Audio/CPU stuttering (latency issues)
Rick
Good evening!
I hope this is the correct forum section to ask for help regarding latency/cpu issues :).
And I am slightly retarded, I got forwarded from another site to here to ask for help... just noticed I posted in /Windows_10 instead of 8. oops, sorry!
____
Here is a video of what exactly happens to my sound and game when I start, for example, League of Legends,
(going from Champion Select, the client, to the Loading screen, the game itself).
Also look at how League of Legends.exe starts as 'not responding' whilst the game is stuttering and trying to load,
and so is the Twitch.tv stream (audio and visual) and my laggy cursor.
For some reason when I'm on Skype, or Discord, my microphone also stutters and my friends audio as well during the loading.
This does not happen on Teamspeak. YouTube audio (video does stutter) and Spotify web player audio do not stutter either.
____
What I have done so far:
  1. Updated BIOS to latest
  2. Updated GPU drivers to latest
  3. Installed all available Windows Updates
  4. Cleaned up /w CCleaner
  5. Ran a full virus scan /w Windows Defender (nothing was found, all clean)
  6. Disabled CPU throttling (performance setting in Control Panel)
____
Computer TypePC/Desktop
Operating SystemWindows 8.1 , 6.3, build: 9600 (x64)
CPUAMD FX(tm)-8350 Eight-Core Processor
MotherboardASUSTeK COMPUTER INC., SABERTOOTH 990FX R2.0
MemoryD3 16GB 1866-9 Vengeance bu K2 COR
Graphics CardAsus2GB D5 X GTX660-DC2 R
Sound Card- (standard one from mobo I assume)
Monitor(s) DisplaysIiya 27 L G2773HS-GB1 LED H+D S & BenQ 21,5 X2000W
Screen Resolution1920x1080@120hz & 1680x1050@60hz
KeyboardLogitech G710+ (Logitech software is up-to-date!)
HeadsetLogitech G35
Power SupplyCooler Master GX 550W
CaseAerocool Strike-X White Edt. wh ATX
CoolingCorsair H60 Water Cooling
SSD (boot)Kingston SSDNow V300, 120 GB SSD
HDDWestern Digital 1500GB 7200RPM SATA
Internet Speed120/150
BrowserGoogle Chrome & Firefox
Anti-VirusWindows Defender, Malwarebytes Anti-Malware
____
I ran the test for 12m35s with 1 Twitch.tv stream and this forum tab open and starting League of Legends (the game, not the client/launcher).
LatencyMon Main
____
LatencyMon Stats
_________________________________________________________________________________________________________CONCLUSION
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. Also one or more ISR routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for  0:12:35  (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name:                                        RICK
OS version:                                           Windows 8.1 , 6.3, build: 9600 (x64)
Hardware:                                             ASUSTeK COMPUTER INC., SABERTOOTH 990FX R2.0
CPU:                                                  AuthenticAMD AMD FX(tm)-8350 Eight-Core Processor
Logical processors:                                   8
Processor groups:                                     1
RAM:                                                  16282 MB total
CPU SPEED
Reported CPU speed:                                   4013 MHz
Measured CPU speed:                                   1 MHz (approx.)
MEASURED INTERRUPT TO DPC LATENCIES
The interrupt to DPC latency reflects the measured interval in which a DPC could execute in response to a hardware request from the moment the interrupt service routine started execution.
Highest measured interrupt to DPC latency (µs):       1279,299309
Average measured interrupt to DPC latency (µs):       6,981140
REPORTED ISRs
Highest ISR routine execution time (µs):              1315,280339
Driver with highest ISR routine execution time:       dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%):          0,266848
Driver with highest ISR total time:                   dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%)                          0,274068
ISR count (execution time <250 µs):                   606871
ISR count (execution time 250-500 µs):                0
ISR count (execution time 500-999 µs):                4
ISR count (execution time 1000-1999 µs):              4
ISR count (execution time 2000-3999 µs):              0
ISR count (execution time >=4000 µs):                 0
REPORTED DPCs
Highest DPC routine execution time (µs):              1335,429105
Driver with highest DPC routine execution time:       nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 376.33 , NVIDIA Corporation
Highest reported total DPC routine time (%):          0,091358
Driver with highest DPC total execution time:         dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%)                          0,303240
DPC count (execution time <250 µs):                   4935828
DPC count (execution time 250-500 µs):                0
DPC count (execution time 500-999 µs):                64
DPC count (execution time 1000-1999 µs):              6
DPC count (execution time 2000-3999 µs):              0
DPC count (execution time >=4000 µs):                 0
REPORTED HARD PAGEFAULTS
Process with highest pagefault count:                 chrome.exe
Total number of hard pagefaults                       3338
Hard pagefault count of hardest hit process:          1687
Highest hard pagefault resolution time (µs):          411601,642163
Total time spent in hard pagefaults (%):              0,030811
Number of processes hit:                              13
PER CPU DATA
CPU 0 Interrupt cycle time (s):                       33,836166
CPU 0 ISR highest execution time (µs):                143,872165
CPU 0 ISR total execution time (s):                   1,383220
CPU 0 ISR count:                                      52967
CPU 0 DPC highest execution time (µs):                1258,743833
CPU 0 DPC total execution time (s):                   5,969294
CPU 0 DPC count:                                      2983360
CPU 1 Interrupt cycle time (s):                       13,870533
CPU 1 ISR highest execution time (µs):                160,419636
CPU 1 ISR total execution time (s):                   1,402012
CPU 1 ISR count:                                      52870
CPU 1 DPC highest execution time (µs):                557,880140
CPU 1 DPC total execution time (s):                   1,096315
CPU 1 DPC count:                                      184208
CPU 2 Interrupt cycle time (s):                       12,675663
CPU 2 ISR highest execution time (µs):                176,177673
CPU 2 ISR total execution time (s):                   1,519578
CPU 2 ISR count:                                      55572
CPU 2 DPC highest execution time (µs):                1284,297284
CPU 2 DPC total execution time (s):                   1,438679
CPU 2 DPC count:                                      256216
CPU 3 Interrupt cycle time (s):                       13,313460
CPU 3 ISR highest execution time (µs):                150,691752
CPU 3 ISR total execution time (s):                   1,427395
CPU 3 ISR count:                                      53054
CPU 3 DPC highest execution time (µs):                778,888861
CPU 3 DPC total execution time (s):                   1,189003
CPU 3 DPC count:                                      190093
CPU 4 Interrupt cycle time (s):                       12,400727
CPU 4 ISR highest execution time (µs):                1227,761276
CPU 4 ISR total execution time (s):                   1,544911
CPU 4 ISR count:                                      55827
CPU 4 DPC highest execution time (µs):                699,147521
CPU 4 DPC total execution time (s):                   1,293171
CPU 4 DPC count:                                      207057
CPU 5 Interrupt cycle time (s):                       13,208979
CPU 5 ISR highest execution time (µs):                176,101919
CPU 5 ISR total execution time (s):                   1,568628
CPU 5 ISR count:                                      56799
CPU 5 DPC highest execution time (µs):                534,728881
CPU 5 DPC total execution time (s):                   1,294780
CPU 5 DPC count:                                      202816
CPU 6 Interrupt cycle time (s):                       13,408310
CPU 6 ISR highest execution time (µs):                1315,280339
CPU 6 ISR total execution time (s):                   2,250851
CPU 6 ISR count:                                      82516
CPU 6 DPC highest execution time (µs):                774,127585
CPU 6 DPC total execution time (s):                   1,869437
CPU 6 DPC count:                                      283133
CPU 7 Interrupt cycle time (s):                       20,402253
CPU 7 ISR highest execution time (µs):                1303,087964
CPU 7 ISR total execution time (s):                   5,457485
CPU 7 ISR count:                                      197274
CPU 7 DPC highest execution time (µs):                1335,429105
CPU 7 DPC total execution time (s):                   4,165389
CPU 7 DPC count:                                      629015
____
LatencyMon Processes
____
LatencyMon Drivers
Above 0 ISR count:
Above 0 DPC count:
____
Above 0 Highest execution (ms) & Total execution (ms)
____
LatencyMon CPUs
____
DxDiag
System Information
Time of this report: 12/28/2016, 23:18:22
       Machine name: RICK
   Operating System: Windows 8.1 Pro 64-bit (6.3, Build 9600) (9600.winblue_ltsb.160930-0600)
           Language: Dutch (Regional Setting: Dutch)
System Manufacturer: To be filled by O.E.M.
