[SOLVED] [7SP1 x86] Cbs&Sfc tdcc 2, Surt tdcc 118. Sfc can't repair by itself, please help.
cranleighboy
Running sfc some errors left unresolved
sfcfix could not fix some:
Start time: 2017-10-05 09:47:47.352
WARNING: Failed to get store name from identity name with return code 2 for component Microsoft-Windows-MarketTheme-CA-Component and file desktop.ini. File is reported as corrupt by SFC.
CORRUPT: desktop.ini of component Microsoft-Windows-MarketTheme-CA-Component.
WARNING: Failed to get store name from identity name with return code 2 for component prnhp003.inf and file I386\hpzsew71.dll. File is reported as corrupt by SFC.
CORRUPT: I386\hpzsew71.dll of component prnhp003.inf.
SURT total detected corruption count: 118
Finish time: 2017-10-05 09:49:18.316
Guidance/assistance as to how to prceed from here very welcome
Chris
Re: [Win7SP1 x86] Cbs&Sfc tdcc 2, Surt tdcc 118. Sfc can't repair by itself, please h
Attach the file C:\Windows\Logs\CBS\CheckSUR.log in your next reply.
The content of CheckSur.log is not as expected.
WARNING! The following fix is specific to the user's system in this thread only. No one else should follow these instructions, as it could damage your system. If you need assistance with an issue, please start a new thread and someone will assist you shortly.
  • Download
Follow the instructions below to run a scan with the System Update Readiness Tool (SURT) and provide a log.
  1. Download SURT for your system. (Windows 7 SP1 x86)
  2. Once downloaded, execute the installer, and go through the installation (this process can take around 15-20 minutes).
  3. On completion, a log will be created in C:\Windows\Logs\CBS\CheckSUR.log.
  4. Attach this log in your next reply.
Alternatively, if these instructions are unclear for you, you can follow the tutorial below.
I have now downloaded SURT again, and this time it ran! IO attach the CheckSUR log file which looks somewhat horrific to me, mabe not so to you!
Thanks Chris
  • Download
I don't see any attachment. Please try again. (The logfiles from step 1 & 2 please.)
I seem to be missing a vital step. How does one attach a file without uploading it -- the attach page seems to have no other methos, and the CheckSUR log at 14Mb is, the system tells me, to big to upload. If I drag it into the lower window of the attach page I get a browser window filled with the file, the window structure has gone (has this been attached), but then don't seem to be able to attach the other smaller log file (clicking on the attach icon simply takes me to the window without a pane to drag the other file to.
Sorry to be somewhat thick, but the attach window seems to be rather non-intuitive
Let me know if this file gets to you, otherwise give me more detailed instructions, somewhere I am missing a trick!!
The maximum filesize for attachments is about 8MB. Larger files must be uploaded to a file-sharing site such as SendSpace and provide the downloadlink here.
You may also upload files to a file-sharing site if using the attachment window somehow fails.
The CheckSur log is quite large.
Lets first check if there is a harddisc failure.
ChkDsk Scan
  • Click on Start - All programs - Accessories.
  • Rightclick on Command-prompt and select Run as administrator.
  • When command prompt opens, typ chkdsk into it, then press enter.
  • Wait for this to complete.
  • Download ListChkdskResult.exe by SleepyDude and save it on your desktop.
  • Rightclick
    ListChkdskResult.exe and select Run as administrator. Notepad will open the file ListChkdskResult.txt on completion. (The file ListChkdskResult.txt can be found on your desktop.)
  • Copy and paste this in your next reply.
Click on Start - All Programs - Accessories.
Right-click on Command-prompt and select Run as administrator.
When command prompt opens, copy and paste the following command into it, press enter afterwards.
chkdsk c: /f /r
At the question "Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)", press Y.
Restart the system.
Do not press any key during the restart. This will allow CHKDSK to start.
