Audio Dropouts
Rockalot
after running his prescribed tests and looking at the results, a Pioneer DJ tech sent me here.
I bought Pioneer's latest DJ controller, DDJ FLX10, downloaded their drivers and updated the device's firmware.
Afterwards I couldn't connect that laptop to wifi and while playing out, gigging, the audio will drop out for a split second.
Seems to be more frequent at higher volumes.
Attached are the results of LatencyMon 7.20 which Pioneer had me run for them.
At Sunday's gig I used the same laptop but with my previous controller, a Pioneer DDJ-SX2 and had no dropout issues.
FYI, I use Serato DJ Pro 3.0 with Stems turned on.
Hi!
  • Enable the automatic system registry backup (to c:\windows\system32\config\RegBack).
  • Create a system restore point.
  • Create a system image and backup your important files.
  • Try to remove mcafee altogether (then enable/update/use windows defender).
  • If things won't change, try the following cleanup and checkup routine:
  • If things won't change, follow these instructions to provide some logs: Video STUTTERING, Audio CRACKS/POPS and dpc/isr LATENCY (posting instructions).
