CONCLUSION
LatencyMon has been analyzing your system for 0:23:30 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-VVTDG82
OS version: Windows 10, 10.0, version 2004, build: 19041 (x64)
Hardware: X570 AORUS MASTER, Gigabyte Technology Co., Ltd.
CPU: AuthenticAMD AMD Ryzen 9 3900XT 12-Core Processor
Logical processors: 24
Processor groups: 1
RAM: 32710 MB total
CPU SPEED
Reported CPU speed: 380 MHz
Highest measured interrupt to process latency (µs): 411.40
Average measured interrupt to process latency (µs): 5.473653
Highest measured interrupt to DPC latency (µs): 407.60
Average measured interrupt to DPC latency (µs): 1.634286
REPORTED ISRs
Highest ISR routine execution time (µs): 130.160
Highest reported total ISR routine time (%): 0.012927
Total time spent in ISRs (%) 0.013143
ISR count (execution time <250 µs): 265959
REPORTED DPCs
Highest DPC routine execution time (µs): 420.490
Driver with highest DPC routine execution time: ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Highest reported total DPC routine time (%): 0.007245
Total time spent in DPCs (%) 0.034931
DPC count (execution time <250 µs): 2634835
DPC count (execution time 500-10000 µs): 18
DPC count (execution time 1000-2000 µs): 0
REPORTED HARD PAGEFAULTS
Total number of hard pagefaults 22803
Hard pagefault count of hardest hit process: 16677
Number of processes hit: 46
PER CPU DATA
CPU 0 Interrupt cycle time (s): 19.973625
CPU 0 ISR highest execution time (µs): 2.450
CPU 0 ISR total execution time (s): 0.000017
CPU 0 ISR count: 17
CPU 0 DPC highest execution time (µs): 309.80
CPU 0 DPC total execution time (s): 3.200943
CPU 0 DPC count: 1696457
CPU 1 Interrupt cycle time (s): 11.211256
CPU 1 ISR highest execution time (µs): 1.260
CPU 1 ISR total execution time (s): 0.000004
CPU 1 ISR count: 4
CPU 1 DPC highest execution time (µs): 420.490
CPU 1 DPC total execution time (s): 0.084250
CPU 1 DPC count: 17146
CPU 2 Interrupt cycle time (s): 12.305956
CPU 2 ISR highest execution time (µs): 0.980
CPU 2 ISR total execution time (s): 0.000004
CPU 2 ISR count: 6
CPU 2 DPC highest execution time (µs): 350.190
CPU 2 DPC total execution time (s): 0.226268
CPU 2 DPC count: 37069
CPU 3 Interrupt cycle time (s): 11.456601
CPU 3 ISR highest execution time (µs): 2.040
CPU 3 ISR total execution time (s): 0.000061
CPU 3 ISR count: 76
CPU 3 DPC highest execution time (µs): 419.060
CPU 3 DPC total execution time (s): 0.098403
CPU 3 DPC count: 18447
CPU 4 Interrupt cycle time (s): 16.064192
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 81.050
CPU 4 DPC total execution time (s): 0.349855
CPU 4 DPC count: 62450
CPU 5 Interrupt cycle time (s): 10.190802
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 47.320
CPU 5 DPC total execution time (s): 0.027491
CPU 5 DPC count: 6263
CPU 6 Interrupt cycle time (s): 14.032311
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 80.240
CPU 6 DPC total execution time (s): 0.137746
CPU 6 DPC count: 29032
CPU 7 Interrupt cycle time (s): 9.755371
CPU 7 ISR highest execution time (µs): 1.750
CPU 7 ISR total execution time (s): 0.000007
CPU 7 ISR count: 5
CPU 7 DPC highest execution time (µs): 50.810
CPU 7 DPC total execution time (s): 0.019823
CPU 7 DPC count: 4605
CPU 8 Interrupt cycle time (s): 16.055318
CPU 8 ISR highest execution time (µs): 6.870
CPU 8 ISR total execution time (s): 0.007817
CPU 8 ISR count: 12061
CPU 8 DPC highest execution time (µs): 198.830
CPU 8 DPC total execution time (s): 0.731443
CPU 8 DPC count: 27676
CPU 9 Interrupt cycle time (s): 9.647516
CPU 9 ISR highest execution time (µs): 2.220
CPU 9 ISR total execution time (s): 0.000188
CPU 9 ISR count: 222
CPU 9 DPC highest execution time (µs): 179.970
CPU 9 DPC total execution time (s): 0.027909
CPU 9 DPC count: 3096
CPU 10 Interrupt cycle time (s): 12.227651
CPU 10 ISR highest execution time (µs): 5.670
