Jose2610
- Aug 15, 2021
- 1
My audio and monitor is usually stuttering. I have been running latencymon for a hour and this is the result that I got.
CONCLUSION
LatencyMon has been analyzing your system for 1:00:17 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DESKTOP-N81TNJ2
OS version: Windows 10, 10.0, version 2009, build: 19043 (x64)
Hardware: MS-7B86, Micro-Star International Co., Ltd
CPU: AuthenticAMD AMD Ryzen 5 3600X 6-Core Processor
Logical processors: 12
Processor groups: 1
RAM: 16333 MB total
CPU SPEED
Reported CPU speed: 380 MHz
Highest measured interrupt to process latency (µs): 101442,222405
Average measured interrupt to process latency (µs): 31,875714
Highest measured interrupt to DPC latency (µs): 101433,701769
Average measured interrupt to DPC latency (µs): 18,588812
REPORTED ISRs
Highest ISR routine execution time (µs): 1100,570
Highest reported total ISR routine time (%): 0,126521
Total time spent in ISRs (%) 0,134752
ISR count (execution time <250 µs): 1561811
ISR count (execution time 500-1000 µs): 2088
ISR count (execution time 1000-2000 µs): 3
REPORTED DPCs
Highest DPC routine execution time (µs): 101795,350
Driver with highest DPC routine execution time: storport.sys - Microsoft Storage Port Driver, Microsoft Corporation
Highest reported total DPC routine time (%): 0,080386
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 471.68 , NVIDIA Corporation
Total time spent in DPCs (%) 0,215187
DPC count (execution time <250 µs): 4994484
DPC count (execution time 500-10000 µs): 24708
DPC count (execution time 1000-2000 µs): 66
DPC count (execution time >=4000 µs): 2
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: avastui.exe
Total number of hard pagefaults 59712
Hard pagefault count of hardest hit process: 32964
Number of processes hit: 221
PER CPU DATA
CPU 0 Interrupt cycle time (s): 364,394509
CPU 0 ISR highest execution time (µs): 1100,570
CPU 0 ISR total execution time (s): 57,262481
CPU 0 ISR count: 1416160
CPU 0 DPC highest execution time (µs): 101795,350
CPU 0 DPC total execution time (s): 88,359329
CPU 0 DPC count: 4333231
CPU 1 Interrupt cycle time (s): 91,690611
CPU 1 ISR highest execution time (µs): 741,770
CPU 1 ISR total execution time (s): 1,212275
CPU 1 ISR count: 114470
CPU 1 DPC highest execution time (µs): 901,680
CPU 1 DPC total execution time (s): 2,668871
CPU 1 DPC count: 356397
CPU 2 Interrupt cycle time (s): 36,092861
CPU 2 ISR highest execution time (µs): 101,220
CPU 2 ISR total execution time (s): 0,007032
CPU 2 ISR count: 439
CPU 2 DPC highest execution time (µs): 487,530
CPU 2 DPC total execution time (s): 0,208515
CPU 2 DPC count: 33635
CPU 3 Interrupt cycle time (s): 34,110462
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 532,130
CPU 3 DPC total execution time (s): 0,117609
CPU 3 DPC count: 20667
CPU 4 Interrupt cycle time (s): 28,858071
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 711,430
CPU 4 DPC total execution time (s): 0,197229
CPU 4 DPC count: 34182
CPU 5 Interrupt cycle time (s): 28,360839
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 625,020
CPU 5 DPC total execution time (s): 0,098896
CPU 5 DPC count: 17782
CPU 6 Interrupt cycle time (s): 45,081810
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 556,050
CPU 6 DPC total execution time (s): 0,509611
CPU 6 DPC count: 85244
CPU 7 Interrupt cycle time (s): 44,838237
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 681,210
CPU 7 DPC total execution time (s): 0,136153
CPU 7 DPC count: 25146
CPU 8 Interrupt cycle time (s): 71,319267
CPU 8 ISR highest execution time (µs): 342,820
CPU 8 ISR total execution time (s): 0,013565
CPU 8 ISR count: 23476
CPU 8 DPC highest execution time (µs): 719,340
CPU 8 DPC total execution time (s): 0,465715
CPU 8 DPC count: 49137
CPU 9 Interrupt cycle time (s): 38,528242
CPU 9 ISR highest execution time (µs): 6,40
CPU 9 ISR total execution time (s): 0,001538
CPU 9 ISR count: 2648
CPU 9 DPC highest execution time (µs): 727,80
CPU 9 DPC total execution time (s): 0,183788
CPU 9 DPC count: 17795
CPU 10 Interrupt cycle time (s): 65,127741
CPU 10 ISR highest execution time (µs): 12,280
CPU 10 ISR total execution time (s): 0,002516
CPU 10 ISR count: 4268
CPU 10 DPC highest execution time (µs): 808,20
CPU 10 DPC total execution time (s): 0,218232
CPU 10 DPC count: 20775
CPU 11 Interrupt cycle time (s): 62,838213
CPU 11 ISR highest execution time (µs): 9,160
CPU 11 ISR total execution time (s): 0,001658
CPU 11 ISR count: 2441
CPU 11 DPC highest execution time (µs): 553,490
CPU 11 DPC total execution time (s): 0,256591
CPU 11 DPC count: 25269
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 16333 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 3 ISR count: 0
CPU 4 ISR count: 0
CPU 5 ISR count: 0
CPU 6 ISR count: 0
CPU 7 ISR count: 0