Wait for this to complete. Please note that this may take several hours. Let it run even if it looks like the process has stopped!
On completion, the system will restart automatically.
SFC Scan
  3. When command prompt opens, copy and paste the following commands into it, press enter after each.
    Note: if the file is too big to upload to your next post please upload via a service such as Dropbox or One Drive or SendSpace and just provide the download link.
Download
CrystalDiskInfo.zip and save it on your desktop.
Extract the .zip file into a new folder.
In this new folder, run the tool DiskInfo.
When the tool is finished, it will show some information about the hard disc.
Note: Resize the window so that all information is visible.
Take a screenshot. Read this on how to take a screenshot.
Upload the image file to a file-sharing site and post the download link.
There are a few problems with your hard disc. Check again next week to see if things get worse.
  • Download the file SFCFix.zip and save it on your desktop.
  • Drag the SFCFix.zip file over the
    SFCFix.exe executable and release it.
Action taken -- sfcfix.txt copied below -- thanks -- Chris
Start time: 2017-10-16 23:00:31.630
Using .zip script file at C:\Users\Chris Leslie\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-terminalmanager_31bf3856ad364e35_6.1.7601.17514_none_f62fe32f013ce946\termmgr.dll
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.2.7601.18934_none_eb7f0c2a4dac9797\mstscax.dll
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-shell-sounds_31bf3856ad364e35_6.1.7600.16385_none_16e8d25616dd2c98\Windows Logon Sound.wav
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-printing-xpsprint_31bf3856ad364e35_7.1.7601.16492_none_9ec29e48fab6a73c\XpsPrint.dll
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.1.7601.17514_none_9fe23e2588fdee38\NlsData000a.dll
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-m..ttheme-ca-component_31bf3856ad364e35_6.1.7601.17514_none_9ec1c61f2850dee3\CA-wp4.jpg
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-ie-offlinefavorites_31bf3856ad364e35_11.2.9600.18638_none_e74fbec0ae799c8c\desktop.ini
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-ie-objectcontrolviewer_31bf3856ad364e35_11.2.9600.18638_none_bd4a43f470e321a8\desktop.ini
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_11.2.9600.18638_none_880ccf45fe931ddd\wininet.dll
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-i..e-trigramdictionary_31bf3856ad364e35_6.1.7600.16385_none_b6b8175fa02129dc\PINTLGT.IMD
Successfully took permissions for file or folder C:\Windows\winsxs\x86_microsoft-windows-f..truetype-angsanaupc_31bf3856ad364e35_6.1.7600.16385_none_69840bdc6189f85f\angsau.ttf
Successfully took permissions for file or folder C:\Windows\winsxs\msil_windowsbase_31bf3856ad364e35_6.1.7601.23614_none_99afc399a70383cd\WindowsBase.dll
Successfully copied file C:\Users\Chris Leslie\AppData\Local\niemiro\Archive\x86_microsoft-windows-terminalmanager_31bf3856ad364e35_6.1.7601.17514_none_f62fe32f013ce946\termmgr.dll to C:\Windows\winsxs\x86_microsoft-windows-terminalmanager_31bf3856ad364e35_6.1.7601.17514_none_f62fe32f013ce946\termmgr.dll.
Successfully copied file C:\Users\Chris Leslie\AppData\Local\niemiro\Archive\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.2.7601.18934_none_eb7f0c2a4dac9797\mstscax.dll to C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.2.7601.18934_none_eb7f0c2a4dac9797\mstscax.dll.
Successfully copied file C:\Users\Chris Leslie\AppData\Local\niemiro\Archive\x86_microsoft-windows-shell-sounds_31bf3856ad364e35_6.1.7600.16385_none_16e8d25616dd2c98\Windows Logon Sound.wav to C:\Windows\winsxs\x86_microsoft-windows-shell-sounds_31bf3856ad364e35_6.1.7600.16385_none_16e8d25616dd2c98\Windows Logon Sound.wav.
