ARNING: Failed to check store directories with return code 1 and error code ERROR_FIL
isach25
Start time: 2016-07-29 08:45:47.756
WARNING: Components hive failed size test and may be corrupt.
SURT total detected corruption count: 1
Finish time: 2016-07-29 08:48:57.188
Hi isach25,
Do you still need assistance with this issue?
Yes, I still have this issues as i havent found any solution. i really appreciate your help. thank you.
Alright, I'll need to take a look at your COMPONENTS Hive.
Retrieving the COMPONENTS Hive
Follow the instructions below to retrieve your COMPONENTS Hive and send me it.
  • Open your Windows Explorer, and navigate to the C:\Windows\System32\Config folder;
  • In this folder, find the COMPONENTS file (there's no extension), and copy it to your Desktop;
    Note: If you receive an error message saying that the COMPONENTS file is in use, restart your computer and try again. If the error message persist, let me know.
  • Right-click on it, and select Send to... and choose Compressed (zipped) folder;
  • Upload the file on Dropbox, Google Drive or OneDrive and post the download URL for it here;
