Hi
Everything was fine with my pc until I changed my graphic card from "Nvidia GT 220" to "Nvidia GTX 650 Ti Boost". I installed the latest version of the related driver "445.87". And...
Problems after changing:
1. A lot of kind of buzzing sound when a music a playing or kind of blinking freeze when a video is playing.
2. Notification area popup: "Display driver stopped responding and has recovered". Usually when the buzzing continues about two or more seconds, i will have a blinking black screen and then the stopped driver popup shows.
3. Freezing completely, but lesser than buzzing sound.
4. I guess one time or two bsod code 0x00000D1.
5. After returning to the old VGA, i had this error too: "The Nvidia openGL driver detected a problem with the display driver and is unable to continue. the application must close. error code 3".
6. there are a lot of this log in windows failures report and their times are match to the time of freezing of my pc. The computer has rebooted from a bugcheck. The bugcheck was: 0x00000117
Things I have tried:
1. Uninstalling the driver with DDU software in safe mode and even ticking the deletion of the Nvidia folder.
2. Changing the VGA power program to high performance.
3. Adding key to the registry: TdrDelay of 8 to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\GraphicsDrivers
4. Downgrading to 3 other certified drivers. From 445.87 to 442.74, 442.50 and also 441.66. I did all of these with uninstalling the driver in safe mode with DDU.
5. Changing the performance setting of the windows to almost win 98.
6. Using registry clean softwares to clean the registry.
7. Even removing the new graphic card and using the old one.
8. Using memory diagnostic tool of windows. (No error)
I might've even done more than these, but I can't remember and still, no success.
I really appreciate your help.
Regards
Start time: 2020-05-11 04:41:16.797
FIXED: Successfully repaired missing store directory C:\Windows\winsxs\amd64_nv_lh.inf_31bf3856ad364e35_6.1.7600.16385_none_4a5c7d78e486512b.
WARNING: Failed to get store name from identity name with return code 2 for component nv_lh.inf and file nvwgf2umx.dll. File is reported as corrupt by SFC.
CORRUPT: nvwgf2umx.dll of component nv_lh.inf.
WARNING: Failed to get store name from identity name with return code 2 for component nv_lh.inf and file nvwgf2um.dll. File is reported as corrupt by SFC.
CORRUPT: nvwgf2um.dll of component nv_lh.inf.
WARNING: Failed to get store name from identity name with return code 2 for component nv_lh.inf and file nvd3dum.dll. File is reported as corrupt by SFC.
CORRUPT: nvd3dum.dll of component nv_lh.inf.
WARNING: Failed to get store name from identity name with return code 2 for component nv_lh.inf and file nvlddmkm.sys. File is reported as corrupt by SFC.
CORRUPT: nvlddmkm.sys of component nv_lh.inf.
WARNING: Failed to get store name from identity name with return code 2 for component nv_lh.inf and file nvd3dumx.dll. File is reported as corrupt by SFC.
CORRUPT: nvd3dumx.dll of component nv_lh.inf.
WARNING: Failed to get store name from identity name with return code 2 for component nv_lh.inf and file nv_LH.inf. File is reported as corrupt by SFC.
CORRUPT: nv_LH.inf of component nv_lh.inf.
CBS & SFC total detected corruption count: 7
CBS & SFC total fixed corruption count: 1
Finish time: 2020-05-11 05:23:18.728
Regards