       System Model: To be filled by O.E.M.
               BIOS: BIOS Date: 04/08/14 10:15:06 Ver: 04.06.05
          Processor: AMD FX(tm)-8350 Eight-Core Processor            (8 CPUs), ~4.0GHz
             Memory: 16384MB RAM
Available OS Memory: 16282MB RAM
          Page File: 4852MB used, 27813MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.03.9600.17415 64bit Unicode
DxDiag Notes
      Display Tab 1: No problems found.
      Display Tab 2: No problems found.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
        Sound Tab 3: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: NVIDIA GeForce GTX 660
       Manufacturer: NVIDIA
          Chip type: GeForce GTX 660
           DAC type: Integrated RAMDAC
        Device Type: Full Device
         Device Key: Enum\PCI\VEN_10DE&DEV_11C0&SUBSYS_84231043&REV_A1
     Display Memory: 10097 MB
   Dedicated Memory: 1956 MB
      Shared Memory: 8141 MB
       Current Mode: 1920 x 1080 (32 bit) (120Hz)
       Monitor Name: Generic PnP Monitor
      Monitor Model: PLG2773
         Monitor Id: IVM6607
        Native Mode: 1920 x 1080(p) (60.000Hz)
        Output Type: DVI
        Driver Name: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver File Version: 21.21.0013.7633 (English)
     Driver Version: 21.21.13.7633
        DDI Version: 11
     Feature Levels: 11.0,10.1,10.0,9.3,9.2,9.1
       Driver Model: WDDM 1.3
Graphics Preemption: DMA
Compute Preemption: DMA
           Miracast: Not Supported
Hybrid Graphics GPU: Integrated
     Power P-states: Not Supported
  Driver Attributes: Final Retail
   Driver Date/Size: 12/12/2016 03:37:18, 17436808 bytes
        WHQL Logo'd: Yes
    WHQL Date Stamp:
  Device Identifier: {D7B71E3E-5280-11CF-226E-2EA41BC2D835}
          Vendor ID: 0x10DE
          Device ID: 0x11C0
          SubSys ID: 0x84231043
        Revision ID: 0x00A1
Driver Strong Name: oem101.inf:0f066de34ffc3860:Section026:21.21.13.7633:pci\ven_10de&dev_11c0
     Rank Of Driver: 00DA2001
        Video Accel: ModeMPEG2_A ModeMPEG2_C ModeVC1_C ModeWMV9_C
        DXVA2 Modes: DXVA2_ModeMPEG2_IDCT  DXVA2_ModeMPEG2_VLD  DXVA2_ModeVC1_VLD  DXVA2_ModeVC1_IDCT  DXVA2_ModeWMV9_IDCT  DXVA2_ModeH264_VLD_NoFGT
   Deinterlace Caps: {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {6CB69578-7617-4637-91E5-1C02DB810285}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {F9F19DA5-3B09-4B2F-9D89-C64753E3EAAB}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
       D3D9 Overlay: Supported
            DXVA-HD: Supported
       DDraw Status: Enabled
         D3D Status: Enabled
         AGP Status: Enabled
       Current Mode: 1680 x 1050 (32 bit) (59Hz)
       Monitor Name: BenQ X2000W (HDMI)
      Monitor Model: BenQ X2000W
         Monitor Id: BNQ7A06
        Native Mode: 1680 x 1050(p) (59.954Hz)
        Output Type: HDMI
        DDI Version: 11
        WHQL Logo'd: Yes
    WHQL Date Stamp:
          Vendor ID: 0x10DE
          Device ID: 0x11C0
        Revision ID: 0x00A1
            DXVA-HD: Supported
         D3D Status: Enabled
         AGP Status: Enabled
Sound Devices
            Description: Luidsprekers (Logitech G35 Gaming Headset)
Default Sound Playback: Yes
Default Voice Playback: Yes
            Hardware ID: USB\VID_046D&PID_0A15&REV_0303&MI_00
        Manufacturer ID: 65535
             Product ID: 65535
                   Type: WDM
            Driver Name: USBAUDIO.sys
         Driver Version: 6.03.9600.16490 (Dutch)
            WHQL Logo'd: Yes
          Date and Size: 3/18/2014 16:30:11, 121088 bytes
            Other Files:
        Driver Provider: Logitech
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
            Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
            Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_10438436&REV_1003
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: RTKVHD64.sys
         Driver Version: 6.00.0001.7240 (English)
            WHQL Logo'd: Yes
          Date and Size: 1/1/2000 01:00:00, 3956056 bytes
            Other Files:
        Driver Provider: Realtek Semiconductor Corp.
