Hello Jacob,
I've looked through your logs and have to say this isn't looking very good:
2015-03-30 12:01:29, Info CBS Failed to load the COMPONENTS hive from 'C:\WINDOWS\System32\config\COMPONENTS' into registry key 'HKLM\COMPONENTS'. [HRESULT = 0x800703f1 - ERROR_BADDB]
2015-03-30 12:01:29, Info CBS Failed to load component store [HRESULT = 0x800703f1 - ERROR_BADDB]
2015-03-30 12:01:29, Info CBS Failed to get CSI store. [HRESULT = 0x800703f1 - ERROR_BADDB]
2015-03-30 12:01:29, Info CBS Failed to get CSI Store. [HRESULT = 0x800703f1 - ERROR_BADDB]
2015-03-30 12:01:29, Info CBS Failed to get CSI session store. [HRESULT = 0x800703f1 - ERROR_BADDB]
2015-03-30 12:01:29, Info CBS Failed to check CSI store. [HRESULT = 0x800703f1 - ERROR_BADDB]
This is a strong indication of a corrupt COMPONENTS.
Can you have a look at this file please:
C:\Windows\system32\config\COMPONENTS
I want you to look at its file size - if it's less than 10MB then tell me, if it's larger, then follow these instructions to upload it please:
- [sfcfixdownload]Download SFCFix[/sfcfixdownload] (by niemiro) and save this to your Desktop.
- Download the attached file, SFCFixScript.txt, and save this to your Desktop. Ensure that this file is named SFCFixScript.txt - do not rename it.
- Save any open documents and close all open windows.
- On your Desktop, you should see two files: SFCFix.exe and SFCFixScript.txt.
- Drag the file SFCFixScript.txt onto the file SFCFix.exe and release it.
- SFCFix will now process the script.
- Upon completion, a log should be created on your Desktop: SFCFix.txt.
- Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text.
https://dl.dropboxusercontent.com/u...eric/Collect/COMPONENTS/SFCFixScript.txt?dl=1
Tom
