G galbicka Member Joined Aug 20, 2015 Posts 23 Aug 20, 2015 #1 I have a very similar issue to this post and need help resolving it: https://www.sysnative.com/forums/windows-update/13481-800b0100-error-need-help-please.html
G galbicka Member Joined Aug 20, 2015 Posts 23 Aug 20, 2015 #2 I ran SFCFix and got this log: SFCFix version 2.4.5.0 by niemiro. Start time: 2015-08-20 10:15:20.141 Microsoft Windows 7 Service Pack 1 - amd64 Not using a script file. AutoAnalysis:: SUMMARY: Some corruptions could not be fixed automatically. Seek advice from helper or sysnative.com. CBS & SFC total detected corruption count: 0 CBS & SFC total unimportant corruption count: 0 CBS & SFC total fixed corruption count: 0 SURT total detected corruption count: 52 SURT total unimportant corruption count: 0 SURT total fixed corruption count: 0 AutoAnalysis:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.5.0 by niemiro has completed. Currently storing 0 datablocks. Finish time: 2015-08-20 10:20:09.708 ----------------------EOF-----------------------
G galbicka Member Joined Aug 20, 2015 Posts 23 Aug 20, 2015 #3 CBS logfiles are shortly to follow - will not upload here - must be too large
LogBot Well-known member Joined Jul 26, 2013 Posts 1,608 Aug 20, 2015 #4 Logfile submission from galbicka Logfile submission from galbicka. The logfiles are available at: https://www.sysnative.com/niemiro/fileDistribution/2015-08/6450.zip
G galbicka Member Joined Aug 20, 2015 Posts 23 Aug 20, 2015 #5 SFCFix version 2.4.5.0 by niemiro. Start time: 2015-08-20 10:44:39.954 Microsoft Windows 7 Service Pack 1 - amd64 Using .txt script file at C:\Users\denglish.VICTORY\Downloads\SFCFixScript.txt [1] Collect:: directive completed successfully. Successfully processed all directives. SFCFix version 2.4.5.0 by niemiro has completed. Currently storing 0 datablocks. Finish time: 2015-08-20 10:46:32.355 ----------------------EOF-----------------------
G galbicka Member Joined Aug 20, 2015 Posts 23 Aug 20, 2015 #6 I have tried all of the steps at this link to fix the problem myself: https://support.microsoft.com/en-us/kb/956702
G galbicka Member Joined Aug 20, 2015 Posts 23 Aug 20, 2015 #7 These same 13 updates fail to install repeatedly and checksur.log only identifies KB3023607 as a problem: KB3031432 KB3004375 KB2984972 KB3067505 KB2992611 KB3045999 KB3011780 KB3057154 KB3068708 KB3033929 KB3003743 KB3000483 KB3061518
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,131 Location United States Aug 24, 2015 #8 Hi and welcome to Sysnative. Sorry for the delay. Please do the following. I know you have done this already but it's important for me to get fresh logs. Thank you. Step#1 - System Update Readiness Tool (SUR) 1. Download and run the following file. 2. When it asks you if you wish to install, please answer yes. Note: It could take 15 minutes or more to run. Please don't cancel. 3. You will get an Installation Complete screen when it's done running. 4. Please attach the log from the following location. C:\Windows\Logs\CBS\CheckSUR.log Please Note:: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the link.
G galbicka Member Joined Aug 20, 2015 Posts 23 Aug 25, 2015 #9 New log available at this link: https://www.dropbox.com/s/sxhvvnnskb0jy22/CheckSUR.log?dl=0
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,131 Location United States Aug 25, 2015 #10 Please do the following. Step#1 - Fix Corrupt/Missing Files Warning: this fix is specific to the user in this thread. No one else should follow these instructions as it may cause more harm than good. If you are after assistance, please start a thread of your own. Please download the attached file, Packs.zip and save this to your Desktop. Right-click on the file and select Extract All... Tick the box labelled Show extracted files when complete then click Extract A window will open showing two folders, Manifests and Packages Open the Manifests folder and copy the files into the following folder (if there are any files). If the Manifests folder doesn't exist within Winsxs you will need to create it. C:\Windows\Temp\CheckSur\Winsxs\Manifests Open the Packages folder and copy the files into the following folder (if there are any files). If the Packages folder doesn't exist within Servicing you will need to create it. C:\Windows\Temp\CheckSur\Servicing\Packages Run the System Update Readiness Tool (SURT) again. When the SURT finishes installing, zip up and attach the following log file: C:\Windows\Logs\CBS\CheckSUR.log Attachments Packs.zip 302.7 KB · Views: 4
G galbicka Member Joined Aug 20, 2015 Posts 23 Aug 25, 2015 #11 new log attachedView attachment CheckSUR.zip
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,131 Location United States Aug 25, 2015 #12 Can you let me know if Windows Updates works now? All errors were fixed in the log.
G galbicka Member Joined Aug 20, 2015 Posts 23 Aug 26, 2015 #13 The 13 updates installed fine and a recheck shows everything up to date now. Thanks for the help. Can you explain what may have caused this? Also this PC is running Windows XP in a VMware Player virtual environment and it is failing to install a set of updates itself. I guess it is best that I open a separate ticket for that, correct.
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,131 Location United States Aug 26, 2015 #14 Can you explain what may have caused this? Click to expand... There are so many reasons that this could happen. Some of them being the machine simply crashing causing corruption, power outages, RAM issues, disk issues. It's really impossible to track down exactly which caused your issues but I'm happy we were able to resolve them. If you do have a different machine that has an issue, yes please start a new thread. Thank you and take care.
G galbicka Member Joined Aug 20, 2015 Posts 23 Aug 26, 2015 #15 As I said in the post the other machine is a Windows XP virtual machine. Is the process different for XP?
BrianDrab Emeritus Joined Oct 20, 2014 Posts 18,131 Location United States Aug 26, 2015 #16 Is the process different for XP? Click to expand... Very. There aren't many tools that we can use for XP but we can always try.