CPU 10 ISR total execution time (s): 0.001367
CPU 10 ISR count: 1818
CPU 10 DPC highest execution time (µs): 190.360
CPU 10 DPC total execution time (s): 0.150010
CPU 10 DPC count: 11309
CPU 11 Interrupt cycle time (s): 10.511749
CPU 11 ISR highest execution time (µs): 3.810
CPU 11 ISR total execution time (s): 0.000341
CPU 11 ISR count: 353
CPU 11 DPC highest execution time (µs): 190.730
CPU 11 DPC total execution time (s): 0.044259
CPU 11 DPC count: 4049
CPU 12 Interrupt cycle time (s): 13.162436
CPU 12 ISR highest execution time (µs): 6.870
CPU 12 ISR total execution time (s): 0.008992
CPU 12 ISR count: 11131
CPU 12 DPC highest execution time (µs): 193.690
CPU 12 DPC total execution time (s): 0.304228
CPU 12 DPC count: 30142
CPU 13 Interrupt cycle time (s): 9.518694
CPU 13 ISR highest execution time (µs): 4.140
CPU 13 ISR total execution time (s): 0.001257
CPU 13 ISR count: 1362
CPU 13 DPC highest execution time (µs): 94.710
CPU 13 DPC total execution time (s): 0.050737
CPU 13 DPC count: 5762
CPU 14 Interrupt cycle time (s): 12.009728
CPU 14 ISR highest execution time (µs): 6.750
CPU 14 ISR total execution time (s): 0.004987
CPU 14 ISR count: 5720
CPU 14 DPC highest execution time (µs): 219.990
CPU 14 DPC total execution time (s): 0.176558
CPU 14 DPC count: 20522
CPU 15 Interrupt cycle time (s): 19.525137
CPU 15 ISR highest execution time (µs): 7.120
CPU 15 ISR total execution time (s): 0.047685
CPU 15 ISR count: 75831
CPU 15 DPC highest execution time (µs): 219.680
CPU 15 DPC total execution time (s): 1.514696
CPU 15 DPC count: 123561
CPU 16 Interrupt cycle time (s): 12.875333
CPU 16 ISR highest execution time (µs): 6.50
CPU 16 ISR total execution time (s): 0.000195
CPU 16 ISR count: 335
CPU 16 DPC highest execution time (µs): 59.050
CPU 16 DPC total execution time (s): 0.088446
CPU 16 DPC count: 21918
CPU 17 Interrupt cycle time (s): 8.231310
CPU 17 ISR highest execution time (µs): 0.790
CPU 17 ISR total execution time (s): 0.000005
CPU 17 ISR count: 7
CPU 17 DPC highest execution time (µs): 58.270
CPU 17 DPC total execution time (s): 0.021546
CPU 17 DPC count: 4107
CPU 18 Interrupt cycle time (s): 16.914579
CPU 18 ISR highest execution time (µs): 1.250
CPU 18 ISR total execution time (s): 0.000002
CPU 18 ISR count: 2
CPU 18 DPC highest execution time (µs): 130.060
CPU 18 DPC total execution time (s): 0.144309
CPU 18 DPC count: 18470
CPU 19 Interrupt cycle time (s): 10.906544
CPU 19 ISR highest execution time (µs): 4.240
CPU 19 ISR total execution time (s): 0.000154
CPU 19 ISR count: 260
CPU 19 DPC highest execution time (µs): 62.740
CPU 19 DPC total execution time (s): 0.024590
CPU 19 DPC count: 6072
CPU 20 Interrupt cycle time (s): 32.190548
CPU 20 ISR highest execution time (µs): 130.160
CPU 20 ISR total execution time (s): 3.562193
CPU 20 ISR count: 128245
CPU 20 DPC highest execution time (µs): 407.480
CPU 20 DPC total execution time (s): 3.481280
CPU 20 DPC count: 367781
CPU 21 Interrupt cycle time (s): 13.654488
CPU 21 ISR highest execution time (µs): 121.340
CPU 21 ISR total execution time (s): 0.204750
CPU 21 ISR count: 7006
CPU 21 DPC highest execution time (µs): 125.540
CPU 21 DPC total execution time (s): 0.376235
CPU 21 DPC count: 60664
CPU 22 Interrupt cycle time (s): 16.663912
CPU 22 ISR highest execution time (µs): 125.510
CPU 22 ISR total execution time (s): 0.301677
CPU 22 ISR count: 10188
CPU 22 DPC highest execution time (µs): 296.020
CPU 22 DPC total execution time (s): 0.309081
CPU 22 DPC count: 31791
CPU 23 Interrupt cycle time (s): 15.014388
CPU 23 ISR highest execution time (µs): 107.610
CPU 23 ISR total execution time (s): 0.306181
CPU 23 ISR count: 11310
CPU 23 DPC highest execution time (µs): 280.740
CPU 23 DPC total execution time (s): 0.231632
CPU 23 DPC count: 26464
done all this and still popping
