BSOD W10 PRO X64, IRQL (not less or equal)
Nenadius
I had BSOD issues (IRQL..not less or equal) few times since I upgrade from W8 to W10 pro x64 - 10 days ago. Last one happend 4 days ago. In the meantime I have uninstall or reinstall some apps and upgrade drivers and fix some sfc /scannow errors with great help of BrianDrab and jcgriff2.
- I had some rarely happening issues with audio (on W8 too) - crackling sound (any player) for which I can not find the reason..When I replay the song - it is ok.
- IE crashes on W10, do not know the reason, so now I am using Edge.
- No other issues..
My system is custom assembled desktop PC 7-8 yrs old - ASUS P8P67 Pro motherboard, 16gb ram, Radeon HD6670 video card, Juli@ Esi soundcard with spdif output to external DAC, 3xHDD internal (WD and Seagate) + 3 x HDD Seagate external.
I would like to ask for check up what is making the BSOD problem (if it still exists). Needed files are attached.
Any suggestion on audio problem???
Thks in advance.
Nenadius
Hi. . .
There were no mini kernel memory dump files in the attached zip file.
I did check msinfo32 WERCON section and found that you've had 12 BSODs -
(SCROLL TO RIGHT)
06/04/2016 08:19	Windows Error Reporting	Fault bucket AV_ipfnd630!unknown_function, type 0
Event Name: [color=red]BlueScreen[/color]
Response: http://wer.microsoft.com/responses/resredir.aspx?sid=10&Bucket=AV_ipfnd630!unknown_function&State=1&ID=b81a79d9-dd57-4acc-b996-aa9f27f79696
Cab Id:
06/04/2016 08:19	Windows Error Reporting	Fault bucket , type 0
Response: Not available
Cab Id: 0
Problem signature:
P1: d1
P2: 8
P3: 2
P4: 0
P5
04/04/2016 09:19	Windows Error Reporting	Fault bucket AV_ipfnd630!Unknown_Function, type 0
Response: http://wer.microsoft.com/responses/resredir.aspx?sid=10&Bucket=AV_ipfnd630!Unknown_Function&State=1&ID=d5ee68bd-6733-4bd4-a99d-97452fdc1c78
Cab Id:
04/04/2016 09:18	Windows Error Reporting	Fault bucket , type 0
Cab Id: 0
Problem signature:
P1: d1
P2: 8
P3: 2
P4: 0
P5
28/03/2016 08:34	Windows Error Reporting	Fault bucket AV_ipfnd630!Unknown_Function, type 0
Response: http://wer.microsoft.com/responses/resredir.aspx?sid=10&Bucket=AV_ipfnd630!Unknown_Function&State=1&ID=f1e99933-88b9-4bc5-96b8-854e659bab09
Cab Id:
28/03/2016 08:34	Windows Error Reporting	Fault bucket , type 0
Cab Id: 0
Problem signature:
P1: d1
P2: 8
P3: 2
P4: 0
P5
27/03/2016 12:16	Windows Error Reporting	Fault bucket AV_ipfnd630!Unknown_Function, type 0
Response: http://wer.microsoft.com/responses/resredir.aspx?sid=10&Bucket=AV_ipfnd630!Unknown_Function&State=1&ID=0259f30a-b8d6-430f-b090-16e4fe27616e
Cab Id:
27/03/2016 12:15	Windows Error Reporting	Fault bucket , type 0
Cab Id: 0
Problem signature:
P1: d1
P2: 8
P3: 2
P4: 0
P5
27/03/2016 11:42	Windows Error Reporting	Fault bucket AV_ipfnd630!Unknown_Function, type 0
Response: http://wer.microsoft.com/responses/resredir.aspx?sid=10&Bucket=AV_ipfnd630!Unknown_Function&State=1&ID=a540f95f-1b57-4464-a8ba-5a6844a9e260
Cab Id:
27/03/2016 11:41	Windows Error Reporting	Fault bucket , type 0
Cab Id: 0
Problem signature:
P1: d1
P2: 8
P3: 2
P4: 0
P5
26/03/2016 19:51	Windows Error Reporting	Fault bucket AV_ipfnd630!Unknown_Function, type 0
Response: http://wer.microsoft.com/responses/resredir.aspx?sid=10&Bucket=AV_ipfnd630!Unknown_Function&State=1&ID=191cf703-771f-4187-918f-73e850e3fcaf
Cab Id:
26/03/2016 19:50	Windows Error Reporting	Fault bucket , type 0
Cab Id: 0
Problem signature:
P1: d1
P2: 8
P3: 2
P4: 0
P5
If you're using an app like CCleaner, un-check "memory dumps" from the deletion/cleaning settings so that dumps files will remain in-tact.
Regards. . .
jcgriff2
p.s. Also check system crash settings to make sure yours is set to "automatic" dump file. You can find the crash settings in Control Panel; System; Advanced System Settings
EDIT: make sure that your audio drivers are updated.
Make sure that BIOS is updated.
Those are the only 2 items that I can think of for audio issues.
Probably your network driver from the looks of WER.
Thks for quick answer.
- I have disable CC Cleaner and Advanced SystemCare and will wait for next BSOD to give you fresh details.....
- Automatic mini dump was setup correct.
- Audio driver is new one, but will check up for UEFI/BIOS update..
- Network Adapter is old TP-LINK TF3200, for which manufacturer did not update driver for 6 yrs, so maybe
(if it causes BSOD) the best solution will be to buy new network adapter.
Thks for yr help
That is one of the problems with network drivers, when the manufacturers cut support for the drivers, and issues start to arise. You've essentially been hung out to dry, and the only viable alternative is to purchase a new card.
Hi Jared,
BIOS is ok.
BSOD happened again. Here is down bellow copy of Nirsoft BlueScreenView report. If the problem is in TP-LINK TF-3200 - I can not find W10 driver for it... Problematic files are ipfnd630.sys and ntoskrnl.exe. Any suggestion???
Dump File : 040916-18828-01.dmp
Crash Time : 09/04/2016 16:00:00
Bug Check String : DRIVER_IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x000000d1
Parameter 1 : 00000000`00000008
Parameter 2 : 00000000`00000002
Parameter 3 : 00000000`00000000
Parameter 4 : fffff801`508a5891
Caused By Driver : ipfnd630.sys
Caused By Address : ipfnd630.sys+5891
File Description : IC Plus IP100A 10/100 Fast Ethernet Adapter
Product Name : IC Plus IP100A 10/100 Fast Ethernet Adapter
Company : IC Plus Corp.
File Version : 6.30.13.419
Processor : x64
Crash Address : ntoskrnl.exe+142760
Stack Address 1 :
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\040916-18828-01.dmp
Processors Count : 8
Major Version : 15
Minor Version : 10586
Dump File Size : 272,236
Dump File Time : 09/04/2016 16:04:28
ntoskrnl is the Windows Kernel component, and obviously is not the cause.
The problem is your driver, if no update is available, you could try downloading an even older version, and installing that.
Although I think the best solution is a new network adapter.
