Hello,
I have problem with Windows 10 on my laptop Samsung NP-300-V5A. To be honest it seems newer updates made system much worse than vanilla state system. Here I am not sure, perhaps I am wrong.
To fight with DPC latencies, ISR I have done so far:
So far without success. Thus I gave up and request for help. I have made short logs via XPERF and sent you a link to check. I also attach screens of programs.
If it helps I may add that when I was compressing xperf files into RAR, I got a lot slowdowns. I also tried to shut down devices in "devices menager" but without any result.
Xperf logs:
CPU - Dropbox - CPU.rar
Kernel - Dropbox - kernel.rar
Here is LatencyMon log:
CONCLUSION
LatencyMon has been analyzing your system for 0:10:16 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: BURGSCH
Hardware: 300V3A/300V4A/300V5A/200A4B/200A5B, SAMSUNG ELECTRONICS CO., LTD.
CPU: GenuineIntel Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
Logical processors: 2
Processor groups: 1
RAM: 8105 MB total
CPU SPEED
Reported CPU speed: 2295 MHz
Measured CPU speed: 30 MHz (approx.)
Highest measured interrupt to process latency (µs): 2555,143182
Average measured interrupt to process latency (µs): 7,364289
Highest measured interrupt to DPC latency (µs): 2546,832069
Average measured interrupt to DPC latency (µs): 2,979351
REPORTED ISRs
Highest ISR routine execution time (µs): 60,526362
Highest reported total ISR routine time (%): 0,029264
Total time spent in ISRs (%) 0,037902
ISR count (execution time <250 µs): 77735
REPORTED DPCs
Highest DPC routine execution time (µs): 5936,134641
Driver with highest DPC routine execution time: ndis.sys - Specyfikacja NDIS (Network Driver Interface Specification), Microsoft Corporation
Highest reported total DPC routine time (%): 0,414939
Driver with highest DPC total execution time: ndis.sys - Specyfikacja NDIS (Network Driver Interface Specification), Microsoft Corporation
Total time spent in DPCs (%) 1,503565
DPC count (execution time <250 µs): 3521580
DPC count (execution time 500-999 µs): 5515
DPC count (execution time 1000-1999 µs): 225
DPC count (execution time 2000-3999 µs): 41
REPORTED HARD PAGEFAULTS
Process with highest pagefault count: waterfox.exe
Total number of hard pagefaults 265
Hard pagefault count of hardest hit process: 67
Highest hard pagefault resolution time (µs): 107565,152070
Total time spent in hard pagefaults (%): 0,087167
Number of processes hit: 7
PER CPU DATA
CPU 0 Interrupt cycle time (s): 37,691997
CPU 0 ISR highest execution time (µs): 60,526362
CPU 0 ISR total execution time (s): 0,466857
CPU 0 ISR count: 77688
CPU 0 DPC highest execution time (µs): 5936,134641
CPU 0 DPC total execution time (s): 17,637236
CPU 0 DPC count: 3449385
CPU 1 Interrupt cycle time (s): 4,373052
CPU 1 ISR highest execution time (µs): 23,015251
CPU 1 ISR total execution time (s): 0,000344
CPU 1 ISR count: 47
CPU 1 DPC highest execution time (µs): 657,834858
CPU 1 DPC total execution time (s): 0,896542
CPU 1 DPC count: 77977
Drivers tab:
DPC Latency Checker:
Thank you.
- updated my laptop's BIOS
- disabled HyperThreading and power save in BIOS
- used "disabledynamictick yes"
- used "HPET" command in the system
Xperf logs:
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 8105 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 1 ISR count: 47
Drivers tab:
Thank you.
