aba7980adc\comdlg32.dll.mui to C:\Windows\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_he-il_d3a012aba7980adc\comdlg32.dll.mui.
Successfully copied file C:\Users\Vince\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-com-dtc-tracing_31bf3856ad364e35_6.1.7600.16385_none_17b5a0e65422e9b1\msdtcvtr.bat to C:\Windows\winsxs\x86_microsoft-windows-com-dtc-tracing_31bf3856ad364e35_6.1.7600.16385_none_17b5a0e65422e9b1\msdtcvtr.bat.
Successfully restored ownership for C:\Windows\winsxs\x86_wiabr00a.inf_31bf3856ad364e35_6.1.7600.16385_none_c3d5d0f14aac8dfa\brus2sti.dll
Successfully restored permissions on C:\Windows\winsxs\x86_wiabr00a.inf_31bf3856ad364e35_6.1.7600.16385_none_c3d5d0f14aac8dfa\brus2sti.dll
Successfully restored ownership for C:\Windows\winsxs\x86_transfercable.inf_31bf3856ad364e35_6.1.7601.17514_none_62a70d1cf019f014\x86\winusb.sys
Successfully restored permissions on C:\Windows\winsxs\x86_transfercable.inf_31bf3856ad364e35_6.1.7601.17514_none_62a70d1cf019f014\x86\winusb.sys
Successfully restored ownership for C:\Windows\winsxs\x86_prnxx002.inf_31bf3856ad364e35_6.1.7600.16385_none_5ad632810fefc3dc\I386\XRX6180N.PPD
Successfully restored permissions on C:\Windows\winsxs\x86_prnxx002.inf_31bf3856ad364e35_6.1.7600.16385_none_5ad632810fefc3dc\I386\XRX6180N.PPD
Successfully restored ownership for C:\Windows\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf472.gpd
Successfully restored permissions on C:\Windows\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf472.gpd
Successfully restored ownership for C:\Windows\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf4x4.gpd
Successfully restored permissions on C:\Windows\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf4x4.gpd
Successfully restored ownership for C:\Windows\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf6x4.gpd
Successfully restored permissions on C:\Windows\winsxs\x86_prnsa002.inf_31bf3856ad364e35_6.1.7600.16385_none_a6848f451d050fc0\I386\smf6x4.gpd
Successfully restored ownership for C:\Windows\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI1321E3.PPD
Successfully restored permissions on C:\Windows\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI1321E3.PPD
Successfully restored ownership for C:\Windows\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI1371E3.PPD
Successfully restored permissions on C:\Windows\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI1371E3.PPD
Successfully restored ownership for C:\Windows\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI2192E3.PPD
Successfully restored permissions on C:\Windows\winsxs\x86_prnrc007.inf_31bf3856ad364e35_6.1.7600.16385_none_c7641bb9218e51f4\I386\RI2192E3.PPD
Successfully restored ownership for C:\Windows\winsxs\x86_prnok002.inf_31bf3856ad364e35_6.1.7600.16385_none_717101322a99525a\I386\OKML630F.GPD
Successfully restored permissions on C:\Windows\winsxs\x86_prnok002.inf_31bf3856ad364e35_6.1.7600.16385_none_717101322a99525a\I386\OKML630F.GPD
Successfully restored ownership for C:\Windows\winsxs\x86_prnhp005.inf_31bf3856ad364e35_6.1.7600.16385_none_d4cb0a8de67cd3af\I386\hp8500at.cfg
Successfully restored permissions on C:\Windows\winsxs\x86_prnhp005.inf_31bf3856ad364e35_6.1.7600.16385_none_d4cb0a8de67cd3af\I386\hp8500at.cfg
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-w32time-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_adb001e20e51af40\w32time.adml
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-w32time-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_adb001e20e51af40\w32time.adml
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-w..ement-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_00992b1dcb117fc1\windowsremotemanagement.adml
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-w..ement-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_00992b1dcb117fc1\windowsremotemanagement.adml
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-tabletshell-adm_31bf3856ad364e35_6.1.7600.16385_none_6911904dc15dc8b4\tabletshell.admx
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-tabletshell-adm_31bf3856ad364e35_6.1.7600.16385_none_6911904dc15dc8b4\tabletshell.admx
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-tabletpcinputpanel-adm_31bf3856ad364e35_6.1.7600.16385_none_2e452f790c6f2c63\tabletpcinputpanel.admx
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-tabletpcinputpanel-adm_31bf3856ad364e35_6.1.7600.16385_none_2e452f790c6f2c63\tabletpcinputpanel.admx
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-t..lishing-wmiprovider_31bf3856ad364e35_6.1.7601.17514_none_373fc283f1cb38ca\tsallow.mof
