I have tried numerous times to load the above referenced MS updates without success. I get error 80073701 for both. I have tried a number of fixes also without success including:
MS Windows Update FixIt tool
MS FixIt 50202
Reset catroot2 and Windows Update Components
MS System Update Readiness Tool
Ran Chkdsk
I use MS Security Essentials as my AV and MS Firewall. I have run Malwarebytes which has been negative for malware.
Here are the results from following the steps in your instructions:
#2 - SFC Scan was negative.
#3 - Hotfix for 947821 ran for 2 hours and stalled at ~90%. Then it locked up and I had to exit using Ctl/Alt/Del.
#4 - SFCFix version 3.0.0.0 by niemiro.
Start time: 2018-08-09 00:28:01.701
SURT total detected corruption count: 914
Finish time: 2018-08-09 00:28:37.808
Hi Softwaremaniac-
I launched the SURT tool as you said to do. It stalled at "Initiate installation" for a long time but after about 3 hours it read "Installation Complete." For Win7 OS what it does is install KB947821. I checked my Update History and it confirms that this file was installed successfully.
What should I do next?
Download SFCFix.exe (by niemiro) and save this to your Desktop.
Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it.
Save any open documents and close all open windows.
Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put
Software Maniac-
Putting in the tags was very tedious. I hope this is what you wanted.
-Barry
Start time: 2018-08-09 19:13:06.463
Using .zip script file at C:\Users\Barry M\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\Temp\CheckSur\Servicing\Packages
[CODE]Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_100_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_100_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_100_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_100_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_100_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_100_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_100_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_100_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_100_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_100_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_100_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_100_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_101_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_101_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_101_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_101_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_101_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_101_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_101_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_101_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_101_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_101_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_101_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_101_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_102_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_102_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_102_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_102_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_102_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_102_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_102_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_102_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_102_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_102_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_102_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_102_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_103_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_103_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_104_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_104_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_105_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_105_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_106_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_106_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1071_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1071_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1071_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1071_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1078_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1078_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1078_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1078_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_107_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_107_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1081_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1081_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1081_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1081_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1088_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1088_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1088_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1088_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_108_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_108_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_109_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_109_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1108_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1108_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1108_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1108_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1109_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1109_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1109_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1109_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_110_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_110_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1110_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1110_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1110_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1110_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1111_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1111_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1111_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1111_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1112_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1112_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1112_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1112_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1113_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1113_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1113_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1113_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1114_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1114_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1114_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1114_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1118_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1118_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1118_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1118_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1119_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1119_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1119_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1119_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_111_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_111_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1120_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1120_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1120_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1120_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1121_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1121_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1121_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1121_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1122_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1122_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1122_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1122_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1123_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1123_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1123_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1123_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1124_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1124_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1124_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1124_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_112_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_112_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_113_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_113_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3040272~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3153731~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3162835~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3177723~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB3182203~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_114_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_114_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_115_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_115_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_115_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_115_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_115_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_115_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_115_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_115_for_KB3161561~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_115_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_115_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_115_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_115_for_KB3167679~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_115_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_115_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_115_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_115_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_115_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_115_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_115_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_115_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_115_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_115_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_115_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_115_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_116_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_116_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_116_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_116_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_116_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_116_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_116_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_116_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_116_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_116_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_116_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_116_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_117_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_117_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_117_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_117_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_118_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_118_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_118_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_118_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_118_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_118_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_118_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_118_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_118_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_118_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_118_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_118_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1197_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1197_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1197_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1197_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_119_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_119_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_119_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_119_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_119_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_119_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_119_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_119_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_119_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_119_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_119_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_119_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1200_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1200_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1200_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1200_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1204_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1204_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1204_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1204_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1207_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1207_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1207_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1207_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_120_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_120_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_120_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_120_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_120_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_120_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_120_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_120_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_121_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_121_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_121_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_121_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_121_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_121_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_121_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_121_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_121_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_121_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_121_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_121_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_121_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_121_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_121_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_121_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1223_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1223_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1223_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1223_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1229_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1229_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1229_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1229_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_122_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_122_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_122_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_122_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_122_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_122_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_122_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_122_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1230_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1230_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1230_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1230_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1234_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1234_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1234_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1234_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1235_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1235_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1235_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1235_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1236_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1236_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1236_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1236_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1236_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1236_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1236_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1236_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1237_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1237_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1237_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1237_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1237_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1237_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1237_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1237_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1238_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1238_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1238_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1238_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1238_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1238_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1238_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1238_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1239_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1239_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1239_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1239_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1239_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1239_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1239_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1239_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_123_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_123_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_123