              Cap Flags: 0xF1F
              HW Memory: 0
            Description: Realtek Digital Output(Optical) (Realtek High Definition Audio)
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            WHQL Logo'd: Yes
            Other Files:
              Cap Flags: 0xF1F
              HW Memory: 0
Sound Capture Devices
            Description: Microfoon (Logitech G35 Gaming Headset)
  Default Sound Capture: Yes
  Default Voice Capture: Yes
              Cap Flags: 0x1
           Format Flags: 0xFFFFF
Video Capture Devices
Number of Devices: 2
           FriendlyName: Trust Webcam
           SymbolicLink: \\?\usb#vid_145f&pid_0167&mi_00#7&1ca58728&0&0000#{e5323777-f976-4f5b-9b55-b94699c46e44}\global
           Manufacturer: Microsoft
             HardwareID: USB\VID_145F&PID_0167&REV_0100&MI_00,USB\VID_145F&PID_0167&MI_00
             DriverDesc: USB-videoapparaat
         DriverProvider: Microsoft
          DriverVersion: 6.3.9600.17217
      DriverDateEnglish: 6/21/2006 00:00:00
    DriverDateLocalized: 21-6-2006 12:00:00 AM
                Service: usbvideo
                  Class: Image
          DevNodeStatus: 180200A[DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
            ContainerId: {51B401E0-668F-11E4-80AF-806E6F6E6963}
            ProblemCode: No Problem
  BusReportedDeviceDesc: Trust Webcam
                 Parent: USB\VID_145F&PID_0167\6&4d5f2e6&0&4
      DriverProblemDesc: n/a
           UpperFilters: n/a
           LowerFilters: n/a
                  Stack: \Driver\ksthunk,\Driver\usbvideo,\Driver\usbccgp
      ContainerCategory: Imaging
           FriendlyName: ManyCam Virtual Webcam
           SymbolicLink: \\?\root#media#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global
           Manufacturer: ManyCam LLC
             HardwareID: MANYCAM
             DriverDesc: ManyCam Virtual Webcam
         DriverProvider: ManyCam LLC
          DriverVersion: 3.1.0.0
      DriverDateEnglish: 6/28/2011 00:00:00
    DriverDateLocalized: 28-6-2011 12:00:00 AM
                Service: ManyCam
                  Class: MEDIA
          DevNodeStatus: 180200B[DN_ROOT_ENUMERATED|DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
            ContainerId: {00000000-0000-0000-FFFF-FFFFFFFFFFFF}
  BusReportedDeviceDesc: n/a
                 Parent: HTREE\ROOT\0
           UpperFilters: n/a
           LowerFilters: n/a
                  Stack: \Driver\ksthunk,\Driver\ManyCam,\Driver\PnpManager
      ContainerCategory: n/a
DirectInput Devices
      Device Name: Muis
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Toetsenbord
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
      Device Name: Logitech G710 Keyboard
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC24D
        FF Driver: n/a
      Device Name: Gaming Mouse G400
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC245
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: Wacom Tablet
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x056A, 0x00D4
        FF Driver: n/a
         Attached: 1
    Controller ID: 0x0
        FF Driver: n/a
      Device Name: Logitech G35 Headset
         Attached: 1
    Controller ID: 0x0
Vendor/Product ID: 0x046D, 0x0A15
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB-hoofdhub
| Vendor/Product ID: 0x1002, 0x4396
| Matching Device ID: USB\ROOT_HUB20
| Service: usbhub
| Driver: usbhub.sys, 10/11/2015 07:34:30, 462168 bytes
| Driver: usbd.sys, 10/11/2015 07:34:30, 27992 bytes
Gameport Devices
PS/2 Devices
+ HID-toetsenbordapparaat
| Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| Service: kbdhid
| Driver: kbdhid.sys, 11/4/2014 07:54:47, 32256 bytes
| Driver: kbdclass.sys, 11/4/2014 20:25:09, 59712 bytes
| Vendor/Product ID: 0x046D, 0xC232
| Service: kbdhid
| Service: kbdhid
+ Logitech Optical Gaming Mouse G400
| Matching Device ID: hid\vid_046d&pid_c245&mi_00
| Lower Filters: LGSHidFilt
| Service: mouhid
| Driver: LGSHidFilt.Sys, 5/30/2013 16:16:40, 64280 bytes
| Driver: mouhid.sys, 11/4/2014 07:54:47, 30208 bytes
| Driver: mouclass.sys, 11/4/2014 20:25:09, 51008 bytes
| Driver: LkmdfCoInst.dll, 5/31/2013 19:19:12, 1843480 bytes
+ HID-Compliant Mouse
| Matching Device ID: HID\VID_056A&PID_00D4&Col01
| Upper Filters: wacomrouterfilter
| Service: mouhid
| Driver: wacomrouterfilter.sys, 11/12/2013 01:16:03, 15160 bytes
| Driver: wdfcoinstaller01009.dll, 4/11/2012 23:34:23, 1721576 bytes
+ HID-muis
| Vendor/Product ID: 0x046D, 0xC231
| Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| Service: mouhid
Disk & DVD/CD-ROM Drives
      Drive: C:
Free Space: 12.0 GB
Total Space: 114.1 GB
File System: NTFS
      Model: KINGSTON  SV300S37A120G SATA Disk Device
      Drive: D:
Free Space: 0.0 GB
Total Space: 0.1 GB
File System: NTFS
      Model: WDC WD15 EARS-22MVWB0 SATA Disk Device
      Drive: E:
Free Space: 691.5 GB
Total Space: 1430.7 GB
File System: NTFS
      Drive: G:
      Model: TSSTcorp CDDVDW SH-S223C SATA CdRom Device
     Driver: c:\windows\system32\drivers\cdrom.sys, 6.03.9600.16384 (Dutch), 8/22/2013 09:46:35, 164352 bytes
System Devices
     Name: ATI I/O Communications Processor SMBus-controller
Device ID: PCI\VEN_1002&DEV_4385&SUBSYS_43851002&REV_42\3&267A616A&2&A0
   Driver: n/a
     Name: ATI I/O Communications Processor PCI Bus-controller
Device ID: PCI\VEN_1002&DEV_4384&SUBSYS_00000000&REV_40\3&267A616A&2&A4
   Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 6.03.9600.17238 (Dutch), 7/24/2014 16:28:35, 280384 bytes
     Name: PCI standard PCI-to-PCI bridge
Device ID: PCI\VEN_1002&DEV_43A1&SUBSYS_00001002&REV_00\3&267A616A&2&A9
     Name: PCI standard host CPU bridge
Device ID: PCI\VEN_1022&DEV_1602&SUBSYS_00000000&REV_00\3&267A616A&2&C2
   Driver: n/a
     Name: Asmedia 106x SATA Controller
Device ID: PCI\VEN_1B21&DEV_0612&SUBSYS_84B71043&REV_01\4&12B20C4C&0&0028
   Driver: C:\WINDOWS\system32\DRIVERS\asstor64.sys, 2.00.0008.0000 (English), 1/27/2014 16:30:36, 84816 bytes
Device ID: PCI\VEN_1002&DEV_5A1E&SUBSYS_5A141002&REV_00\3&267A616A&2&68
     Name: High Definition Audio-besturing
Device ID: PCI\VEN_1002&DEV_4383&SUBSYS_84361043&REV_40\3&267A616A&2&A2
   Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 6.03.9600.17238 (Dutch), 7/24/2014 12:45:39, 76800 bytes
     Name: ASMedia XHCI Controller
Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_84881043&REV_00\4&2057C65&0&00AA
   Driver: C:\WINDOWS\system32\DRIVERS\asmtxhci.sys, 1.16.0012.0000 (Dutch), 8/16/2013 14:37:12, 424192 bytes
     Name: AMD SATA Controller
Device ID: PCI\VEN_1002&DEV_4391&SUBSYS_84DD1043&REV_40\3&267A616A&2&88
   Driver: C:\WINDOWS\system32\DRIVERS\amd_sata.sys, 1.03.0001.0050 (Dutch), 9/16/2012 20:41:02, 80552 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\amd_xata.sys, 1.03.0001.0050 (Dutch), 9/16/2012 20:41:02, 26280 bytes
