Hi, i bought new laptop 3 months ago and until then i am fighting with audio dropouts when audio goes through usb audio interface Yamaha mw8cx. So, when audio is reproduced through laptop speaker everything is normal. I also tried different usb audio interface, steinberg ur22 and the dropouts still occurs. It happens no matter if audio is from youtube or my collection.Dropouts are not freaquent, they come every ten minutes(sometimes longer, sometimes shorter).Also intersting is that when i connect my usb audio interface and dont install appropriate drivers, windows has some automatic drivers and i dont have dropouts but then i cant use my usb audio interface in my DAW, cubase (music production)
Today i updated my OS to windows 10 pro, but problem is still here.
My laptop is HP 470 G3- intel core i5-6200U 2.3 GHz, 8 gb ram, windows 10 pro
So here is my latencymon check run for 3 hours. I hope we will find solution to my problems! Cheers!
(I made a thread in win7 part of forum but i will delete it because i has updated to win 10)
ONCLUSION
LatencyMon has been analyzing your system for 3:22:33 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-QSQEO1U
Hardware: HP ProBook 470 G3, HP, 8102
CPU: GenuineIntel Intel(R) Core(TM) i5-6200U CPU @ 2.30GHz
Logical processors: 4
Processor groups: 1
RAM: 8088 MB total
CPU SPEED
Reported CPU speed: 240 MHz
Highest measured interrupt to process latency (µs): 2164,054257
Average measured interrupt to process latency (µs): 2,732952
Highest measured interrupt to DPC latency (µs): 2152,107585
Average measured interrupt to DPC latency (µs): 0,913439
REPORTED ISRs
Highest ISR routine execution time (µs): 510,2550
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0,009841
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0,009841
ISR count (execution time <250 µs): 11645205
ISR count (execution time 500-999 µs): 2
REPORTED DPCs
Highest DPC routine execution time (µs): 1191,49250
Driver with highest DPC routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total DPC routine time (%): 0,198155
Total time spent in DPCs (%) 0,367611
DPC count (execution time <250 µs): 80007838
DPC count (execution time 500-999 µs): 22403
DPC count (execution time 1000-1999 µs): 10
REPORTED HARD PAGEFAULTS
Total number of hard pagefaults 270185
Hard pagefault count of hardest hit process: 74423
Highest hard pagefault resolution time (µs): 3755975,67750
Total time spent in hard pagefaults (%): 0,855562
Number of processes hit: 36
PER CPU DATA
CPU 0 Interrupt cycle time (s): 254,757304
CPU 0 ISR highest execution time (µs): 216,90750
CPU 0 ISR total execution time (s): 2,788953
CPU 0 ISR count: 6057936
CPU 0 DPC highest execution time (µs): 1191,49250
CPU 0 DPC total execution time (s): 157,731966
CPU 0 DPC count: 76842878
CPU 1 Interrupt cycle time (s): 36,347357
CPU 1 ISR highest execution time (µs): 510,2550
CPU 1 ISR total execution time (s): 1,995023
CPU 1 ISR count: 5587260
CPU 1 DPC highest execution time (µs): 579,67250
CPU 1 DPC total execution time (s): 3,284103
CPU 1 DPC count: 456561
CPU 2 Interrupt cycle time (s): 45,104559
CPU 2 ISR highest execution time (µs): 12,726667
CPU 2 ISR total execution time (s): 0,000046
CPU 2 ISR count: 11
CPU 2 DPC highest execution time (µs): 606,51250
CPU 2 DPC total execution time (s): 12,161529
CPU 2 DPC count: 1959775
CPU 3 Interrupt cycle time (s): 36,020161
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 1098,591667
CPU 3 DPC total execution time (s): 5,530220
CPU 3 DPC count: 771037
ONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 8088 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 2 ISR count: 11
CPU 3 ISR count: 0
