Corrupt system files- SFC fix / DISM stuck at 40%
qwerty123
Hi Everyone,
I am thoroughly puzzled as to why not my pc is working correctly after i deleted the windows.old folder,from the previous installation of windows 10.
Basic services like start menu are not working on my pc.
Please help.
Thanks in advance,
YS
:huh:
Hi qwerty123 :)
My name is Aura and I'll be assisting you with your issue. Follow the instructions below please.
System File Checker (SFC)
    Run as Administrator