Device ID: PCI\VEN_1002&DEV_5A14&SUBSYS_5A141002&REV_02\3&267A616A&2&00
   Driver: n/a
Device ID: PCI\VEN_1022&DEV_1605&SUBSYS_00000000&REV_00\3&267A616A&2&C5
   Driver: n/a
Device ID: PCI\VEN_10DE&DEV_0E0B&SUBSYS_84231043&REV_A1\4&320ACFF0&0&0110
Device ID: PCI\VEN_1002&DEV_5A18&SUBSYS_5A141002&REV_00\3&267A616A&2&20
     Name: Standaard Enhanced PCI naar USB-hostcontroller
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_43961002&REV_00\3&267A616A&2&B2
   Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 6.03.9600.18191 (Dutch), 1/9/2016 02:38:04, 91992 bytes
   Driver: C:\WINDOWS\system32\drivers\usbport.sys, 6.03.9600.18088 (Dutch), 10/11/2015 07:34:30, 443224 bytes
   Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 6.03.9600.18088 (Dutch), 10/11/2015 07:34:30, 462168 bytes
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_43961002&REV_00\3&267A616A&2&9A
Device ID: PCI\VEN_1002&DEV_4396&SUBSYS_43961002&REV_00\3&267A616A&2&92
     Name: PCI standard ISA bridge
Device ID: PCI\VEN_1002&DEV_439D&SUBSYS_439D1002&REV_40\3&267A616A&2&A3
   Driver: C:\WINDOWS\system32\DRIVERS\msisadrv.sys, 6.03.9600.16384 (English), 8/22/2013 13:43:49, 17248 bytes
Device ID: PCI\VEN_1022&DEV_1600&SUBSYS_00000000&REV_00\3&267A616A&2&C0
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_5A1C&SUBSYS_5A141002&REV_00\3&267A616A&2&48
Device ID: PCI\VEN_1002&DEV_43A2&SUBSYS_00001002&REV_00\3&267A616A&2&AA
Device ID: PCI\VEN_1022&DEV_1603&SUBSYS_00000000&REV_00\3&267A616A&2&C3
   Driver: n/a
Device ID: PCI\VEN_1002&DEV_5A1F&SUBSYS_5A141002&REV_00\3&267A616A&2&58
Device ID: PCI\VEN_1002&DEV_5A16&SUBSYS_5A141002&REV_00\3&267A616A&2&10
Device ID: PCI\VEN_1B21&DEV_0612&SUBSYS_84B71043&REV_01\4&921044E&0&0020
Device ID: PCI\VEN_1002&DEV_5A19&SUBSYS_5A141002&REV_00\3&267A616A&2&28
Device ID: PCI\VEN_1002&DEV_43A0&SUBSYS_00001002&REV_00\3&267A616A&2&A8
Device ID: PCI\VEN_1022&DEV_1601&SUBSYS_00000000&REV_00\3&267A616A&2&C1
   Driver: n/a
     Name: NVIDIA GeForce GTX 660
Device ID: PCI\VEN_10DE&DEV_11C0&SUBSYS_84231043&REV_A1\4&320ACFF0&0&0010
   Driver: C:\Program Files\NVIDIA Corporation\Drs\dbInstaller.exe, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 456640 bytes
   Driver: C:\Program Files\NVIDIA Corporation\Drs\nvdrsdb.bin, 12/12/2016 03:37:18, 1361324 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_942cd454022d42e5\NvContainerSetup.exe, 1.00.0005.0000 (Dutch), 12/12/2016 03:37:18, 4098320 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_942cd454022d42e5\NvCplSetupInt.exe, 1.00.0005.0000 (Dutch), 12/12/2016 03:37:18, 97028168 bytes
   Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0207 (English), 12/12/2016 03:37:18, 20536 bytes
   Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvd3d9wrap.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 180672 bytes
   Driver: C:\Program Files (x86)\NVIDIA Corporation\coprocmanager\nvdxgiwrap.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 115056 bytes
   Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\detoured.dll, 2.01.0000.0207 (English), 12/12/2016 03:37:18, 18880 bytes
   Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvd3d9wrapx.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 210352 bytes
   Driver: C:\Program Files\NVIDIA Corporation\coprocmanager\nvdxgiwrapx.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 135632 bytes
   Driver: C:\Program Files\NVIDIA Corporation\license.txt, 12/12/2016 03:37:18, 26629 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\MCU.exe, 1.01.5204.20580 (Dutch), 12/12/2016 03:37:18, 849976 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvdebugdump.exe, 6.14.0013.7633 (English), 12/12/2016 03:37:18, 412728 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.1.pdf, 12/12/2016 03:37:18, 77216 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvidia-smi.exe, 8.17.0013.7633 (English), 12/12/2016 03:37:18, 450496 bytes
   Driver: C:\Program Files\NVIDIA Corporation\NVSMI\nvml.dll, 8.17.0013.7633 (English), 12/12/2016 03:37:18, 831032 bytes
   Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL.dll, 1.02.0011.0000 (English), 12/12/2016 03:37:18, 203320 bytes
   Driver: C:\Program Files\NVIDIA Corporation\OpenCL\OpenCL64.dll, 1.02.0011.0000 (English), 12/12/2016 03:37:18, 213952 bytes
   Driver: C:\WINDOWS\system32\DRIVERS\nvlddmkm.sys, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 14073400 bytes
   Driver: C:\WINDOWS\system32\NvFBC64.dll, 6.14.0013.7633 (English), 12/12/2016 03:37:18, 1036224 bytes
   Driver: C:\WINDOWS\system32\NvIFR64.dll, 6.14.0013.7633 (English), 12/12/2016 03:37:18, 944184 bytes
   Driver: C:\WINDOWS\system32\NvIFROpenGL.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 438208 bytes
   Driver: C:\WINDOWS\system32\nv-vk64.json, 12/12/2016 03:37:18, 669 bytes
   Driver: C:\WINDOWS\system32\nvEncodeAPI64.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 521096 bytes
   Driver: C:\WINDOWS\system32\nvapi64.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 3941536 bytes
   Driver: C:\WINDOWS\system32\nvcompiler.dll, 12/12/2016 03:37:18, 40125496 bytes
   Driver: C:\WINDOWS\system32\nvcuda.dll, 6.14.0013.7633 (English), 12/12/2016 03:37:18, 10345696 bytes
   Driver: C:\WINDOWS\system32\nvcuvid.dll, 7.17.0013.7633 (English), 12/12/2016 03:37:18, 3640376 bytes
   Driver: C:\WINDOWS\system32\nvd3dumx.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 17436808 bytes
   Driver: C:\WINDOWS\system32\nvfatbinaryLoader.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 683640 bytes
   Driver: C:\WINDOWS\system32\nvinfo.pb, 12/12/2016 03:37:18, 41334 bytes
   Driver: C:\WINDOWS\system32\nvinitx.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 170688 bytes
   Driver: C:\WINDOWS\system32\nvmcumd.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 894760 bytes
   Driver: C:\WINDOWS\system32\nvoglshim64.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 153184 bytes
   Driver: C:\WINDOWS\system32\nvoglv64.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 34703416 bytes
   Driver: C:\WINDOWS\system32\nvopencl.dll, 6.14.0013.7633 (English), 12/12/2016 03:37:18, 10795312 bytes
   Driver: C:\WINDOWS\system32\nvptxJitCompiler.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 10912744 bytes
   Driver: C:\WINDOWS\system32\nvumdshimx.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 491536 bytes
   Driver: C:\WINDOWS\system32\nvwgf2umx.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 19947472 bytes
   Driver: C:\WINDOWS\SysWow64\NvFBC.dll, 6.14.0013.7633 (English), 12/12/2016 03:37:18, 975416 bytes
   Driver: C:\WINDOWS\SysWow64\NvIFR.dll, 6.14.0013.7633 (English), 12/12/2016 03:37:18, 896056 bytes
   Driver: C:\WINDOWS\SysWow64\NvIFROpenGL.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 388544 bytes
