[SOLVED] Audio/Video Stutter (Audio makes a "glitchy" sound); Mouse Freezes During Stutter. High DPC Latency. FIX: using a cabled network (got Ethernet cable)
friedrice
Hey guys, I've had this problem since September of last year. The title basically describes my situation. I moved in with my girlfriend last year, and due to not having a truck, I moved my things slowly having my PC the first to go. My car has stiff springs so I thought this is a hardware issue, which it still might be, but the parts that I think would be affected (RAM and GPU) are both fine. At first it was just the audio and video having the stutters. I had my PC hooked up to the TV and thought it could have just been the TV, but the problem persisted when I had my desk and peripherals. I noticed the mouse also being affected when I was playing games and my mouse would not be in the position I expected it to be; it lagged behind.
For what I've done, I have done a clean install of Windows 10, new RAM, ran on Intel Graphics, updated all my drivers, updated my BIOS, but the problem is still here.
I've seen other posts on this forum about similar issues, but most are tailored for their specs. Any help will be greatly appreciated!
My Specs:
Intel i5-6600K
MSI GTX 1070
8GB Viper DDR4 Memory (Later swapped with Kingston HyperX 8GB)
MSI Z170A Gaming M7 Motherboard
120GB Kingston SSD
1TB Seagate Barracuda HDD
500GB Western Digital HDD
Razer NAGA Trinity Mouse
Corsair K70 Keyboard
I ran LatencyMon for almost an hour on idle.
CONCLUSION
LatencyMon has been analyzing your system for 0:52:51 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-086QR17
OS version: Windows 10 , 10.0, build: 18363 (x64)
Hardware: MS-7976, MSI, Z170A GAMING M7 (MS-7976)
CPU: GenuineIntel Intel(R) Core(TM) i5-6600K CPU @ 3.50GHz
Logical processors: 4
Processor groups: 1
RAM: 8153 MB total
CPU SPEED
Reported CPU speed: 3504 MHz
Highest measured interrupt to process latency (µs): 1758.50
Average measured interrupt to process latency (µs): 1.483550
Highest measured interrupt to DPC latency (µs): 1756.90
Average measured interrupt to DPC latency (µs): 0.529031
REPORTED ISRs
Highest ISR routine execution time (µs): 211.764840
Highest reported total ISR routine time (%): 0.014724
Total time spent in ISRs (%) 0.021728
ISR count (execution time <250 µs): 186863
REPORTED DPCs
Highest DPC routine execution time (µs): 86319.986301
Highest reported total DPC routine time (%): 0.700964
Driver with highest DPC total execution time: ndis.sys - Network Driver Interface Specification (NDIS), Microsoft Corporation
Total time spent in DPCs (%) 0.749775
DPC count (execution time <250 µs): 7751638
DPC count (execution time 500-999 µs): 20
DPC count (execution time 2000-3999 µs): 3
REPORTED HARD PAGEFAULTS
Total number of hard pagefaults 3300
Hard pagefault count of hardest hit process: 956
Number of processes hit: 27
PER CPU DATA
CPU 0 Interrupt cycle time (s): 113.955468
CPU 0 ISR highest execution time (µs): 211.764840
CPU 0 ISR total execution time (s): 2.756050
CPU 0 ISR count: 186859
CPU 0 DPC highest execution time (µs): 86319.986301
CPU 0 DPC total execution time (s): 95.049688
CPU 0 DPC count: 7729071
CPU 1 Interrupt cycle time (s): 4.404043
CPU 1 ISR highest execution time (µs): 12.676941
CPU 1 ISR total execution time (s): 0.000048
CPU 1 ISR count: 4
CPU 1 DPC highest execution time (µs): 84.738014
CPU 1 DPC total execution time (s): 0.030226
CPU 1 DPC count: 13381
CPU 2 Interrupt cycle time (s): 4.397069
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 51.611301
CPU 2 DPC total execution time (s): 0.010281
CPU 2 DPC count: 3855
CPU 3 Interrupt cycle time (s): 4.431714
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 95.049087
CPU 3 DPC total execution time (s): 0.015949
CPU 3 DPC count: 6415
A link here to your logs.
