PROBLEM: corrupt prncacla.inf file, possibly corrupt CNBJ2530.DPB file
FAILED SOLUTIONS:
I first ran the following three commands, all of which did not work to fix the corrupted files:
Dism /Online /Cleanup-Image /StartComponentCleanup
CBS file is attached as two parts as follows:
View attachment CBS 1.txt
View attachment CBS 2.txt
I ran SFCFix.exe
The result can be viewed in the attached SFCFix1.txt file. View attachment SFCFix1.txt
Then I dragged a SFCFix.zip file that I found on the forum from another thread, I think this one [ https://www.sysnative.com/forums/wi...prncacla-inf-corruptions-windows-8-8-1-a.html ] into SFCFix.exe
The result can be viewed in the attached SFCFix2.txt file. View attachment SFCFix2.txt
FAILED SOLUTIONS:
I ran SFCFix.exe
Note
The prncacla.inf file previously on the computer was changed from a 17415 version to a 16384 version through the takeown, icacls, and copy method. This did not work, so I used the takeown, icacls, and copy method again to go back from the 16384 version to the 17415 version (copy of the 17415 version in case it did not work). This may explain why the prncacla.inf version is 16384 in the SFCFix2.txt file, instead of the 17415 version.
I ran DISM, and it did not fix the corrupted files.
The result can be viewed in the attached dism.txt file. View attachment dism.txt
How can the corrupted files be fixed?
