[7SP1x64] SFC and SURT corruptions were not fixed post SFCFix
AN78
Hello,
I executed sfc/ scannow (which couldn't fix the corrupted files) and subsequenty installed/ran the sfcfix utility which generated the following report below.
Unfortunately, the sfcfix couldn't repair the 4 corrupted files and I don't have the Windows 7 media. Any suggestions on how I can repair these 4 corrupted files please? There is also reference to 104 SURT corruptions that were not fixed as well.
I'm on Windows 7 Home SP1 (64-bit). Thank you.
Start time: 2017-12-23 17:55:22.697
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-fdeploy_31bf3856ad364e35_6.1.7601.17514_none_e1bcfc28af006dea\fdeploy.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-fde_31bf3856ad364e35_6.1.7601.17514_none_aa136561b9ed4ae4\fde.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-g..policy-admin-gpedit_31bf3856ad364e35_6.1.7600.16385_none_ce0882b8c63afdf6\gpedit.dll
CORRUPT: C:\Windows\winsxs\x86_microsoft-windows-grouppolicy-gptext_31bf3856ad364e35_6.1.7600.16385_none_372622adf05a6587\gptext.dll
CBS & SFC total detected corruption count: 4
SURT total detected corruption count: 104
Finish time: 2017-12-23 18:08:35.096
re: [Win7SP1x64] SFC and SURT corruptions were not fixed post SFCFix
Hello and welcome to Sysnative!
Please do the following:
Please Note:: if the file is too big to upload to your next post please upload via a service and just provide the link.
Re: [Win7SP1x64] SFC and SURT corruptions were not fixed post SFCFix
Advised steps completed. See attachment for requested log.
SURT can be ignored as the only remaining issues are benign.
SFC Scan
As requested, SFCFIX.txt below. CBS.txt attached.
Start time: 2017-12-23 19:17:53.002
SURT total detected corruption count: 9
Finish time: 2017-12-23 19:18:30.384
You have not done this correctly.
Download the attached zip file and drag it on top of the SFCFix.exe, then release. A few moments later, the log will appear.
Run SFC /scannow afterwards and then attach both logs here :)
My apologies.
Attached updated SFCFix.txt.
Unable to attach the latest cbs.txt due to forum upload size limitation of 1.68MB vs. 2.66MB (actual) for this specific filetype.
