Corrupt/Missing Winsxs manafest: No DVD in System
More Info
Start time: 2014-09-20 09:53:18.113
CORRUPT: C:\Windows\winsxs\amd64_cdrom.inf_31bf3856ad364e35_6.1.7601.17514_none_bdcf6151ba66f48b\cdrom.sys
Currently storing 225 datablocks.
Finish time: 2014-09-20 09:56:33.825
Hello DonB and welcome to Sysnative forums :)
Lets get this corrupt file fixed up.
SFC /SCANNOW
  1. Click on the
  4. Please wait for this to Finish before continuing with the rest of the steps.
Convert CBS.log to CBS.txt
  1. Click on the
    button => Inside the search box copy and paste the following command:
  2. Press Enter
  3. Once this has completed please go to your Desktop and you will find CBS.txt => Please upload CBS.txt to this thread
Please Note:: if the file is too big to upload to you next post please upload via Dropbox or ge.tt
Start time: 2014-09-23 10:51:47.024
Using .zip script file at C:\Users\DonB\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\amd64_cdrom.inf_31bf3856ad364e35_6.1.7601.17514_none_bdcf6151ba66f48b
Line blocked (SFCFix.txt): "C:\Users\DonB\AppData\Local\niemiro\Archive\SFCFix.txt" C:\Windows\SFCFix.txt.
Successfully copied file C:\Users\DonB\AppData\Local\niemiro\Archive\winsxs\amd64_cdrom.inf_31bf3856ad364e35_6.1.7601.17514_none_bdcf6151ba66f48b\cdrom.sys to C:\Windows\winsxs\amd64_cdrom.inf_31bf3856ad364e35_6.1.7601.17514_none_bdcf6151ba66f48b\cdrom.sys.
Successfully restored ownership for C:\Windows\winsxs\amd64_cdrom.inf_31bf3856ad364e35_6.1.7601.17514_none_bdcf6151ba66f48b
Successfully restored permissions on C:\Windows\winsxs\amd64_cdrom.inf_31bf3856ad364e35_6.1.7601.17514_none_bdcf6151ba66f48b
Currently storing 226 datablocks.
Finish time: 2014-09-23 10:51:47.486
Script hash: atoXYB/GOA5brpfHALgbRuI/WYACDIr3rQgSw4Izyp8=
The file can be be viewed. When I click on the link the following message appears:
The item might not exist or is no longer available
Your can try uploading it straight to the forum
SFCFix Collect CBS
  2. Download SFCFix.txt, and save this to your Desktop. Ensure that this file is named SFCFixScript.txt - do not rename it.
  3. On your Desktop, you should now see two files: SFCFix.exe and SFCFixScript.txt.
  4. Drag the file SFCFixScript.txt onto the file SFCFix.exe and release it.
  5. SFCFix will now begin to upload your CBS logfiles to our server.
  6. Upon completion, a log should be created on your Desktop: SFCFix.txt.
  7. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text.
If all goes well, you should see that your logfiles have now been added to your thread.
Thanks, I got the file this time.
Can you please run SFC /SCANNOW again then upload the file the same way as you did before?
Hi Don,
SFC is still identify the following errors
2014-09-25 10:28:02, Info                  CSI    00000333 [SR] Cannot repair member file [l:26{13}]"cdrom.sys.mui" of cdrom.inf.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing
2014-09-25 10:28:02, Info                  CSI    00000334 [SR] Cannot verify component files for Microsoft.VC80.ATL, Version = 8.0.50727.91, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope neutral, PublicKeyToken = {l:8 b:1fc8b3b9a1e18e3b}, Type = [l:10{5}]"win32", TypeName neutral, PublicKey neutral, manifest is damaged (FALSE)
2014-09-25 10:28:02, Info                  CSI    00000335 [SR] Cannot verify component files for Microsoft.VC80.MFC, Version = 8.0.50727.91, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope neutral, PublicKeyToken = {l:8 b:1fc8b3b9a1e18e3b}, Type = [l:10{5}]"win32", TypeName neutral, PublicKey neutral, manifest is damaged (FALSE)
2014-09-25 10:28:02, Info                  CSI    00000336 [SR] Cannot repair member file [l:26{13}]"cdrom.sys.mui" of cdrom.inf.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing
2014-09-25 10:28:02, Info                  CSI    00000337 [SR] This component was referenced by [l:188{94}]"Microsoft-Windows-Common-Drivers-Package~31bf3856ad364e35~amd64~en-US~6.1.7601.17514.INF_cdrom"
2014-09-25 10:28:02, Info                  CSI    00000338 [SR] Could not reproject corrupted file [ml:520{260},l:74{37}]"\??\C:\Windows\System32\drivers\en-US"\[l:26{13}]"cdrom.sys.mui"; source file in store is also corrupted
2014-09-25 10:28:02, Info                  CSI    00000339 Repair results created:
Download and Run SFCFix
Please download and run SFCFix from >Here<
It will take about 15 minutes to process. Once the scan has completed a notepad file will launch with the results. Please copy and paste the entire contents of the results and post them back into this thread. Please put [CODE][/CODE] tags around the log to break up the text.
