A brief description of your problem (but you can also include the steps you tried)
- Laptop or Desktop?
- OS ? (Windows 11, 10, 8.1, 8, 7, Vista)
- x86 (32bit) or x64 (64bit)?
- What was original installed OS on system?
- Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)?
- Age of system? (hardware)
- Age of OS installation?
- Have you re-installed the OS?
- CPU
- RAM (brand, EXACT model, what slots are you using?)
- Video Card
EVGA SuperNOVA G1+ 650 Watt
- Is driver verifier enabled or disabled?
- What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth)
- Are you using proxy, vpn, ipfilters or similar software?
- Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software)
- Are you currently under/overclocking? Are there overclocking software installed on your system?
Speccy:
http://speccy.piriform.com/results/6AxbirgZrHtM11USnM5SI2N
I'm pretty sure disabling hardware acceleration on Chrome will fix this issue since it's only ever happened on chrome, however as I said I'd like to get a second opinion from experts to make sure i'm not missing anything.
Thanks.