   Driver: C:\WINDOWS\SysWow64\nv-vk32.json, 12/12/2016 03:37:18, 669 bytes
   Driver: C:\WINDOWS\SysWow64\nvEncodeAPI.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 435904 bytes
   Driver: C:\WINDOWS\SysWow64\nvapi.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 3479744 bytes
   Driver: C:\WINDOWS\SysWow64\nvcompiler.dll, 12/12/2016 03:37:18, 35222976 bytes
   Driver: C:\WINDOWS\SysWow64\nvcuda.dll, 6.14.0013.7633 (English), 12/12/2016 03:37:18, 8753832 bytes
   Driver: C:\WINDOWS\SysWow64\nvcuvid.dll, 7.17.0013.7633 (English), 12/12/2016 03:37:18, 3206080 bytes
   Driver: C:\WINDOWS\SysWow64\nvd3dum.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 14410472 bytes
   Driver: C:\WINDOWS\SysWow64\nvfatbinaryLoader.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 572888 bytes
   Driver: C:\WINDOWS\SysWow64\nvinit.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 148016 bytes
   Driver: C:\WINDOWS\SysWow64\nvoglshim32.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 131536 bytes
   Driver: C:\WINDOWS\SysWow64\nvoglv32.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 28138432 bytes
   Driver: C:\WINDOWS\SysWow64\nvopencl.dll, 6.14.0013.7633 (English), 12/12/2016 03:37:18, 9151216 bytes
   Driver: C:\WINDOWS\SysWow64\nvptxJitCompiler.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 8913328 bytes
   Driver: C:\WINDOWS\SysWow64\nvumdshim.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 407248 bytes
   Driver: C:\WINDOWS\SysWow64\nvwgf2um.dll, 21.21.0013.7633 (English), 12/12/2016 03:37:18, 17376896 bytes
   Driver: C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_942cd454022d42e5\VulkanRT-Installer.exe, 1.00.0026.0000 (English), 12/12/2016 03:37:18, 673400 bytes
   Driver: C:\WINDOWS\system32\nvdispco6437633.dll, 2.00.0046.0004 (English), 12/12/2016 03:37:18, 1953336 bytes
   Driver: C:\WINDOWS\system32\nvdispgenco6437633.dll, 2.00.0022.0002 (English), 12/12/2016 03:37:18, 1586744 bytes
Device ID: PCI\VEN_1002&DEV_5A1D&SUBSYS_5A141002&REV_00\3&267A616A&2&50
Device ID: PCI\VEN_1002&DEV_43A3&SUBSYS_00001002&REV_00\3&267A616A&2&AB
Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_84881043&REV_00\4&35BA9A29&0&0048
     Name: Standard OpenHCD USB Host-controller
Device ID: PCI\VEN_1002&DEV_4399&SUBSYS_43991002&REV_00\3&267A616A&2&A5
   Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 6.03.9600.18088 (English), 10/10/2015 19:41:14, 30208 bytes
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_43971002&REV_00\3&267A616A&2&B0
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_43971002&REV_00\3&267A616A&2&98
Device ID: PCI\VEN_1002&DEV_4397&SUBSYS_43971002&REV_00\3&267A616A&2&90
Device ID: PCI\VEN_1022&DEV_1604&SUBSYS_00000000&REV_00\3&267A616A&2&C4
   Driver: n/a
Device ID: PCI\VEN_1B21&DEV_1042&SUBSYS_84881043&REV_00\4&2830FDF9&0&00AB
     Name: Realtek PCIe GBE Family Controller
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_85051043&REV_09\4&B968463&0&00A9
   Driver: C:\WINDOWS\system32\DRIVERS\Rt630x64.sys, 8.36.0826.2014 (Dutch), 1/1/2000 01:00:00, 874712 bytes
   Driver: C:\WINDOWS\system32\RtNicProp64.dll, 1.02.0000.0006 (Dutch), 1/1/2000 01:00:00, 73800 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.03.9600.18154
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.03.9600.18154
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.03.9600.18154
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.03.9600.18154
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.03.9600.18154
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.03.9600.18154
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.03.9600.18154
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.03.9600.18154
MS ATC Screen Decoder 1,0x00600800,1,1,scdec.dll,15.00.4617.1000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.03.9600.18154
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.03.4534.0000
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.03.4534.0000
ffdshow Audio Decoder,0xff800001,1,1,ffdshow.ax,1.03.4534.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.06.9600.17415
Color Space Converter,0x00400001,1,1,quartz.dll,6.06.9600.18154
LAV Splitter,0x00400001,1,1,LAVSplitter.ax,0.68.0001.0031
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.9600.17415
AVI Splitter,0x00600000,1,1,quartz.dll,6.06.9600.18154
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.9600.18154
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.9600.17415
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,12.00.9600.17374
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.9600.17415
StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.9600.17415
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.9600.18154
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.9600.18154
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.9600.18154
VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.9600.17415
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.9600.17415
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.9600.17415
SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.9600.17415
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.9600.17415
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.9600.18154
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.9600.18154
DV Splitter,0x00600000,1,2,qdv.dll,6.06.9600.17415
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.9600.18154
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,12.00.9600.17415
ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.9600.18154
Video Renderer,0x00800001,1,0,quartz.dll,6.06.9600.18154
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.9600.17415
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,6.06.9600.18154
Video Renderer,0x00400000,1,0,quartz.dll,6.06.9600.18154
VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.9600.17415
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.9600.17415
Sony Wave Hammer Surround,0x00200000,1,1,mchammer_x64.dll,1.01.0000.2469
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.03.9600.17415
File writer,0x00200000,1,0,qcap.dll,6.06.9600.16384
VSFilter,0x00200000,2,1,vsfilter.dll,1.07.0010.0250
VSFilter (auto-loading version),0x00800002,2,1,vsfilter.dll,1.07.0010.0250
DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.9600.18154
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,12.00.9600.17415
WST Pager,0x00200000,1,1,WSTPager.ax,6.06.9600.17415
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.9600.17415
DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.9600.17415
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.03.4534.0000
LAV Splitter Source,0x00400001,0,1,LAVSplitter.ax,0.68.0001.0031
