Audio Popping - Not sure what's causing it - please help :(
EssDee
System Manufacturer?
Laptop or Desktop? Desktop
OS ? (Windows 10, 8.1, 8, 7, Vista) Windows 10
x86 (32bit) or x64 (64bit)? 64bit
What was original installed OS on system? Windows 10 x64
Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? Retail
Age of system? (hardware) 5 months
Age of OS installation? fresh
Have you re-installed the OS? yes 2 times now
CPU - Ryzen 9 3900XT
RAM (brand, EXACT model, what slots are you using?) GSKILL Trident Z , F4-3600C18D-32GTZN, A2 B2
Video Card - GTX 1080
MotherBoard - (if NOT a laptop) Aorus X570 AORUS MASTER
Power Supply - brand & wattage (if laptop, skip this one) Be Quiet 1200W Straight Power 11 Platinum
Is driver verifier enabled or disabled? Default setting after a clean install.
What security software are you using? (Firewall, antivirus, antimalware, antispyware, and so forth) Windows AV
Are you using proxy, vpn, ipfilters or similar software? No
Are you using Disk Image tools? (like daemon tools, alcohol 52% or 120%, virtual CloneDrive, roxio software) No
Are you currently under/overclocking? Are there overclocking software installed on your system? Yes - OC on RAM 3600MHz - More stable and less audio popping than Stock.
I have audio popping happening during streams, movies in VLC, In discord and TeamSpeak and at the start of playing music, I have tried numerous steps to lower my latency and have been successful somewhat. I have an external AMP/DAC - Schiit Jotunheim. It may be a driver issue im just not sure, please help.
CONCLUSION
LatencyMon has been analyzing your system for 79:42:24 (h:mm:ss) on processors 0,1,2,3,4,5,6,7,8,9,10 and 11.
SYSTEM INFORMATION
Computer name: DESKTOP-VVTDG82
OS version: Windows 10, 10.0, version 2009, build: 19042 (x64)
Hardware: X570 AORUS MASTER, Gigabyte Technology Co., Ltd.
CPU: AuthenticAMD AMD Ryzen 9 3900XT 12-Core Processor
Logical processors: 24
Processor groups: 1
RAM: 32691 MB total
CPU SPEED
Reported CPU speed: 410 MHz
Highest measured interrupt to process latency (µs): 1181.854118
Average measured interrupt to process latency (µs): 20.138764
Highest measured interrupt to DPC latency (µs): 1174.730308
Average measured interrupt to DPC latency (µs): 10.483838
REPORTED ISRs
Highest ISR routine execution time (µs): 571.260
Highest reported total ISR routine time (%): 0.026521
Total time spent in ISRs (%) 0.026624
ISR count (execution time <250 µs): 77449963
ISR count (execution time 500-1000 µs): 128
REPORTED DPCs
Highest DPC routine execution time (µs): 1092.650
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 461.40 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.049915
Driver with highest DPC total execution time: rspLLL64.sys - Resplendence Latency Monitoring and Auxiliary Kernel Library, Resplendence Software Projects Sp.
