Yes, I forgot, sorry. I have monitoring about 3 hours and you can see stats + images:
CONCLUSION
LatencyMon has been analyzing your system for 2:59:46 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: HELLER
OS version: Windows 10 , 10.0, build: 16299 (x64)
Hardware: ASUSTeK COMPUTER INC., PRIME Z270-A
CPU: GenuineIntel Intel(R) Core(TM) i7-7700K CPU @ 4.20GHz
Logical processors: 8
Processor groups: 1
RAM: 16322 MB total
CPU SPEED
Reported CPU speed: 420 MHz
Highest measured interrupt to process latency (µs): 36733,313617
Average measured interrupt to process latency (µs): 2,903022
Highest measured interrupt to DPC latency (µs): 36729,900284
Average measured interrupt to DPC latency (µs): 1,40840
REPORTED ISRs
Highest ISR routine execution time (µs): 367,931190
Highest reported total ISR routine time (%): 0,074406
Total time spent in ISRs (%) 0,130471
ISR count (execution time <250 µs): 5323536
ISR count (execution time 500-999 µs): 2449
REPORTED DPCs
Highest DPC routine execution time (µs): 36944,165714
Driver with highest DPC routine execution time: NDIS.SYS - Network Driver Interface Specification (NDIS), Microsoft Corporation
Highest reported total DPC routine time (%): 0,190938
Driver with highest DPC total execution time: ACPI.sys - ACPI Driver for NT, Microsoft Corporation
Total time spent in DPCs (%) 0,336634
DPC count (execution time <250 µs): 46021696
DPC count (execution time 500-999 µs): 256331
DPC count (execution time 1000-1999 µs): 18
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: none
Total number of hard pagefaults 0
Hard pagefault count of hardest hit process: 0
Highest hard pagefault resolution time (µs): 0,0
Total time spent in hard pagefaults (%): 0,0
Number of processes hit: 0
PER CPU DATA
CPU 0 Interrupt cycle time (s): 435,316758
CPU 0 ISR highest execution time (µs): 367,931190
CPU 0 ISR total execution time (s): 97,970934
CPU 0 ISR count: 4461515
CPU 0 DPC highest execution time (µs): 35320,331429
CPU 0 DPC total execution time (s): 266,761368
CPU 0 DPC count: 40754309
CPU 1 Interrupt cycle time (s): 63,283119
CPU 1 ISR highest execution time (µs): 338,170952
CPU 1 ISR total execution time (s): 12,427025
CPU 1 ISR count: 553120
CPU 1 DPC highest execution time (µs): 871,7950
CPU 1 DPC total execution time (s): 12,248427
CPU 1 DPC count: 1415972
CPU 2 Interrupt cycle time (s): 48,509402
CPU 2 ISR highest execution time (µs): 221,236429
CPU 2 ISR total execution time (s): 1,939719
CPU 2 ISR count: 274328
CPU 2 DPC highest execution time (µs): 36944,165714
CPU 2 DPC total execution time (s): 4,214933
CPU 2 DPC count: 1716931
CPU 3 Interrupt cycle time (s): 39,593462
CPU 3 ISR highest execution time (µs): 123,032857
CPU 3 ISR total execution time (s): 0,244839
CPU 3 ISR count: 37022
CPU 3 DPC highest execution time (µs): 141,930476
CPU 3 DPC total execution time (s): 0,957099
CPU 3 DPC count: 333491
CPU 4 Interrupt cycle time (s): 42,535632
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 172,728571
CPU 4 DPC total execution time (s): 1,967138
CPU 4 DPC count: 672658
CPU 5 Interrupt cycle time (s): 44,234854
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 141,674286
CPU 5 DPC total execution time (s): 1,051212
CPU 5 DPC count: 362358
CPU 6 Interrupt cycle time (s): 41,099975
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 143,166190
CPU 6 DPC total execution time (s): 2,247447
CPU 6 DPC count: 725632
CPU 7 Interrupt cycle time (s): 40,105557
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 145,485238
CPU 7 DPC total execution time (s): 1,032399
CPU 7 DPC count: 296702
IMAGES:
Imgur: The magic of the Internet