SampleGrabber,0x00200000,1,1,qedit.dll,6.06.9600.18152
Null Renderer,0x00200000,1,0,qedit.dll,6.06.9600.18152
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.9600.17415
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.03.9600.17415
StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.9600.17415
Smart Tee,0x00200000,1,2,qcap.dll,6.06.9600.16384
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.9600.18154
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.9600.18154
Wave Parser,0x00400000,1,1,quartz.dll,6.06.9600.18154
MIDI Parser,0x00400000,1,1,quartz.dll,6.06.9600.18154
Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.9600.18154
File stream renderer,0x00400000,1,1,quartz.dll,6.06.9600.18154
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.03.4534.0000
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,12.00.9600.18145
StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.9600.17415
AVI Mux,0x00200000,1,0,qcap.dll,6.06.9600.16384
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.9600.18154
File Source (Async.),0x00400000,0,1,quartz.dll,6.06.9600.18154
File Source (URL),0x00400000,0,1,quartz.dll,6.06.9600.18154
AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
LAV Audio Decoder,0x00800003,1,1,LAVAudio.ax,0.68.0001.0031
LAV Video Decoder,0xff800000,1,1,LAVVideo.ax,0.68.0001.0031
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.9600.16384
Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.03.9600.18154
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.9600.17415
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.9600.18154
Sony ExpressFX Chorus,0x00200000,1,1,sfxpfx2_x64.dll,1.01.0000.2469
Sony ExpressFX Delay,0x00200000,1,1,sfxpfx2_x64.dll,1.01.0000.2469
Sony ExpressFX Distortion,0x00200000,1,1,sfxpfx1_x64.dll,1.01.0000.2469
Sony ExpressFX Equalization,0x00200000,1,1,sfxpfx2_x64.dll,1.01.0000.2469
Sony ExpressFX Flange/Wah-Wah,0x00200000,1,1,sfxpfx1_x64.dll,1.01.0000.2469
Sony ExpressFX Amplitude Modulation,0x00200000,1,1,sfxpfx2_x64.dll,1.01.0000.2469
Sony ExpressFX Reverb,0x00200000,1,1,sfxpfx1_x64.dll,1.01.0000.2469
Sony ExpressFX Stutter,0x00200000,1,1,sfxpfx1_x64.dll,1.01.0000.2469
Sony ExpressFX Dynamics,0x00200000,1,1,sfxpfx3_x64.dll,1.01.0000.2469
Sony ExpressFX Graphic EQ,0x00200000,1,1,sfxpfx3_x64.dll,1.01.0000.2469
Sony ExpressFX Noise Gate,0x00200000,1,1,sfxpfx3_x64.dll,1.01.0000.2469
Sony ExpressFX Time Stretch,0x00200000,1,1,sfxpfx3_x64.dll,1.01.0000.2469
Sony ExpressFX Audio Restoration,0x00200000,1,1,xpvinyl_x64.dll,1.01.0000.2469
Sony Multi-Band Dynamics,0x00200000,1,1,sfppack2_x64.dll,1.01.0000.2469
Sony Track Compressor,0x00200000,1,1,sftrkfx1_x64.dll,1.01.0000.2469
Sony Dither,0x00200000,1,1,sftrkfx1_x64.dll,1.01.0000.2469
Sony Chorus,0x00200000,1,1,sfppack1_x64.dll,1.01.0000.2469
Sony Distortion,0x00200000,1,1,sfppack3_x64.dll,1.01.0000.2469
Sony Gapper/Snipper,0x00200000,1,1,sfppack3_x64.dll,1.01.0000.2469
Sony Simple Delay,0x00200000,1,1,sfppack1_x64.dll,1.01.0000.2469
Sony Reverb,0x00200000,1,1,sfppack1_x64.dll,1.01.0000.2469
Sony Multi-Tap Delay,0x00200000,1,1,sfppack1_x64.dll,1.01.0000.2469
Sony Track Noise Gate,0x00200000,1,1,sftrkfx1_x64.dll,1.01.0000.2469
Sony Graphic EQ,0x00200000,1,1,sfppack2_x64.dll,1.01.0000.2469
Sony Track EQ,0x00200000,1,1,sftrkfx1_x64.dll,1.01.0000.2469
Sony Smooth/Enhance,0x00200000,1,1,sfppack3_x64.dll,1.01.0000.2469
Sony Resonant Filter,0x00200000,1,1,sfresfilter_x64.dll,1.01.0000.2469
Sony Parametric EQ,0x00200000,1,1,sfppack2_x64.dll,1.01.0000.2469
Sony Time Stretch,0x00200000,1,1,sfppack1_x64.dll,1.01.0000.2469
Sony Noise Gate,0x00200000,1,1,sfppack2_x64.dll,1.01.0000.2469
Sony Paragraphic EQ,0x00200000,1,1,sfppack2_x64.dll,1.01.0000.2469
Sony Vibrato,0x00200000,1,1,sfppack3_x64.dll,1.01.0000.2469
Sony Pan,0x00200000,1,1,sffrgpnv_x64.dll,1.01.0000.2469
Sony Pitch Shift,0x00200000,1,1,sfppack1_x64.dll,1.01.0000.2469
Sony Volume,0x00200000,1,1,sffrgpnv_x64.dll,1.01.0000.2469
Sony Flange/Wah-wah,0x00200000,1,1,sfppack3_x64.dll,1.01.0000.2469
Sony Graphic Dynamics,0x00200000,1,1,sfppack2_x64.dll,1.01.0000.2469
Sony Amplitude Modulation,0x00200000,1,1,sfppack3_x64.dll,1.01.0000.2469
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink-conversieprogramma,0x00200000,1,1,ksproxy.ax,6.03.9600.18154
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.03.9600.18154
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.03.9600.18154
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.03.9600.18154
DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.9600.17415
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.03.4534.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.9600.18154
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.03.9600.18154
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.03.9600.18154
IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.9600.18154
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.9600.18154
GSM 6.10,0x00200000,1,1,quartz.dll,6.06.9600.18154
AC-3 ACM Extensible,0x00200000,1,1,quartz.dll,6.06.9600.18154
CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.9600.18154
CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.9600.18154
AC-3 ACM Codec,0x00200000,1,1,quartz.dll,6.06.9600.18154
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.9600.18154
Audio Capture Sources:
Microfoon (Logitech G35 Gaming Headset),0x00200000,0,0,qcap.dll,6.06.9600.16384
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.9600.18192
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.9600.18192
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.9600.18192
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.9600.18154
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.9600.18154
WDM Streaming Capture Devices:
Trust Webcam ,0x00200000,1,2,ksproxy.ax,6.03.9600.18154
,0x00000000,0,0,,
USB Audio Device,0x00200000,1,1,ksproxy.ax,6.03.9600.18154
ManyCam Wave,0x00200000,1,1,ksproxy.ax,6.03.9600.18154
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,6.03.9600.18154
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,6.03.9600.18154
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,6.03.9600.18154
ManyCam Virtual Webcam,0x00200000,1,2,ksproxy.ax,6.03.9600.18154
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,6.03.9600.18154
Realtek HDA SPDIF Optical Out,0x00200000,1,1,ksproxy.ax,6.03.9600.18154
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,6.03.9600.18154
,0x00000000,0,0,,
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.9600.17415
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.9600.17415
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.9600.17415
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.9600.17415
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.9600.17415