Successfully copied file C:\Users\Chris Leslie\AppData\Local\niemiro\Archive\x86_microsoft-windows-printing-xpsprint_31bf3856ad364e35_7.1.7601.16492_none_9ec29e48fab6a73c\XpsPrint.dll to C:\Windows\winsxs\x86_microsoft-windows-printing-xpsprint_31bf3856ad364e35_7.1.7601.16492_none_9ec29e48fab6a73c\XpsPrint.dll.
WARNING: File C:\Windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.1.7601.17514_none_9fe23e2588fdee38\NlsData000a.dll was not backed up as that would replace the current backup.
Successfully copied file C:\Users\Chris Leslie\AppData\Local\niemiro\Archive\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.1.7601.17514_none_9fe23e2588fdee38\NlsData000a.dll to C:\Windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.1.7601.17514_none_9fe23e2588fdee38\NlsData000a.dll.
Successfully copied file C:\Users\Chris Leslie\AppData\Local\niemiro\Archive\x86_microsoft-windows-m..ttheme-ca-component_31bf3856ad364e35_6.1.7601.17514_none_9ec1c61f2850dee3\CA-wp4.jpg to C:\Windows\winsxs\x86_microsoft-windows-m..ttheme-ca-component_31bf3856ad364e35_6.1.7601.17514_none_9ec1c61f2850dee3\CA-wp4.jpg.
Successfully copied file C:\Users\Chris Leslie\AppData\Local\niemiro\Archive\x86_microsoft-windows-ie-offlinefavorites_31bf3856ad364e35_11.2.9600.18638_none_e74fbec0ae799c8c\desktop.ini to C:\Windows\winsxs\x86_microsoft-windows-ie-offlinefavorites_31bf3856ad364e35_11.2.9600.18638_none_e74fbec0ae799c8c\desktop.ini.
Successfully copied file C:\Users\Chris Leslie\AppData\Local\niemiro\Archive\x86_microsoft-windows-ie-objectcontrolviewer_31bf3856ad364e35_11.2.9600.18638_none_bd4a43f470e321a8\desktop.ini to C:\Windows\winsxs\x86_microsoft-windows-ie-objectcontrolviewer_31bf3856ad364e35_11.2.9600.18638_none_bd4a43f470e321a8\desktop.ini.
Successfully copied file C:\Users\Chris Leslie\AppData\Local\niemiro\Archive\x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_11.2.9600.18638_none_880ccf45fe931ddd\wininet.dll to C:\Windows\winsxs\x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_11.2.9600.18638_none_880ccf45fe931ddd\wininet.dll.
Successfully copied file C:\Users\Chris Leslie\AppData\Local\niemiro\Archive\x86_microsoft-windows-i..e-trigramdictionary_31bf3856ad364e35_6.1.7600.16385_none_b6b8175fa02129dc\PINTLGT.IMD to C:\Windows\winsxs\x86_microsoft-windows-i..e-trigramdictionary_31bf3856ad364e35_6.1.7600.16385_none_b6b8175fa02129dc\PINTLGT.IMD.
Successfully copied file C:\Users\Chris Leslie\AppData\Local\niemiro\Archive\x86_microsoft-windows-f..truetype-angsanaupc_31bf3856ad364e35_6.1.7600.16385_none_69840bdc6189f85f\angsau.ttf to C:\Windows\winsxs\x86_microsoft-windows-f..truetype-angsanaupc_31bf3856ad364e35_6.1.7600.16385_none_69840bdc6189f85f\angsau.ttf.
Successfully copied file C:\Users\Chris Leslie\AppData\Local\niemiro\Archive\msil_windowsbase_31bf3856ad364e35_6.1.7601.23614_none_99afc399a70383cd\WindowsBase.dll to C:\Windows\winsxs\msil_windowsbase_31bf3856ad364e35_6.1.7601.23614_none_99afc399a70383cd\WindowsBase.dll.