_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_123_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_123_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_123_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_123_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_123_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_123_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_123_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_123_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_123_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1240_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1240_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1240_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1240_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1240_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1240_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1240_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1240_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1241_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1241_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1241_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1241_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1242_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1242_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1242_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1242_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1243_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1243_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1243_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1243_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_124_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_124_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_124_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_124_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_125_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_125_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_125_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_125_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1260_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1260_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1260_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1260_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1261_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1261_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1261_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1261_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1262_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1262_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1262_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1262_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1263_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1263_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1263_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1263_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1264_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1264_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1264_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1264_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1265_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1265_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1265_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1265_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1266_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1266_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1266_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1266_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1266_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1266_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1266_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1266_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1267_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1267_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1267_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1267_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1268_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1268_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1268_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1268_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1269_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1269_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1269_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1269_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_126_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_126_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_126_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_126_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1270_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1270_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1270_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1270_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1271_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1271_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1271_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1271_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1272_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1272_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1272_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1272_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_128_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_128_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_128_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_128_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_128_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_128_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_128_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_128_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_128_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_128_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_128_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_128_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_128_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_128_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_128_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_128_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_128_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_128_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_128_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_128_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_129_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_129_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_129_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_129_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_129_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_129_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_129_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_129_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_129_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_129_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_129_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_129_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_129_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_129_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_129_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_129_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_129_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_129_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_129_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_129_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_129_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_129_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_129_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_129_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_130_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_130_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_130_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_130_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_130_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_130_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_130_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_130_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_130_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_130_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_130_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_130_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_130_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_130_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_130_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_130_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_130_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_130_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_130_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_130_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_130_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_130_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_130_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_130_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_131_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_131_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_132_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_132_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_133_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_133_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_133_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_133_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_133_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_133_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_133_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_133_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_133_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_133_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_133_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_133_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_133_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_133_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_133_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_133_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_133_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_133_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_133_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_133_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_133_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_133_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_133_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_133_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB3080079~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_134_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_134_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_135_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_135_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_136_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_136_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_136_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_136_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_136_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_136_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_136_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_136_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_136_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_136_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_136_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_136_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_136_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_136_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_136_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_136_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_136_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_136_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_136_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_136_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_136_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_136_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_136_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_136_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_137_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_137_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_137_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_137_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_137_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_137_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_137_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_137_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_137_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_137_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_137_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_137_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_137_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_137_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_137_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_137_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_137_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_137_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_137_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_137_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_137_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_137_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_137_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_137_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_138_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_138_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_138_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_138_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_138_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_138_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_138_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_138_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_138_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_138_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_138_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_138_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_138_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_138_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_138_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_138_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_139_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_139_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_139_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_139_for_KB3042058~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_139_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_139_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_139_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_139_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_139_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_139_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_139_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_139_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_139_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_139_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_139_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_139_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_140_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_140_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_140_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_140_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_140_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_140_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_140_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_140_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_140_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_140_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_140_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_140_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_141_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_141_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_141_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_141_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_144_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_144_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_144_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_144_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_144_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_144_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_144_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_144_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_145_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_145_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_145_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_145_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_145_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_145_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_145_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_145_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_146_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_146_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_146_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_146_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_146_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_146_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_146_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_146_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_147_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_147_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_147_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_147_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_147_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_147_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_147_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_147_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_148_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_148_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_148_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_148_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_148_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_148_