THROW_ME_AWAY
- Dec 16, 2019
- 35
Hi, My PC takes a very long time to power off after I shut it down.
The screen turns off after the shutdown animation, but the Fans, RGB etc. stay on for very long afterwards.
This only happens o windows, not on an ubuntu install I have on another disk, so I can safely exclude any hardware issues.
I found it's not really safe to power it off by suffocating it with the power button, because that led to a broken EFI partition which I had to repair.
Luckily that's working again after rebuilding the EFI with an installation media and a system restore.
How can I safely diagnose what program or driver is causing the long wait before shutdown?
I tried booting in safe mode, but the problem persists there (sometimes?).
I'm not really sure how to proceed with this.
I'm worried that if I leave it like this, it might cause more system corruption in the future, so I want to solve the problem before it gets worse.
Is there a tool which I can use to see which drivers are still running after shutdown?
Maybe some sort of virtual driver whose job is to log which other drivers are still running after shutdown and then exits after like 5-10 minutes so it itself does not block shutdown?
Other things I tried:
chkdsk C: -> Windows has scanned the file system and found no problems.
sfc /SCANNOW -> Found corrupt files and repaired them. Running it again found no integrity violations
DISM /online /Cleanup-Image /ScanHealth -> No component store corruption detected.
Reinstall/update all drivers I could find (NVIDIA, Sound Card, Mouse) -> No Change
If you could help me with this, I would very much appreciate it!
Thanks in advance!
Thanks in advance!