Video Capture Sources:
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.9600.17415
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.9600.17415
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.9600.18192
Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.9600.18192
PTFilter,0x00200000,0,0,EncDec.dll,6.06.9600.18192
XDS Codec,0x00200000,0,0,EncDec.dll,6.06.9600.18192
WDM Streaming Communication Transforms:
Audio Renderers:
Luidsprekers (Logitech G35 Gaming Headset),0x00200000,1,0,quartz.dll,6.06.9600.18154
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.9600.18154
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.9600.18154
DirectSound: Realtek Digital Output (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.9600.18154
DirectSound: Realtek Digital Output(Optical) (Realtek High Definition Audio),0x00200000,1,0,quartz.dll,6.06.9600.18154
DirectSound: Luidsprekers (Logitech G35 Gaming Headset),0x00200000,1,0,quartz.dll,6.06.9600.18154
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
{31435648-0000-0010-8000-00AA00389B71}, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
{43564548-0000-0010-8000-00AA00389B71}, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
MEDIASUBTYPE_WVC1, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_h264, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
{78766964-0000-0010-8000-00AA00389B71}, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
{64697678-0000-0010-8000-00AA00389B71}, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
MEDIASUBTYPE_RAW_AAC1, LAV Audio Decoder, {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_AVC1, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
MEDIASUBTYPE_mp4s, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{5634504D-0000-0010-8000-00AA00389B71}, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
{7634706D-0000-0010-8000-00AA00389B71}, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
MEDIASUBTYPE_H264, Enhanced Video Renderer, {FA10746C-9B63-4B6C-BC49-FC300EA5F256}
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
  <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
  Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 12.00.9600.17374
  DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 6.03.9600.17415
  Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 6.03.9600.18154
  Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 12.00.9600.17374
  WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 6.03.9600.18154
  WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 6.03.9600.18154
  MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 6.03.9600.17415
  Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 6.03.9600.18154
  MS ATC Screen Decoder 1, {F1931D8E-51D3-496F-BE8A-3D08AEE9C9DB}, 0x1, scdec.dll, 15.00.4617.1000
  Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 6.03.9600.18154
Video Encoders:
  H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 6.03.9600.17415
  WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 6.03.9600.18154
  WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 6.03.9600.18154
  Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 12.00.9600.17415
Video Effects:
  Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 6.03.9600.18154
  Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 6.03.9600.18154
  VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 6.03.9600.17415
  Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 6.03.9600.18154
  Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 6.03.9600.18154
Video Processor:
  Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 12.00.9600.17415
Audio Decoders:
  Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, MSAudDecMFT.dll, 6.03.9600.17415
  WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 6.03.9600.18154
  Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 6.03.9600.17415
  A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 12.00.9600.18154
  GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 12.00.9600.18154
  WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 6.03.9600.18154
  Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 6.03.9600.17415
  WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 6.03.9600.18154
  G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 12.00.9600.18154
  IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 12.00.9600.18154
  MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 6.03.9600.18154
  ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 12.00.9600.18154
Audio Encoders:
  MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 12.00.9600.18154
  WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 6.03.9600.18154
  Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 12.00.9600.17415
  WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 6.03.9600.18154
  Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 6.03.9600.17415
  Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 6.03.9600.17415
Audio Effects:
  AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 6.03.9600.18154
  Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 6.03.9600.18154
Multiplexers:
  Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 12.00.9600.17415
Others:
  Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 12.00.9600.17374
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 0
EnableEncoders = 1
EnableVideoProcessors = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Foutbucket 127748590320, type 5
Naam van gebeurtenis: AVSubmit
Antwoord: Niet beschikbaar
Id van CAB-bestand: 0
Handtekening van probleem:
P1: Windows Defender (77BDAF73-B396-481F-9042-AD358843EC24)
P2: 1.1.13303.0
P3: 1.233.3468.0
P4: 1.233.3468.0
P5: 0000000000000000,756de4100ec2605af8ccb2c0008f4522310b20be
P6:
P7:
P8:
P9:
P10:
Toegevoegde bestanden:
\\?\C:\ProgramData\Microsoft\Windows Defender\LocalCopy\{BCB036BF-EB2F-0347-B6CD-B5040621096C}-rs2client.exe
C:\Windows\ServiceProfiles\NetworkService\AppData\Local\Temp\MPSampleSubmit\client_manifest.txt
Deze bestanden zijn mogelijk hier beschikbaar:
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\NonCritical_Windows Defender_fa7b7583d57c558fb85d1fc9ca1b62718666_00000000_10c63338
Analysesymbool:
Opnieuw zoeken naar oplossing: 0
Rapport-id: a7ad9ab0-cd43-11e6-8430-60a44c6284c2
Rapportstatus: 0
Opgedeelde bucket: 6ae2f8291d1080ac0b613205128de932
+++ WER1 +++:
Foutbucket 129233942911, type 5
Naam van gebeurtenis: RADAR_PRE_LEAK_64
P1: LCore.exe
P2: 8.88.30.0
P3: 6.3.9600.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
C:\Users\R ick\AppData\Local\Temp\RDR6BC8.tmp\empty.txt
Analysesymbool:
Rapport-id: ca9a6d66-cd28-11e6-842e-60a44c6284c2
Rapportstatus: 0
Opgedeelde bucket: d95d50862486cb38a4fc1e567fee0b44