Please follow the instructions Here to run the System Update Readiness Tool. When the SURT finishes installing, copy (Ctrl + C) and paste (Ctrl + V) the contents of the SURT log into your next post please:
C:\Windows\Logs\CBS\CheckSUR.log
C:\Windows\Logs\CBS\CheckSUR.persist.log
Hi Don,
UPLOADED:09/26/14
Start time: 2014-09-25 10:39:02.188
Using .txt script file at C:\Users\DonB\Desktop\SFCFixScript.txt [0]
Collect:: directive completed successfully.
   CBS & SFC total detected corruption count:     3
Finish time: 2014-09-26 10:24:23.035
Hi Don,
UPLOADED:09/26/14
Re: Logfile submission from DonB
RE: Ran Windows System Readiness Tool v33 (May 2014) for Win7x64
Date: 09/26/14
Summary:
Seconds executed: 415
Found 13 errors
Fixed 6 errors
CSI Manifest Missing Total count: 6
CSI Catalog Missing Total count: 6
Fixed: CSI Catalog Missing. Total count: 6
CSI Payload File Missing Total count: 1
Unavailable repair files:
winsxs\manifests\x86_microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.91_none_dc9917e997f80c63.manifest
winsxs\manifests\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.91_none_5c400d5e63e93b68.manifest
winsxs\manifests\x86_policy.8.0.microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.91_none_54c1279468b7b84b.manifest
winsxs\manifests\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.91_none_db5f5c9d98cb161f.manifest
winsxs\manifests\x86_microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.91_none_d6c3f1519bae0514.manifest
winsxs\manifests\x86_policy.8.0.microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.91_none_58b1a5ca663317c4.manifest
Hi Don,
Not having much lucky trying to find these files. Lets try another approach.
  2. Download SFCFixScript.txt (Attached to this post), and save this to your Desktop. Ensure that this file is named SFCFixScript.txt - do not rename it.
Don, can you please try the instructions again. That was not the right script. Please refer to my previous post for the correct script.
Alex
I need help installing fresh Manafest for DVD and CDROM.SYS in Win7 x64 OEM.
There seems to be more files corrupted?
See attached file: sfcdetails.txt
Thanks, DonB
NOTE: I have extracted Install.win to e:\Windows\winsxs
Start time: 2014-10-10 15:39:37.472
Trace::
Failed to trace component x86_microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.91_none_dc9917e997f80c63 with return code -3.
Failed to trace component x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.91_none_5c400d5e63e93b68 with return code -3.
Failed to trace component x86_policy.8.0.microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.91_none_54c1279468b7b84b with return code -3.
Failed to trace component x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.91_none_db5f5c9d98cb161f with return code -3.
Failed to trace component x86_microsoft.vc80.mfc_1fc8b3b9a1e18e3b_8.0.50727.91_none_d6c3f1519bae0514 with return code -3.
Failed to trace component x86_policy.8.0.microsoft.vc80.atl_1fc8b3b9a1e18e3b_8.0.50727.91_none_58b1a5ca663317c4 with return code -3.
Currently storing 227 datablocks.
Finish time: 2014-10-10 15:39:38.512
Script hash: wipUJKeuec8LeynJGCQJp1W5fQET6ii7QXxg+mHcniI=
Thanks, DonB
