[7SP1HomePre x64] CheckSUR "(f) CSI Missing Deployment Key" (not a problem?)
WinUpdt would not function at all. The check for updates button instantly returned a service was not running and it was best the PC was restarted. BITS, WU and Workstation were all Running and could be restarted (Stopping, Starting, Running).
SFCFix:
CheckSUR (also in ZIP):
Binary Version 6.1.7601.22471
Package Version 26.0
2017-12-28 19:16
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
(f) CSI Missing Deployment Key 0x00000000 policy.9.0...vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.4148_c6e3d20ca2b1ebce HKLM\Components\CanonicalData\Deployments
(f) CSI Missing Deployment Key 0x00000000 microsoft.vc90.openmp_1fc8b3b9a1e18e3b_9.0.30729.4148_390a91d20a21a864 HKLM\Components\CanonicalData\Deployments
(f) CSI Missing Deployment Key 0x00000000 policy.9.0...ft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4148_acd0e4ffe1daef0a HKLM\Components\CanonicalData\Deployments
(f) CSI Missing Deployment Key 0x00000000 microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4148_08e3747fa83e48bc HKLM\Components\CanonicalData\Deployments
Summary:
Seconds executed: 1239
Found 4 errors
CSI Missing Deployment Key Total count: 4
A variety of tools were utilized, including:
SFC/SCANNOW
FixWU 1.0 (thewindowsclub.com)
"WUFix(C) : [v3.0]" (an old script given by Ms. support back years ago, source here: )
Windows6.1-KB947821-v34-x64 (CheckSUR)
windowsupdateagent-7.6-x64 (Unsure if it installed successfully)
Ms. Inbuilt Fix-It (Found and Fixed four issues which appear to have corrected WU)
Logs attached. Suggestions? Thanks in advance.
View attachment CBS.zip
SFCFix:
Start time: 2017-12-28 20:01:10.499
SURT total detected corruption count: 4
Finish time: 2017-12-28 20:09:31.279
2017-12-28 19:16
Checking Packages
Summary:
Found 4 errors
SFC/SCANNOW
