E EssDee Member Joined Oct 1, 2020 Posts 23 Mar 15, 2021 #1 Hi all, Since building my new PC over 6 months ago, I've had terrible audio problems on any form of media e.g. Twitch, Youtube, TeamSpeak, Discord etc. I've tried most guides online with setting playback rate, trying new cables, different drivers, editing regedit. If it fails, I just do a fresh install of windows. My audio set up is a Schiit Jotunheim 4490K DAC built in so my PC isn't processing the audio, so there must be something else but I am in the dark about this and require help as I am near breaking point. Any other questions and I would gladly answer them and pay even to solve this problem, hope to hear from someone soon, EssDee. OS ? (Windows 10, 8.1, 8, 7, Vista) - Windows 10 Home x86 (32bit) or x64 (64bit)? - x64 (Only for xp, vista, 7) Service pack? What was original installed OS on system? - Windows 10 Home Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? - Full Retail version to my knowledge Age of system? (hardware) - CPU, RAM, PSU, MOBO Less than 6 months - Rest is 3/4 years old Age of OS installation? - 1 Day old Have you re-installed the OS? - Yes, Multiple times. System Manufacturer? - Varies - PC built by myself. Laptop or Desktop? - Desktop Exact model number (if laptop, check label on bottom) MotherBoard - (if NOT a laptop) - X570 AORUS MASTER (rev. 1.0) CPU - Ryzen 3900XT RAM (brand, EXACT model, what slots are you using?) - G.Skill DIMM 32GB DDR4-3600 Kit Memory F4-3600C18D-32GTZN Trident Z - A2/B2 Video Card - NVidia GTX 1080 Power Supply - brand & wattage (if laptop, skip this one) - Be Quiet 1200W Straight Power 11 Is driver verifier enabled or disabled? - Enabled as far as I am aware What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth) - Windows Security Are you using proxy, vpn, ipfilters or similar software? - None Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) - None Are you currently under/overclocking? Are there overclocking software installed on your system? - Over clocking CPU & RAM - No difference when stock with issues Sysnative File Speccy link Trace File
