britechguy Well-known member Joined Jun 2, 2016 Posts 772 Location Staunton, VA Jun 2, 2016 #1 Here are links to the logs: CBS.log DISM.log Thanks in advance for any assistance you can offer me in resolving this issue. Brian
Aura Sysnative Staff, Security Analyst Staff member Joined Mar 16, 2015 Posts 8,061 Jun 3, 2016 #2 Yo :) Here, follow the instructions below please. SFCFix - Fix Time WARNING! The following fix is specific to the user's system in this thread. No one else should follow the instructions below to apply that fix, as it could damage your system. If you need assistance with an issue, please start a new thread and someone will assist you shortly. Follow the instructions below to download and execute a SFCFix fix, and provide the log. Download SFCFix and move the executable on your Desktop; Download the attached SFCFix.zip and move the archive to your Desktop; Note: Make sure that the file is named SFCFix.zip, do not rename it. Save any work you have open, and close every programs; Drag the SFCFix.zip archive file over the SFCFix.exe executable and release it; SFCFix will launch, let it complete; Once done, a file will appear on your Desktop, called SFCFix.txt; Open the file, then copy and paste its content in your next reply; SFCFix.zip
britechguy Well-known member Joined Jun 2, 2016 Posts 772 Location Staunton, VA Jun 3, 2016 #3 Aura, Thanks again and here you go: SFCFix version 3.0.0.0 by niemiro. Start time: 2016-06-03 09:48:10.907 Microsoft Windows 10 Build 10586 - amd64 Using .zip script file at C:\Users\brite_000\Desktop\SFCFix.zip [0] PowerCopy:: Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_microsoft-windows-grouppolicy-gptext_31bf3856ad364e35_10.0.10586.0_none_67b6c95f81009211\gptext.dll Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_microsoft-windows-g..policy-admin-gpedit_31bf3856ad364e35_10.0.10586.0_none_fe99296a56e12a80\gpedit.dll Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_microsoft-windows-fde_31bf3856ad364e35_10.0.10586.0_none_d872f84b4da4f3d4\fde.dll Successfully took permissions for file or folder C:\WINDOWS\winsxs\x86_microsoft-windows-fdeploy_31bf3856ad364e35_10.0.10586.0_none_101c8f1242b816da\fdeploy.dll Successfully copied file C:\Users\brite_000\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-grouppolicy-gptext_31bf3856ad364e35_10.0.10586.0_none_67b6c95f81009211\gptext.dll to C:\WINDOWS\winsxs\x86_microsoft-windows-grouppolicy-gptext_31bf3856ad364e35_10.0.10586.0_none_67b6c95f81009211\gptext.dll. Successfully copied file C:\Users\brite_000\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-g..policy-admin-gpedit_31bf3856ad364e35_10.0.10586.0_none_fe99296a56e12a80\gpedit.dll to C:\WINDOWS\winsxs\x86_microsoft-windows-g..policy-admin-gpedit_31bf3856ad364e35_10.0.10586.0_none_fe99296a56e12a80\gpedit.dll. Successfully copied file C:\Users\brite_000\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-fde_31bf3856ad364e35_10.0.10586.0_none_d872f84b4da4f3d4\fde.dll to C:\WINDOWS\winsxs\x86_microsoft-windows-fde_31bf3856ad364e35_10.0.10586.0_none_d872f84b4da4f3d4\fde.dll. Successfully copied file C:\Users\brite_000\AppData\Local\niemiro\Archive\winsxs\x86_microsoft-windows-fdeploy_31bf3856ad364e35_10.0.10586.0_none_101c8f1242b816da\fdeploy.dll to C:\WINDOWS\winsxs\x86_microsoft-windows-fdeploy_31bf3856ad364e35_10.0.10586.0_none_101c8f1242b816da\fdeploy.dll. Successfully restored ownership for C:\WINDOWS\winsxs\x86_microsoft-windows-grouppolicy-gptext_31bf3856ad364e35_10.0.10586.0_none_67b6c95f81009211\gptext.dll Successfully restored permissions on C:\WINDOWS\winsxs\x86_microsoft-windows-grouppolicy-gptext_31bf3856ad364e35_10.0.10586.0_none_67b6c95f81009211\gptext.dll Successfully restored ownership for C:\WINDOWS\winsxs\x86_microsoft-windows-g..policy-admin-gpedit_31bf3856ad364e35_10.0.10586.0_none_fe99296a56e12a80\gpedit.dll Successfully restored permissions on