+++ WER2 +++:
Foutbucket 126579914418, type 5
Naam van gebeurtenis: WindowsUpdateFailure3
P1: 7.9.9600.18340
P2: 80070643
P3: 230B82D1-3ABD-471A-A4F9-23F97FB857D9
P4: Install
P5: 101
P6: 0
P7: 13ec
P8: AutomaticUpdatesWuApp
P9: {7971F918-A847-4430-9279-4A52D1EFE18D}
P10: 0
C:\Windows\WindowsUpdate.log
C:\Windows\SoftwareDistribution\ReportingEvents.log
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\NonCritical_7.9.9600.18340_9f797ac566d16e216246175147d6adfc1d4787a_00000000_118028d4
Analysesymbool:
Rapport-id: b1ff144a-cd1c-11e6-842e-60a44c6284c2
Rapportstatus: 0
Opgedeelde bucket: 4efe91cb1df7f4104080bba593cf91f1
+++ WER3 +++:
Foutbucket , type 0
P1: 7.9.9600.18340
P2: 80070643
P4: Install
P5: 101
P6: 0
P7: 13ec
P10: 0
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\NonCritical_7.9.9600.18340_9f797ac566d16e216246175147d6adfc1d4787a_00000000_cab_1a2425f5
Analysesymbool:
Rapportstatus: 4
Opgedeelde bucket:
+++ WER4 +++:
Foutbucket , type 0
P1: 7.9.9600.18340
P2: 80070643
P4: Install
P5: 101
P6: 0
P7: 13ec
P10: 0
Analysesymbool:
Rapportstatus: 262144
Opgedeelde bucket:
+++ WER5 +++:
Foutbucket 127747731995, type 5
P2: 1.1.13303.0
P3: 1.233.3413.0
P4: 1.233.3413.0
P5: 0000000000000000,4ddaa03ff123d1ce00e2e3690aa3a774b8e490bb
P6:
P7:
P8:
P9:
P10:
\\?\C:\ProgramData\Microsoft\Windows Defender\LocalCopy\{F63133BB-5EC9-7FD7-25B3-12B4C163EE8F}-nvlddmkm.sys
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\NonCritical_Windows Defender_f346c957b90392f1260233fc7712b576b239c3_00000000_138be517
Analysesymbool:
Rapport-id: 0b4d85f0-cd1c-11e6-842e-60a44c6284c2
Rapportstatus: 0
Opgedeelde bucket: 5460f75c71b3aed2c4ef47bb698d20cb
+++ WER6 +++:
No Data
+++ WER7 +++:
No Data
+++ WER8 +++:
No Data
+++ WER9 +++:
No Data
____
If I missed any kind of information, please let me know and I will it add it as soon as possible!
Thanks and Regards,
Rick
Hi Rick. :)
Did you try to clean directly your hardware? (to remove dust, apply new thermal compound, etc... Obviously the pc should be unplugged from the mains :-p)
Dxdiag says BIOS Date: 04/08/14 10:15:06 Ver: 04.06.05; it seems BIOS version 2501.
On your MB website there's BIOS version 2901 (2016/08/05).
There's also Realtek Audio Driver V6.0.1.7525.
I'm not sure about realtek drivers listed in the dxdiag report: it's written 6.06.9600.18154.
Did you install any codec pack?
Or are you using some driver updater programs?
Hi Rick. :)
I clean and de-dust every 3 months, thermal paste has been half a year I think.
Last time I updated my BIOS I did it through the ASUS AI Suite II 2.04.01 software and it was unable to find any new updates after 04/08/2014.
I manually updated my BIOS with the .cap file from the ASUS website to version 2901 from 2016/08/05.
I do not know anything about the Realtek Audio Driver? I use the Logitech Gaming software for my Logitech G35.
I once installed the K-Lite Mega Codec Pack 12.3.5, not sure if I even still use it as I only use VLC to watch movies/series if I can't stream them.
After BIOS update my CPU fan is going crazy (very loud, never been like this before) even when the system is idle and processor is running <5%.
Also my boot order/menu was completely mixed up together with my BIOS settings.
The stuttering from the main post still occurs.
___
Even after changing settings around in the BIOS the fan noise is still the same and my boot order refuses to save.
That update did more bad than good :-/
What procedure did you use to update the BIOS?
I may suggest you to re-try it: I'd use all the methods but the Windows one.
The asus ez flash 2 would be my preferred, if I had an asus MB.
Or maybe the USB bios flashback port and button method (see chapter 2.2).
Before and after BIOS updating, in the exit menu select load optimized defaults and save the settings.
Let's see if this works in a better way... :bored2:
Did it through the ASUS AI Suite II software just like last time I updated it.
However, this time I manually selected the .cap file instead of the online update (which does not find a new update for some reason).
I fixed the boot order and put the fans on silent, ran multiple stress tests to ensure the temperature is still fine while the fans run on low rpm.
Also I removed the AI Suite software, read somewhere that it might cause errors and it is not that useful anyway as it is outdated, but it did not solve the issue from the main post.
As you mentioned before there is a new version of the Realtek Audio Driver, so I installed that one.
Well the boot order was only fine for that one boot I guess... it's back to where it was: loud fans & manually having to go in boot menu in order to start the PC.
Whenever I enter the advanced BIOS settings now and load optimized defaults and try to save it it just completely freezes the computer.
I already reset the BIOS/CMOS but it refuses to save ANY settings I change, even the default ones I am unable to load and save.
Wow. Then try to reinstall the previous bios.
Done that, BIOS works perfectly fine again now.
Can make changes again, and it will boot Windows from SSD right away.
___
Is there anything, a program or something, I can see all my listed drivers and if there are any updates available for them?
Device manager is a joke and does not work, any third party software that allows me to check?
As I have been asking around other people, since a ton of people have had this issue, I have done the following - sadly without any results so far:
- BIOS back to v2501
- Installed the new available Windows Updates
- Updated all outdated drivers that I could find through IOBit Driver Booster (someone said that worked for him)
Sadly after updating those drivers I came across multiple Blue Screens, one that occurred while updating one of the USB 3.0 drivers... it rebooted and all my USB 3.0 ports did not work anymore.
I managed did fix that. However, the Blue Screens still occur every now and then(?). The dumpfile is below, 100% it is because one of the driver updates but I can not read these dump files out myself.
Updated DxDiag: /u/Saint_Rick - Pastebin.com
Bluescreen dump: http://puu.sh/t8h9m.dmp
Bluescreenview results: http://i.imgur.com/4RL93Ha.png
Imo (and not only mine), driver updaters are software to avoid.
I installed over the months/years:
  • DriverEasy (still installed)
  • DriverDR (still installed)
  • IOBIT DriverBooster 4 free (still installed)
  • DriverMagician
  • DriverMax
  • DUMO free (portable) (still present)
  • driverdetails-pcvark DriverUpdater 1.0.0.16358
  • intel driver updater
Even the intel driver updater failed to check and install the correct drivers, but if I must believe in one/two driver updaters, I'd believe in intel driver updater and in windows device manager.
You can see the comparison (and other opinions) on giveawayoftheday.com.