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_148_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_148_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_149_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_149_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_149_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_149_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_149_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_149_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_149_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_149_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_149_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_149_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_149_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_149_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_149_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_149_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_149_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_149_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_149_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_149_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_149_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_149_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_150_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_150_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_150_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_150_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_150_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_150_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_150_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_150_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_150_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_150_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_150_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_150_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_150_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_150_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_150_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_150_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_150_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_150_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_150_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_150_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_150_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_150_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_150_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_150_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_151_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_151_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_151_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_151_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_151_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_151_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_151_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_151_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_151_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_151_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_151_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_151_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_151_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_151_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_151_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_151_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_151_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_151_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_151_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_151_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_152_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_152_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_153_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_153_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_154_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_154_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_155_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_155_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_155_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_155_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_155_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_155_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_155_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_155_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_155_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_155_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_155_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_155_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_155_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_155_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_155_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_155_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_155_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_155_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_155_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_155_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_155_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_155_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_155_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_155_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_156_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_156_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_156_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_156_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_156_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_156_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_156_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_156_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_156_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_156_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_156_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_156_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_156_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_156_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_156_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_156_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_156_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_156_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_156_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_156_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_157_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_157_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_157_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_157_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_157_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_157_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_157_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_157_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_157_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_157_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_157_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_157_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_157_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_157_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_157_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_157_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_158_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_158_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_158_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_158_for_KB3153171~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_158_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_158_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_158_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_158_for_KB3175024~31bf3856ad364e35~amd64~~6.1.2.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_160_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_160_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_160_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_160_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_161_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_161_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_161_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_161_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_162_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_162_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_162_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_162_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_162_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_162_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_162_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_162_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_163_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_163_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_163_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_163_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_163_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_163_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_163_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_163_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_164_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_164_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_164_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_164_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_164_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_164_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_164_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_164_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_165_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_165_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_165_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_165_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_165_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_165_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_165_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_165_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_166_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_166_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_166_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_166_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_166_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_166_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_166_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_166_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_166_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_166_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_166_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_166_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_166_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_166_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_166_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_166_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_167_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_167_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_167_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_167_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_167_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_167_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_167_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_167_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_167_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_167_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_167_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_167_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_167_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_167_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_167_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_167_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_168_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_168_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_168_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_168_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_168_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_168_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_168_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_168_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_168_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_168_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_168_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_168_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_169_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_169_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_169_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_169_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_169_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_169_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_169_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_169_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_169_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_169_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_169_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_169_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_16_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_16_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_16_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_16_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_16_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_16_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_16_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_16_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_16_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_16_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_16_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_16_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_170_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_170_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_170_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_170_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_170_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_170_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_170_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_170_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_170_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_170_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_170_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_170_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_170_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_170_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_170_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_170_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_170_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_170_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_170_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_170_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_170_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_170_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_170_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_170_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_171_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_171_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_171_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_171_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_171_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_171_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_171_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_171_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_171_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_171_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_171_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_171_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_171_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_171_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_171_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_171_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_171_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_171_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_171_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_171_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_171_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_171_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_171_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_171_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_172_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_172_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_172_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_172_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_172_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_172_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_172_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_172_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_172_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_172_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_172_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_172_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_172_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_172_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_172_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_172_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_173_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_173_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_173_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_173_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_173_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_173_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_173_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_173_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_173_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_173_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_173_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_173_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_173_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_173_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_173_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_173_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_173_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_173_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_173_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_173_