[SOLVED] Corrupt SFC scannow...SfcFix after running told me to come here and post my issue
cadprofessor
Ran Sfcfix after running sfc /scannow and finding corrupt files. Insert my Windows 7 pro DVD when instructed. This is the text file that was created. If there is another log file that you need please tell be where to locate it.
Start time: 2020-01-10 16:53:10.207
CORRUPT: C:\Windows\winsxs
\msil_microsoft.mediacenter.shell_31bf3856ad364e35_6.1.7601.17514_none_529b6191f4228c10\Microsoft.MediaCenter
.Shell.dll
SURT total detected corruption count: 8
SFC Scan
Start time: 2020-01-10 20:27:07.072
Using .zip script file at E:\Downloads\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\WinSxS\msil_microsoft.mediacenter.shell_31bf3856ad364e35_6.1.7601.17514_none_529b6191f4228c10\Microsoft.MediaCenter.Shell.dll
Successfully copied file C:\Users\Michael Jordan\AppData\Local\niemiro\Archive\WinSxS\msil_microsoft.mediacenter.shell_31bf3856ad364e35_6.1.7601.17514_none_529b6191f4228c10\Microsoft.MediaCenter.Shell.dll to C:\Windows\WinSxS\msil_microsoft.mediacenter.shell_31bf3856ad364e35_6.1.7601.17514_none_529b6191f4228c10\Microsoft.MediaCenter.Shell.dll.
Successfully restored ownership for C:\Windows\WinSxS\msil_microsoft.mediacenter.shell_31bf3856ad364e35_6.1.7601.17514_none_529b6191f4228c10\Microsoft.MediaCenter.Shell.dll
Successfully restored permissions on C:\Windows\WinSxS\msil_microsoft.mediacenter.shell_31bf3856ad364e35_6.1.7601.17514_none_529b6191f4228c10\Microsoft.MediaCenter.Shell.dll
Currently storing 90 datablocks.
Finish time: 2020-01-10 20:27:07.807
Script hash: dM4bnJg9jpYS+yd2oThvwRakdNYI1BclE6+s/yJ3oeo=
Thank you.
Step#1 - System Update Readiness Tool (SUR) Windows 7 - 64-Bit
2. When it asks you if you wish to install, please answer Yes. Note: It could take several hours to run. Please don't cancel it.
Please Note:: if the file is too big to upload to your next post, please upload via Sendspace and just provide the link here.
I am wondering if this has do with I installed EPG123 a few days ago and it changes many things in the windows media center and the ehome directory. Thank you for the assistance. Currently installing KB947821. I will send you the log file once it completes. Oh what is the upload limit on the file size. If it is to big can I not compress it ZIP?
No that seems to have fixed the sfc errors. Thank you so much for the help and assistance. Do have any ideas what may have caused the problem. Thanks again.