Hey, okay so I'm basically almost done and in the last final steps, but when I try to execute the "xperf -on DiagEasy" code, I get an error saying, "xperf: error: NT Kernel Logger: Cannot create a file when that file already exists. (0xb7)."
Any idea how I can fix this?
Stop It with the second command written in the guide, then re-try.
Okay, I tried it again and the error popped up again. I entered the second command and it left a trace.etl on my desktop. Is this the right file? Or should I retry since I got the error to begin with?
Edit: I tried right after and was prompted with "The trace you have just captured "C:\Users\USER\Desktop\trace.etl" may contain personally identifiable information, including but not necessarily limited to paths to files accessed, paths to registry accessed and process names. Exact information depends on the events that were logged. Please be aware of this when sharing out this trace with other people."
System Manufacturer?
N/A
Laptop or Desktop?
Desktop
Exact model number
N/A
OS?
Windows 10 Pro
x86 (32-bit) or x64 (64-bit)?
64-bit
Service Pack?
Feature update to Windows 10, version 1909
What was original installed OS on system?
Windows 10 Pro
Is the OS an OEM version or full retail version?
Full Retail Version
Age of system? (hardware)
Approx 3 years
Age of OS installation?
1 week
Have you re-installed the OS?
Yes
CPU
Intel(R) Core(TM) i5-6600K @ 3.50GHz
RAM
2x4GB Patriot Viper DDR4 RAM @ 3200MHz, on slots 2 and 4
Video Card
MSI GeForce GTX 1070 Gaming X 8GB
Motherboard
MSI Z170A Gaming M7
Power Supply - brand & wattage
Is driver verifier enabled or disabled?
Disabled
What security software are you using?
Windows Defender
Are you using proxy, vpn, ipfilters or similar software?
No
Are you using Disk Image tools?
No
Are you currently under/overclocking?
No
Are there overclocking software installed on your system?
No
Speccy System Information: Here
Before you follow all instructions, create a system restore point and a system image with your preferred tool (example: macrium reflect free... Prepare an USB rescue media, if you didn't already do it).
And backup all of your important data present in the drives.
Update the firmware for your kingston ssd SV300S37A/120G: the current version of it is 505ABBF1, the most updated version of the firmware is 60AABBF0 (on kingston.com).
Update the firmware for your seagate ST1000DM003-1CH162: the current version of it is CC47, the most updated version of the firmware is CC4H (on seagate.com).
There's a new version of nvidia drivers: 442.74.
Set dram speed to 2133 in your bios settings.
I've updated the firmware on my SSD, but I'm having trouble updating the Seagate one. I get an error when I run the .exe update and prompted me to try the .iso version. I can't burn it though cause I don't have a burner and I dont know how to put it on a usb drive. Also, on my bios, the dram speed is at 2176 and there's no 2133 option, just 2142 and 2040 after that
Update, so I tried booting my system with the Seagate 1TB HDD unplugged to see if the problem still occurs, and yes, it still does.
I've also set the dram frequency to 2142 down from 2176, and the problem still occurs.
Update: I think I've isolated what's causing the problem. I uninstalled all of the network adapter drivers in device manager and have been running LatencyMon for approx. 6 minutes without any issues. I've downloaded the drivers for my adapter, but I'm gonna leave LatencyMon running for a while. Will come back after I've installed drivers and restarted.
I ran LatencyMon for about 1 hour and 30 minutes with no latency. Installed my adapter drivers, restarted, and within 1 minute of running LatencyMon, I'm already experiencing the problem. I personally think this might be a hardware issue, but if anyone can tell me otherwise, I'd love to hear it.
Did you try to connect with the ethernet cable?
I got the Ethernet cable and ran LatencyMon for an hour with no issues whatsoever. My only concern now is if my network adapter has hardware or software issues, though leaning with the former. Thank you for all the help.