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-terminalmanager_31bf3856ad364e35_6.1.7601.17514_none_f62fe32f013ce946\termmgr.dll
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-terminalmanager_31bf3856ad364e35_6.1.7601.17514_none_f62fe32f013ce946\termmgr.dll
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.2.7601.18934_none_eb7f0c2a4dac9797\mstscax.dll
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-t..s-clientactivexcore_31bf3856ad364e35_7.2.7601.18934_none_eb7f0c2a4dac9797\mstscax.dll
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-shell-sounds_31bf3856ad364e35_6.1.7600.16385_none_16e8d25616dd2c98\Windows Logon Sound.wav
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-shell-sounds_31bf3856ad364e35_6.1.7600.16385_none_16e8d25616dd2c98\Windows Logon Sound.wav
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-printing-xpsprint_31bf3856ad364e35_7.1.7601.16492_none_9ec29e48fab6a73c\XpsPrint.dll
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-printing-xpsprint_31bf3856ad364e35_7.1.7601.16492_none_9ec29e48fab6a73c\XpsPrint.dll
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.1.7601.17514_none_9fe23e2588fdee38\NlsData000a.dll
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-naturallanguage6_31bf3856ad364e35_6.1.7601.17514_none_9fe23e2588fdee38\NlsData000a.dll
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-m..ttheme-ca-component_31bf3856ad364e35_6.1.7601.17514_none_9ec1c61f2850dee3\CA-wp4.jpg
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-m..ttheme-ca-component_31bf3856ad364e35_6.1.7601.17514_none_9ec1c61f2850dee3\CA-wp4.jpg
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-ie-offlinefavorites_31bf3856ad364e35_11.2.9600.18638_none_e74fbec0ae799c8c\desktop.ini
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-ie-offlinefavorites_31bf3856ad364e35_11.2.9600.18638_none_e74fbec0ae799c8c\desktop.ini
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-ie-objectcontrolviewer_31bf3856ad364e35_11.2.9600.18638_none_bd4a43f470e321a8\desktop.ini
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-ie-objectcontrolviewer_31bf3856ad364e35_11.2.9600.18638_none_bd4a43f470e321a8\desktop.ini
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_11.2.9600.18638_none_880ccf45fe931ddd\wininet.dll
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_11.2.9600.18638_none_880ccf45fe931ddd\wininet.dll
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-i..e-trigramdictionary_31bf3856ad364e35_6.1.7600.16385_none_b6b8175fa02129dc\PINTLGT.IMD
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-i..e-trigramdictionary_31bf3856ad364e35_6.1.7600.16385_none_b6b8175fa02129dc\PINTLGT.IMD
Successfully restored ownership for C:\Windows\winsxs\x86_microsoft-windows-f..truetype-angsanaupc_31bf3856ad364e35_6.1.7600.16385_none_69840bdc6189f85f\angsau.ttf
Successfully restored permissions on C:\Windows\winsxs\x86_microsoft-windows-f..truetype-angsanaupc_31bf3856ad364e35_6.1.7600.16385_none_69840bdc6189f85f\angsau.ttf
Successfully restored ownership for C:\Windows\winsxs\msil_windowsbase_31bf3856ad364e35_6.1.7601.23614_none_99afc399a70383cd\WindowsBase.dll
Successfully restored permissions on C:\Windows\winsxs\msil_windowsbase_31bf3856ad364e35_6.1.7601.23614_none_99afc399a70383cd\WindowsBase.dll
Currently storing 1118 datablocks.
Finish time: 2017-10-16 23:00:41.162
Script hash: dEg9X6n1Zz3lyz6jYh5c61Rw2BAfADsNxdJFpXSwlwI=
  • Download
Retrieve Components Hive
  • Then please upload the zip file (COMPONENTS.zip) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Dropbox or One Drive or SendSpace and then just provide the link in your reply.
