Hi all, I'm having an issue with my audio.
Basically, it cuts out at random times, or shortly after starting up my pc.
I've had this issue last month, and the only solution I found online was uninstalling the Realtek drivers, deleting the files and restarting the pc. That seemed to fix it.
When my audio cuts out, I uninstall Realtek drivers and restart, but when I start my pc up I can hear the Win startup jingle in my headphones, a couple of "USB in/USB out" sounds, and then by the time I can start any program to test the audio, it's usually dead. Sometimes, instead, it works, and it keeps working for days, or hours, or minutes. It just seems random and I can't find a correlation.
I can still see in Sounds that my headphones are detected, and the green bars move like if audio was playing, but nothing more than that. I noticed that the sounds troubleshooter doesn't seem to work, and sometimes outright crashes the drivers, giving me the red x symbol next to the audio symbol on the task bar.
I seem to have found a workaround by connecting my headphones in the rear jack of my pc, so I'm guessing that there might be some issue with the front ports, but if that the case, why would it work normally for months/days and then stop?
I have a X570 Aorus Ultra and a Cooler Master Mastercase 5, if that helps.
Please, let me know if more data is required.
Thanks in advance for your help.
EDIT: audio went out anyways even with the jack connected on the rear panel
