[SOLVED] Audio keep stopping, sfc scan shows corrupted and unable to repair
Bheizm
Hi! I'm currently having an issue which the audio kept stopped working and the audio related websites such as YouTube started to crash. I tried restarting the Windows Audio service and it seems to work but after a while the audio stopped working again. I tried using sfc /scannow but it mentioned the corrupt file is unable to repair. I've tried running the SFCFix.exe and the results is shown:
SFCFix.txt:
Start time: 2016-05-24 10:17:12.305
Microsoft Windows 10 Build 10586 - amd64
WARNING: Performed DISM repair due to manifest damage on component "amd64_avast.vc140.crt_fcc99ee6193ebbca_14.0.23918.0_none_53c8344321b452ba". See CBS logfile for more details.
WARNING: Performed DISM repair due to manifest damage on component "x86_avast.vc140.crt_fcc99ee6193ebbca_14.0.23918.0_none_9b756b1a36307bc0". See CBS logfile for more details.
CBS & SFC total detected corruption count: 18
Finish time: 2016-05-24 10:35:07.355
Attached is the CBS.zip file.
Hi and welcome to Sysnative. The files that are referenced that have issues are related to your Antivirus Avast. Are you using the free version of the software? I assume you are using the most current version?
Please let me know. Thanks.
First thing we should do is uninstall Avast from Add/Remove programs. Once you have removed it please follow the instructions at the link below to run the Avast Uninstall Utility to clean up any remnants that are left over.
Avast Uninstall Utility | Download aswClear for Avast Removal
Once this is complete, then please do the following.
SFC Scan
1. Right-click on the Start
Avira Free 2015 is uninstalled and the steps are followed.
The cbs.zip requested is uploaded.
Thanks.
Thanks. Next step is I need your hives.
Retrieve Components/Software Hives
Note: The Software have has confidential and sensitive information in it so please send me a PM with a link to that particular hive so it's not in the public form.
  • This will bring you into the folder where the backup was made. You should see a Users folder and a Windows folder along with a couple other files. Double-click on the Windows folder to open it. Then open the System32 folder and then config folder. You should see around 6 files in here, two of which are named COMPONENTS and SOFTWARE.
  • Copy these two files to your Desktop. If the COMPONENTS file does not exist, please fetch it instead from C:\Windows\System32\config\COMPONENTS.
  • Now right click on these files on your desktop and select Send to > Compressed (zipped) folder.
  • Then please upload the zip file(s) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Dropbox or One Drive or SendSpace and then just provide the link in your reply.
Thank you. Please do the following.
Step#1 - SFCFix Script
Attached is the content of the file
Thanks. Please do the following again.
SFC Scan
Attached is the cbs.zip file.
Looks like the sfc scan doesn't have error now. Thanks.
Excellent. Now let's do the following.