Total time spent in DPCs (%) 0.089448
DPC count (execution time <250 µs): 742836060
DPC count (execution time 500-10000 µs): 5051
DPC count (execution time 1000-2000 µs): 4
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: firefox.exe
Total number of hard pagefaults 1102166
Hard pagefault count of hardest hit process: 253314
Number of processes hit: 167
PER CPU DATA
CPU 0 Interrupt cycle time (s): 15754.213266
CPU 0 ISR highest execution time (µs): 32.070
CPU 0 ISR total execution time (s): 0.800324
CPU 0 ISR count: 906579
CPU 0 DPC highest execution time (µs): 752.70
CPU 0 DPC total execution time (s): 4455.830513
CPU 0 DPC count: 556061043
CPU 1 Interrupt cycle time (s): 3978.263061
CPU 1 ISR highest execution time (µs): 23.720
CPU 1 ISR total execution time (s): 0.024841
CPU 1 ISR count: 24237
CPU 1 DPC highest execution time (µs): 466.320
CPU 1 DPC total execution time (s): 3.853008
CPU 1 DPC count: 800927
CPU 2 Interrupt cycle time (s): 3712.353539
CPU 2 ISR highest execution time (µs): 29.0
CPU 2 ISR total execution time (s): 0.181281
CPU 2 ISR count: 171860
CPU 2 DPC highest execution time (µs): 798.460
CPU 2 DPC total execution time (s): 109.691956
CPU 2 DPC count: 23043142
CPU 3 Interrupt cycle time (s): 4417.349409
CPU 3 ISR highest execution time (µs): 26.630
CPU 3 ISR total execution time (s): 0.551598
CPU 3 ISR count: 604207
CPU 3 DPC highest execution time (µs): 595.070
CPU 3 DPC total execution time (s): 37.450138
CPU 3 DPC count: 1403825
CPU 4 Interrupt cycle time (s): 7516.178732
CPU 4 ISR highest execution time (µs): 522.820
CPU 4 ISR total execution time (s): 689.858643
CPU 4 ISR count: 28698581
CPU 4 DPC highest execution time (µs): 1079.970
CPU 4 DPC total execution time (s): 575.323266
CPU 4 DPC count: 60783635
CPU 5 Interrupt cycle time (s): 4495.288701
CPU 5 ISR highest execution time (µs): 286.360
CPU 5 ISR total execution time (s): 24.361983
CPU 5 ISR count: 924099
CPU 5 DPC highest execution time (µs): 496.0
CPU 5 DPC total execution time (s): 23.153375
CPU 5 DPC count: 2609865
CPU 6 Interrupt cycle time (s): 5927.517923
CPU 6 ISR highest execution time (µs): 467.50
CPU 6 ISR total execution time (s): 106.726410
CPU 6 ISR count: 4066145
CPU 6 DPC highest execution time (µs): 861.660
CPU 6 DPC total execution time (s): 99.460721
CPU 6 DPC count: 10570761
CPU 7 Interrupt cycle time (s): 10132.721781
CPU 7 ISR highest execution time (µs): 571.260
CPU 7 ISR total execution time (s): 1010.811058
CPU 7 ISR count: 41876197
CPU 7 DPC highest execution time (µs): 1092.650
CPU 7 DPC total execution time (s): 825.175350
CPU 7 DPC count: 82756714
CPU 8 Interrupt cycle time (s): 4911.733786
CPU 8 ISR highest execution time (µs): 28.680
CPU 8 ISR total execution time (s): 0.133075
CPU 8 ISR count: 142826
CPU 8 DPC highest execution time (µs): 403.010
CPU 8 DPC total execution time (s): 15.781268
CPU 8 DPC count: 2902099
CPU 9 Interrupt cycle time (s): 4764.861138
CPU 9 ISR highest execution time (µs): 24.420
CPU 9 ISR total execution time (s): 0.003469
CPU 9 ISR count: 2850
CPU 9 DPC highest execution time (µs): 409.490
CPU 9 DPC total execution time (s): 2.464970
CPU 9 DPC count: 328728
CPU 10 Interrupt cycle time (s): 5000.757527
CPU 10 ISR highest execution time (µs): 25.390
CPU 10 ISR total execution time (s): 0.031459
CPU 10 ISR count: 22168
CPU 10 DPC highest execution time (µs): 405.710
CPU 10 DPC total execution time (s): 8.708084
CPU 10 DPC count: 1137778
CPU 11 Interrupt cycle time (s): 4879.025683
CPU 11 ISR highest execution time (µs): 26.550
CPU 11 ISR total execution time (s): 0.016843
CPU 11 ISR count: 10342
CPU 11 DPC highest execution time (µs): 406.110
CPU 11 DPC total execution time (s): 3.101683
CPU 11 DPC count: 442598