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_174_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_174_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_174_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_174_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_174_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_174_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_174_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_174_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_174_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_174_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_174_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_174_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_174_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_174_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_174_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_174_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_175_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_175_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_175_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_175_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_175_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_175_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_175_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_175_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_175_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_175_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_175_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_175_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_175_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_175_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_175_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_175_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_176_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_176_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_176_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_176_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_176_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_176_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_176_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_176_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_176_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_176_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_176_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_176_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_176_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_176_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_176_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_176_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_177_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_177_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_177_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_177_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_177_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_177_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_177_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_177_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_178_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_178_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_178_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_178_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_178_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_178_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_178_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_178_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_179_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_179_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_179_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_179_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_179_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_179_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_179_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_179_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_17_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_17_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_17_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_17_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_17_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_17_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_17_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_17_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_180_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_180_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_180_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_180_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_180_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_180_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_180_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_180_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_181_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_181_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_181_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_181_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_182_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_182_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_182_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_182_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_186_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_186_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_186_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_186_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_187_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_187_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_187_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_187_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_188_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_188_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_188_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_188_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_189_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_189_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_189_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_189_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_189_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_189_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_189_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_189_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_189_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_189_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_189_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_189_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_189_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_189_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_189_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_189_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_190_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_190_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_190_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_190_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_190_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_190_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_190_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_190_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_190_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_190_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_190_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_190_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_190_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_190_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_190_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_190_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_190_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_190_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_190_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_190_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_191_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_191_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_191_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_191_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_191_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_191_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_191_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_191_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_191_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_191_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_191_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_191_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_191_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_191_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_191_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_191_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_191_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_191_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_191_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_191_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_192_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_192_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_192_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_192_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_192_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_192_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_192_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_192_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_192_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_192_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_192_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_192_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_192_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_192_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_192_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_192_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_192_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_192_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_192_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_192_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_192_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_192_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_192_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_192_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_193_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_193_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_193_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_193_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_193_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_193_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_193_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_193_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_193_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_193_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_193_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_193_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_193_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_193_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_193_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_193_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_194_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_194_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_194_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_194_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_194_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_194_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_194_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_194_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_194_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_194_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_194_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_194_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_195_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_195_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_195_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_195_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_195_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_195_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_195_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_195_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_195_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_195_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_195_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_195_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_195_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_195_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_195_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_195_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_196_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_196_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_196_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_196_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_196_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_196_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_196_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_196_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_196_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_196_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_196_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_196_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_196_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_196_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_196_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_196_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_197_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_197_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_197_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_197_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_197_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_197_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_197_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_197_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_197_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_197_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_197_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_197_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_197_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_197_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_197_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_197_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_198_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_198_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_198_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_198_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_198_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_198_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_198_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_198_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_198_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_198_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_198_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_198_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_198_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_198_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_198_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_198_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_199_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_199_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_199_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_199_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_199_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_199_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_199_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_199_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_199_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_199_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_199_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_199_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_199_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_199_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_199_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_199_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_199_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_199_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_199_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_199_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.19.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.19.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.19.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.19.0.mum.
Successfully restored ownership for C:\Windows\Temp\CheckSur\Servicing\Packages
Successfully restored permissions on C:\Windows\Temp\CheckSur\Servicing\Packages
Finish time: 2018-08-09 19:13:31.719
Script hash: xEJ9Fn5VCO4E6MJO7eLKi9MLwSDBQkVeWNRtZ82SHH4=
----------------------EOF-----------------------[/CODE]
By the way, what I had done to get the tags on the other file was to triple click on each line to highlight it and then click on the # button. Only problem, there were a LOT of lines. Was there an easier way to do this....so I'll know for next time. By the time I finished I felt like had gotten run over by a truck!
-Barry
Download SFCFix.exe (by niemiro) and save this to your Desktop.
Download the file below, SFCFix.zip, and save this to your Desktop. Ensure that this file is named SFCFix.zip - do not rename it.
Save any open documents and close all open windows.
Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put [CODE][/CODE] tags around the log to break up the text.
I have SFCFix.zip and SFCFix.exe on my desktop from previous steps you've had me take. Can I use the same SFCFix.exe I already have and just put the new SFCFix.zip in that, or do I need to download both of them again? Also, should I delete one or both of these files that are already on my computer?
When you say "put
tags around the log to break up the text," do you mean what I did last time with tags at the beginning and end of each line, or just two (2), one at the beginning of the entire log and the other at the end?
Please let me know so I can get this right.
Thanks.
-Barry
Below are the files you requested. I hope I got this right....I've had a lot going on here today.
