Audio cracks/stuttering
Scairtin
Hello,
I came across your website while trying to fix the audio cracks/stutters. I've recently upgraded my laptop with an extra 8GB RAM, an SSD, and got a fresh Windows 10 reinstall with it. The laptop works great, but there's one issue that is currently bothering me, audio cracks/stutters while playing video games. If I just listen to music, it seems to be fine.
I tried to:
1) Update audio driver;
2) Rollback audio driver;
3) Go to manufacturer's website and download the driver from there.
After multiple attempts the issue is unresolved, I would greatly appreciate if you could help me out. I've attached all the files according to the sticky thread. I've uploaded the ZIP to Google Drive since it didn't allow me to attach it here due to size.
Google Drive: Information.zip
Speccy: http://speccy.piriform.com/results/f3Ixi8x586sZzk6Ple8KQat
Thanks a lot!
I downloaded LatencyMon and ran it for more information:
CONCLUSION
LatencyMon has been analyzing your system for 0:38:39 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: CHRIS-LAPTOP
OS version: Windows 10 , 10.0, build: 19041 (x64)
Hardware: Aspire E5-574G, Acer, Zoro_SL
CPU: GenuineIntel Intel(R) Core(TM) i7-6500U CPU @ 2.50GHz
Logical processors: 4
Processor groups: 1
RAM: 16250 MB total
CPU SPEED
Reported CPU speed: 2592 MHz
Highest measured interrupt to process latency (µs): 3771.90
Average measured interrupt to process latency (µs): 7.471638
Highest measured interrupt to DPC latency (µs): 3267.70
Average measured interrupt to DPC latency (µs): 3.090857
REPORTED ISRs
Highest ISR routine execution time (µs): 311.834877
Highest reported total ISR routine time (%): 5.760150
Total time spent in ISRs (%) 5.854939
ISR count (execution time <250 µs): 293176809
ISR count (execution time 500-999 µs): 23
REPORTED DPCs
Highest DPC routine execution time (µs): 5695.945988
Highest reported total DPC routine time (%): 0.023043
Driver with highest DPC total execution time: storport.sys - Microsoft Storage Port Driver, Microsoft Corporation
Total time spent in DPCs (%) 0.124895
DPC count (execution time <250 µs): 2202341
DPC count (execution time 500-999 µs): 1307
DPC count (execution time 1000-1999 µs): 18
DPC count (execution time 2000-3999 µs): 7
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: microsoft.photos.exe
Total number of hard pagefaults 4140
Hard pagefault count of hardest hit process: 1525
Number of processes hit: 42
PER CPU DATA
CPU 0 Interrupt cycle time (s): 607.183047
CPU 0 ISR highest execution time (µs): 311.834877
CPU 0 ISR total execution time (s): 543.265554
CPU 0 ISR count: 293175705
CPU 0 DPC highest execution time (µs): 3241.431327
CPU 0 DPC total execution time (s): 7.968670
CPU 0 DPC count: 1610315
CPU 1 Interrupt cycle time (s): 15.506661
CPU 1 ISR highest execution time (µs): 127.777006
CPU 1 ISR total execution time (s): 0.000625
CPU 1 ISR count: 248
CPU 1 DPC highest execution time (µs): 1064.302469
CPU 1 DPC total execution time (s): 1.104755
CPU 1 DPC count: 98980
CPU 2 Interrupt cycle time (s): 20.845363
CPU 2 ISR highest execution time (µs): 89.807099
CPU 2 ISR total execution time (s): 0.001178
CPU 2 ISR count: 273
CPU 2 DPC highest execution time (µs): 3124.714506
CPU 2 DPC total execution time (s): 2.089273
CPU 2 DPC count: 430661
CPU 3 Interrupt cycle time (s): 5.611224
CPU 3 ISR highest execution time (µs): 133.845679
CPU 3 ISR total execution time (s): 0.008642
CPU 3 ISR count: 606
CPU 3 DPC highest execution time (µs): 5695.945988
CPU 3 DPC total execution time (s): 0.426245
CPU 3 DPC count: 63719
