Audio Clicks, Pops and Dropouts
edwardinchains
Hi - I'm new here so I'm not sure if I'm posting in the right place - Hello by the way!
Anyway, Im working on a computer for a friend of mine - he uses it solely for audio production, live recording, mastering, playback etc. - he uses ableton, cubase, kontakt etc - lately he has been getting audio clipping, clicks, pops and dropouts - I have tried a few things I have found online but cant seem to figure what is causing the issue - below is a copy of the LatencyMon report - scsiport.sys is showing a high execution rate, however i can resolve this by disabling the JMicron in the bios and removing the dvd drive - any help would be greatly appreciated - pulling my hair out here
CONCLUSION
LatencyMon has been analyzing your system for 0:07:58 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: MICK-PC
Hardware: OEM, http://www.abit.com.tw/, AB9 QuadGT (Intel965+ICH8R)
CPU: GenuineIntel Intel(R) Core(TM)2 Quad CPU @ 2.40GHz
Logical processors: 4
Processor groups: 1
RAM: 8190 MB total
CPU SPEED
Reported CPU speed: 2448.0 MHz
Measured CPU speed: 2253.0 MHz (approx.)
Highest measured interrupt to process latency (µs): 2132.479784
Average measured interrupt to process latency (µs): 5.715297
Highest measured interrupt to DPC latency (µs): 1329.767209
Average measured interrupt to DPC latency (µs): 2.373725
REPORTED ISRs
Highest ISR routine execution time (µs): 99.367647
Highest reported total ISR routine time (%): 0.021610
Total time spent in ISRs (%) 0.041467
ISR count (execution time <250 µs): 158691
REPORTED DPCs
Highest DPC routine execution time (µs): 1493.702206
Driver with highest DPC routine execution time: ataport.SYS - ATAPI Driver Extension, Microsoft Corporation
Highest reported total DPC routine time (%): 0.039375
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 309.08 , NVIDIA Corporation
Total time spent in DPCs (%) 0.127080
DPC count (execution time <250 µs): 311786
DPC count (execution time 500-999 µs): 413
DPC count (execution time 1000-1999 µs): 66
REPORTED HARD PAGEFAULTS
Total number of hard pagefaults 3458
Hard pagefault count of hardest hit process: 1368
Highest hard pagefault resolution time (µs): 500011.128676
Total time spent in hard pagefaults (%): 0.198139
Number of processes hit: 14
PER CPU DATA
CPU 0 Interrupt cycle time (s): 3.614672
CPU 0 ISR highest execution time (µs): 99.367647
CPU 0 ISR total execution time (s): 0.774237
CPU 0 ISR count: 155203
CPU 0 DPC highest execution time (µs): 1294.323529
CPU 0 DPC total execution time (s): 2.341696
CPU 0 DPC count: 308111
CPU 1 Interrupt cycle time (s): 0.387328
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 37.886029
CPU 1 DPC total execution time (s): 0.001583
CPU 1 DPC count: 196
CPU 2 Interrupt cycle time (s): 0.307506
CPU 2 ISR highest execution time (µs): 59.926471
CPU 2 ISR total execution time (s): 0.018818
CPU 2 ISR count: 3488
CPU 2 DPC highest execution time (µs): 1493.702206
CPU 2 DPC total execution time (s): 0.085446
CPU 2 DPC count: 3753
CPU 3 Interrupt cycle time (s): 0.344707
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 102.011029
CPU 3 DPC total execution time (s): 0.001687
CPU 3 DPC count: 205