-Barry
Start time: 2018-08-10 21:42:44.650
Using .zip script file at C:\Users\Barry M\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\Temp\CheckSur\Servicing\Packages
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.20.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.20.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.20.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.20.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.23.11.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.23.11.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.23.11.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.23.11.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.23.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.23.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.23.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB2952664~31bf3856ad364e35~amd64~~6.1.23.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2972211~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB2972211~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2972211~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB2972211~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2978120~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB2978120~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB2978120~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB2978120~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3006625~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3006625~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3006625~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3006625~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3042553~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3042553~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3042553~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3042553~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3084135~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3084135~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3084135~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3084135~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3122648~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3122648~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3122648~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3122648~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3124280~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3124280~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3124280~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3124280~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3126446~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3126446~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3126446~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3126446~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3135983~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3135983~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3135983~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3135983~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3138962~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3138962~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3138962~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3138962~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3156017~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3156017~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3156017~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3156017~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3161958~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3161958~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3161958~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3161958~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3163245~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3163245~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3163245~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3163245~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3177186~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3177186~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3177186~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3177186~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3188740~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3188740~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3188740~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3188740~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3195789~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3195789~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3195789~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3195789~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3210131~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3210131~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB3210131~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB3210131~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB4014565~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB4014565~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_1_for_KB4014565~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_1_for_KB4014565~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_200_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_200_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_200_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_200_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_200_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_200_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_200_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_200_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_201_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_201_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_201_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_201_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_202_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_202_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_202_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_202_for_KB3033929~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_203_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_203_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_203_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_203_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_204_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_204_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_204_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_204_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_204_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_204_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_204_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_204_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_204_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_204_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_204_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_204_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_205_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_205_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_205_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_205_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_205_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_205_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_205_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_205_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_206_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_206_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_206_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_206_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_206_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_206_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_206_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_206_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_207_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_207_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_207_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_207_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_207_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_207_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_207_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_207_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_207_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_207_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_207_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_207_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_207_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_207_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_207_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_207_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_208_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_208_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_208_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_208_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_208_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_208_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_208_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_208_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_208_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_208_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_208_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_208_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_208_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_208_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_208_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_208_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_209_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_209_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_209_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_209_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_209_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_209_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_209_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_209_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_209_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_209_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_209_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_209_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_209_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_209_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_209_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_209_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_210_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_210_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_210_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_210_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_210_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_210_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_210_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_210_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_210_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_210_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_210_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_210_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_211_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_211_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_211_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_211_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_211_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_211_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_211_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_211_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_211_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_211_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_211_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_211_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_212_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_212_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_212_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_212_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_212_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_212_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_212_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_212_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_212_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_212_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_212_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_212_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_213_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_213_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_213_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_213_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_213_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_213_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_213_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_213_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_213_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_213_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_213_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_213_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_214_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_214_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_214_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_214_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_214_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_214_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_214_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_214_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_214_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_214_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_214_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_214_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_215_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_215_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_215_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_215_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_215_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_215_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_215_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_215_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_219_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_219_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_219_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_219_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_220_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_220_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_220_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_220_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_221_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_221_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_221_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_221_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_222_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_222_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_222_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_222_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_223_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_223_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_223_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_223_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_224_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_224_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_224_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_224_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_235_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_235_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_235_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_235_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_235_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_235_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_235_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_235_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_235_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_235_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_235_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_235_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_235_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_235_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_235_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_235_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_236_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_236_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_237_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_237_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_238_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_238_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_239_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_239_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_240_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_240_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_241_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_241_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_242_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_242_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_243_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_243_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_244_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_244_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_245_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_245_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_246_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_246_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_246_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_246_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_246_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_246_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_246_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_246_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_246_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_246_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_246_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_246_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_246_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_246_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_246_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_246_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_246_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_246_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_246_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_246_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_246_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_246_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_246_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_246_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_247_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_247_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_247_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_247_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_247_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_247_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_247_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_247_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_247_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_247_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_247_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_247_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_247_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_247_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_247_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_247_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_247_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_247_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_247_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_247_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_248_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_248_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_248_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_248_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_248_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_248_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_248_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_248_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_248_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_248_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_248_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_248_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_248_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_248_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_248_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_248_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_248_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_248_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_248_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_248_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_249_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_249_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_249_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_249_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_249_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_249_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_249_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_249_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_249_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_249_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_249_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_249_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_249_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_249_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_249_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_249_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_250_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_250_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_250_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_250_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_250_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_250_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_250_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_250_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_250_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_250_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_250_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_250_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_250_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_250_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_250_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_250_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_250_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_250_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_250_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_250_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_251_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_251_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_251_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_251_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_251_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_251_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_251_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_251_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_251_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_251_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_251_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_251_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_251_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_251_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_251_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_251_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_251_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_251_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_251_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_251_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_252_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_252_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_252_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_252_