Changing of Wi-Fi caused Problems with Network Driver/High DPC Latency
LatexKaktus
I got new Fiber this week and used the same fiber before from my neighbor, since then I get high dpc latency, audio stuttering etc.
I tried a lot searching up the problem, but nothing fixes it, I am out of options and frustrated, so I am seeking help here.
Thank you in advance.
  • System Manufacturer? ASUS
  • Laptop or Desktop? Desktop
  • Exact model number (if laptop, check label on bottom) 140526608400227
  • OS ? (Windows 10, 8.1, 8, 7, Vista) Windows 10
  • x86 (32bit) or x64 (64bit)? 64-Nit-System,x64-based processor
  • Service pack? 1803
  • What was original installed OS on system? Windows 10
  • Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? Pre-installed
  • Age of system? (hardware) 2014
  • Age of OS installation? 2014
  • Have you re-installed the OS? No
  • CPU Intel(R) Core(TM) i5-4590 CPU@ 3.30GHz
  • RAM (brand, EXACT model, what slots are you using?) I tried figuring this out, I really dont know, all I find out is that its 8 GB
  • Video Card AMD Radeon R9 200 Series
  • MotherBoard - (if NOT a laptop) ASUSteK COMPUTER INC.
  • Power Supply - brand & wattage (if laptop, skip this one) AIDON/VCCIN 1.744V
  • Is driver verifier enabled or disabled? unsure
  • What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth) Avira
  • Are you using proxy, vpn, ipfilters or similar software? no
  • Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) no
  • Are you currently under/overclocking? Are there overclocking software installed on your system? no
http://speccy.piriform.com/results/MmqhSwnFMI4ef7Hv5zvNovs
View attachment msinfo32.zipView attachment DxDiag.zip
xqFFlusde0AAAAASUVORK5CYII=
