Hi! I've got problems with audio crackling on my computer since it was build in April 2018. LatencyMon shows storport.sys is responsible for highest DPC routine. I've done a lot of searching about this but every solution I found didn't solve the crackling. As far as I remember I tried: changing SATA cable for SSD and HDD, changing power management plan (loading default, switching off Link Power Management), sfc /scannow, DISM /Online /Cleanup-image /Restorehealth. I've probably tried even more solutions but over a year ago I gave up on fixing this so I forgot.
OS:
Windows 10 20H2 x64
What was original installed OS on system:
Windows 10 x64
OS is from Microsoft Dreamspark, I've installed it myself
Age of system:
April 2018
Age of OS installation:
about 2 years ago
Have you re-installed the OS:
yes
Laptop or Desktop?
Desktop
MotherBoard:
ASRock AB350 Pro4, UEFI 5.80 (newer isn't recommended for Raven Ridge on this MOBO)
CPU:
AMD Ryzen 5 2400G
RAM:
GOODRAM IRX3000D464L16S/8G, slots -
A2, B2
Video Card:
MSI GTX 1070
Power Supply:
SeaSonic Focus Plus Gold 550W
Is
driver verifier enabled or disabled:
I think I disabled it
What security software are you using:
Malwarebytes scan once a month
Are you using proxy, vpn, ipfilters or similar software:
I'm not
Are you using Disk Image tools:
hardly ever Windows 10 built-in disk image tool
Are you currently under/overclocking:
XMP profile to run my RAM @3000MHz
Are there overclocking software installed on your system?
no
trace.etl
speccy
