P pedzz23 New member Joined Jan 3, 2023 Posts 2 Jan 3, 2023 #1 please help to read my DUMP file for what is the cause when I'm playing A brief description of your problem (but you can also include the steps you tried) BSOD when playing path of exile System Manufacturer? Asus Laptop or Desktop? Desktop Exact model number (if laptop, check label on bottom) k30ad_m31ad_m51ad_m32ad OS ? (Windows 11, 10, 8.1, 8, 7, Vista) windows 10 x86 (32bit) or x64 (64bit)? 64bit (Only for Vista, Windows 7) Service pack? What was original installed OS on system? last 2weeks Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? microsoft website Age of system? (hardware) 2015 Age of OS installation? last 2 weeks Have you re-installed the OS? yes CPU: i7 4790s RAM (brand, EXACT model, what slots are you using?) samsung RAM Video Card: HIS RX 570 MotherBoard - (if NOT a laptop) ASUS h81m Power Supply - brand & wattage (if laptop, skip this one) silverstone 600w Is driver verifier enabled or disabled? disable What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth) win defender Are you using proxy, vpn, ipfilters or similar software? no Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software): noi Are you currently under/overclocking? Are there overclocking software installed on your system? no Attachments SysnativeFileCollectionApp.zip 1.9 MB · Views: 6
P pedzz23 New member Joined Jan 3, 2023 Posts 2 Jan 4, 2023 #2 SPECCY : http://speccy.piriform.com/results/E6zyNl6AUwCoSrFcGcxCTwp