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-t..lishing-wmiprovider_31bf3856ad364e35_6.1.7601.17514_none_373fc283f1cb38ca\tsallow.mof
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-sysprep_31bf3856ad364e35_6.1.7601.17514_none_f1860ab056bcfa69\sysprep.exe
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-sysprep_31bf3856ad364e35_6.1.7601.17514_none_f1860ab056bcfa69\sysprep.exe
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-s..tcard-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_16db4620373b1b5c\smartcard.adml
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-s..tcard-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_16db4620373b1b5c\smartcard.adml
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-r..orage-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_33d2300b5f9d5439\removablestorage.adml
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-r..orage-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_33d2300b5f9d5439\removablestorage.adml
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-qos-adm_31bf3856ad364e35_6.1.7600.16385_none_d3b9c9c525d3c5b7\qos.admx
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-qos-adm_31bf3856ad364e35_6.1.7600.16385_none_d3b9c9c525d3c5b7\qos.admx
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-powershell_31bf3856ad364e35_6.1.7601.17514_none_ff381cd004fd6e1a\powershellcore.format.ps1xml
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-powershell_31bf3856ad364e35_6.1.7601.17514_none_ff381cd004fd6e1a\powershellcore.format.ps1xml
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-p2p-pnrp-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_2fdd993586b26c0c\p2p-pnrp.adml
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-p2p-pnrp-adm.resources_31bf3856ad364e35_6.1.7600.16385_en-us_2fdd993586b26c0c\p2p-pnrp.adml
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-p..ting-tools-printbrm_31bf3856ad364e35_6.1.7601.17514_none_83c1925fa396acd5\printbrmps.dll
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-p..ting-tools-printbrm_31bf3856ad364e35_6.1.7601.17514_none_83c1925fa396acd5\printbrmps.dll
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-ime-korean-hanjadic_31bf3856ad364e35_6.1.7600.16385_none_fad036f66f6e635e\imkrhjd.dll
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-ime-korean-hanjadic_31bf3856ad364e35_6.1.7600.16385_none_fad036f66f6e635e\imkrhjd.dll
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-i..hinese-imepadapplet_31bf3856ad364e35_6.1.7600.16385_none_faff6acb5cd29b45\imtcskf.dll
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-i..hinese-imepadapplet_31bf3856ad364e35_6.1.7600.16385_none_faff6acb5cd29b45\imtcskf.dll
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-directshow-core_31bf3856ad364e35_6.1.7601.23471_none_a8bd2cd5657978f6\quartz.dll
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-directshow-core_31bf3856ad364e35_6.1.7601.23471_none_a8bd2cd5657978f6\quartz.dll
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_hu-hu_d6f0eb51a588d90a\comdlg32.dll.mui
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_hu-hu_d6f0eb51a588d90a\comdlg32.dll.mui
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_hr-hr_d5bcc58ba64b77a2\comdlg32.dll.mui
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_hr-hr_d5bcc58ba64b77a2\comdlg32.dll.mui
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_he-il_d3a012aba7980adc\comdlg32.dll.mui
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-comdlg32.resources_31bf3856ad364e35_6.1.7601.17514_he-il_d3a012aba7980adc\comdlg32.dll.mui
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-com-dtc-tracing_31bf3856ad364e35_6.1.7600.16385_none_17b5a0e65422e9b1\msdtcvtr.bat
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-com-dtc-tracing_31bf3856ad364e35_6.1.7600.16385_none_17b5a0e65422e9b1\msdtcvtr.bat
Currently storing 33 datablocks.
Finish time: 2016-11-22 19:20:04.408
Script hash: CZhUpR3C9Pg3BB+ib3P3noxp8S3egxPzUyfcQ5mX0Dg=
Looks good :thumbsup2:
Please check for Windows Updates and install any that are offered.
If an update fails, zip and attach C:\Windows\Logs\CBS\CBS.log with your reply.
Hello zcomputerwiz.
I have done updates and all has been ok for 5 days and no errors in event logs at all.
2 days ago cloned the new hard drive onto the original hard drive which was in the pc when the troubles started and it has been working ok with no errors also.
Your advice and hard work have helped me out and i would like to thanky for your help and wish you and your family a Merry Christmas.
Thank you.
1vincent.
Glad to help and Merry Christmas to you and yours as well!
I'll mark the thread solved. If you encounter any problems please post back and I will continue to assist you.