C:\WINDOWS\winsxs\x86_microsoft-windows-g..policy-admin-gpedit_31bf3856ad364e35_10.0.10586.0_none_fe99296a56e12a80\gpedit.dll Successfully restored ownership for C:\WINDOWS\winsxs\x86_microsoft-windows-fde_31bf3856ad364e35_10.0.10586.0_none_d872f84b4da4f3d4\fde.dll Successfully restored permissions on C:\WINDOWS\winsxs\x86_microsoft-windows-fde_31bf3856ad364e35_10.0.10586.0_none_d872f84b4da4f3d4\fde.dll Successfully restored ownership for C:\WINDOWS\winsxs\x86_microsoft-windows-fdeploy_31bf3856ad364e35_10.0.10586.0_none_101c8f1242b816da\fdeploy.dll Successfully restored permissions on C:\WINDOWS\winsxs\x86_microsoft-windows-fdeploy_31bf3856ad364e35_10.0.10586.0_none_101c8f1242b816da\fdeploy.dll PowerCopy:: directive completed successfully. Successfully processed all directives. SFCFix version 3.0.0.0 by niemiro has completed. Currently storing 4 datablocks. Finish time: 2016-06-03 09:56:03.111 Script hash: QbblkULKvZjI6TZ+utUx/7t96Ym+N0spOmswp6Hsuks= ----------------------EOF-----------------------
Aura Sysnative Staff, Security Analyst Staff member Joined Mar 16, 2015 Posts 8,061 Jun 3, 2016 #4 Good! Now can you run SFC again and provide me the CBS.log after?
britechguy Well-known member Joined Jun 2, 2016 Posts 772 Location Staunton, VA Jun 3, 2016 #5 Certainly. I've got it running now and will post the log after it completes.
britechguy Well-known member Joined Jun 2, 2016 Posts 772 Location Staunton, VA Jun 3, 2016 #6 Aura, Final message from SFC indicated no integrity violations. Here's the CBS.log.
Aura Sysnative Staff, Security Analyst Staff member Joined Mar 16, 2015 Posts 8,061 Jun 3, 2016 #7 Indeed, SFC returned a clean CBS.log. Anything else? :)
britechguy Well-known member Joined Jun 2, 2016 Posts 772 Location Staunton, VA Jun 3, 2016 #8 Aura, Other than asking whether I should or need to run DISM, nothing but my profound thanks! Hold it, I lied just a bit, are you able to give a thumbnail sketch of the difference between what SFC and the DISM trio do or are intended to do? Like so many things Microsoft there often appear to be twenty mechanisms to do essentially or exactly the same thing.
Aura Sysnative Staff, Security Analyst Staff member Joined Mar 16, 2015 Posts 8,061 Jun 3, 2016 #9 I think I explained the differences at one point in a thread on BleepingComputer, and I might have explained it to you It was in the Windows 10 section, though I don't remember which thread. I'll see if I can find it.
britechguy Well-known member Joined Jun 2, 2016 Posts 772 Location Staunton, VA Jun 3, 2016 #10 If you can find it, that's fine, if not, that's fine too. There's been a lot of water flowing under, around, and sometimes a bit over my bridge the last couple of months, so certain "non-vital" information gets lost in that flood.
Aura Sysnative Staff, Security Analyst Staff member Joined Mar 16, 2015 Posts 8,061 Jun 3, 2016 #11 In my opinion, /ScanHealth and /CheckHealth aren't really needed on online Windows image (the current system). They are mostly destined to packaged Windows images that are ready for deployment. The /RestoreHealth switch is the only one that interests us. Repair a Windows Image https://support.microsoft.com/en-ca/kb/929833
britechguy Well-known member Joined Jun 2, 2016 Posts 772 Location Staunton, VA Jun 3, 2016 #12 I've often thought that anything but the /RestoreHealth option seemed to be irrelevant to an online system. Since I've done the "all three" routine a couple of times just because some have insisted it's necessary I've observed that the /RestoreHealth option appears to recapitulate the very action of the /ScanHealth option as its first order of business. Thanks again, very much, for your help. I really do appreciate it and the amount of time and effort that goes into it.
Aura Sysnative Staff, Security Analyst Staff member Joined Mar 16, 2015 Posts 8,061 Jun 3, 2016 #13 No problem Brian, you're welcome :)