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_252_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_252_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_252_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_252_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_252_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_252_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_252_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_252_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_252_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_252_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_252_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_252_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_252_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_252_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_252_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_252_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_252_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_252_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_252_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_252_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_253_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_253_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_253_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_253_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_253_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_253_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_253_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_253_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_253_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_253_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_253_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_253_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_253_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_253_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_253_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_253_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_253_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_253_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_253_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_253_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_254_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_254_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_254_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_254_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_254_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_254_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_254_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_254_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_254_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_254_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_254_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_254_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_254_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_254_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_254_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_254_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_255_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_255_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_255_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_255_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_255_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_255_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_255_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_255_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_255_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_255_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_255_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_255_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_256_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_256_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_256_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_256_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_256_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_256_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_256_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_256_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_256_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_256_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_256_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_256_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_257_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_257_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_257_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_257_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_257_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_257_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_257_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_257_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_257_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_257_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_257_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_257_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_258_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_258_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_258_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_258_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_258_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_258_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_258_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_258_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_258_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_258_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_258_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_258_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_259_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_259_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_259_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_259_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_259_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_259_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_259_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_259_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_259_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_259_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_259_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_259_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_25_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_25_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_25_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_25_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_260_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_260_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_260_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_260_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_260_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_260_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_260_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_260_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_260_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_260_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_260_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_260_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_261_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_261_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_261_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_261_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_261_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_261_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_261_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_261_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_261_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_261_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_261_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_261_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_262_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_262_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_262_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_262_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_262_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_262_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_262_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_262_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_262_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_262_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_262_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_262_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_262_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_262_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_262_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_262_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_263_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_263_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_263_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_263_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_263_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_263_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_263_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_263_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_263_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_263_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_263_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_263_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_263_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_263_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_263_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_263_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_264_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_264_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_264_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_264_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_264_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_264_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_264_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_264_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_264_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_264_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_264_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_264_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_265_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_265_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_265_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_265_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_265_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_265_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_265_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_265_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_265_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_265_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_265_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_265_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_265_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_265_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_265_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_265_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_266_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_266_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_266_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_266_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_266_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_266_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_266_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_266_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_266_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_266_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_266_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_266_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_267_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_267_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_267_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_267_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_267_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_267_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_267_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_267_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_267_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_267_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_267_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_267_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_268_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_268_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_268_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_268_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_268_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_268_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_268_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_268_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_268_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_268_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_268_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_268_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_269_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_269_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_269_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_269_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_26_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_26_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_26_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_26_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_26_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_26_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_26_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_26_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_270_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_270_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_270_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_270_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_272_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_272_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_272_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_272_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_272_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_272_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_272_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_272_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_273_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_273_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_273_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_273_for_KB4015549~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_273_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_273_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_273_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_273_for_KB4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_274_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_274_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_274_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_274_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_275_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_275_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_275_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_275_for_KB4022719~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_277_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_277_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_277_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_277_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_277_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_277_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_277_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_277_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_277_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_277_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_277_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_277_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_278_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_278_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_278_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_278_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_278_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_278_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_278_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_278_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_278_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_278_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_278_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_278_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_278_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_278_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_278_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_278_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_279_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_279_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_279_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_279_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_279_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_279_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_279_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_279_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_279_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_279_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_279_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_279_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_279_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_279_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_279_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_279_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_27_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_27_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_27_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_27_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_27_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_27_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_27_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_27_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_280_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_280_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_280_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_280_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_280_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_280_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_280_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_280_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_280_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_280_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_280_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_280_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_280_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_280_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_280_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_280_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_280_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_280_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_280_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_280_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_281_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_281_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_281_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_281_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_281_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_281_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_281_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_281_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_281_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_281_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_281_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_281_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_281_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_281_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_281_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_281_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_281_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_281_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_281_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_281_for_KB4012215~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_282_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_282_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_282_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_282_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_282_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_282_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_282_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_282_for_KB3197869~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_282_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_282_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_282_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_282_for_KB3207752~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_282_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_282_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_282_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_282_for_KB3212646~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_283_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_283_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_283_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_283_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_283_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_283_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_283_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_283_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_284_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_284_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_284_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_284_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_284_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_284_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_284_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_284_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_285_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_285_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_285_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_285_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_285_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_285_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_285_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_285_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_286_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_286_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_286_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_286_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_286_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_286_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_286_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_286_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_286_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_286_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_286_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_286_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_286_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_286_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_286_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_286_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_287_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_287_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_287_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_287_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_287_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_287_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_287_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_287_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_287_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_287_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_287_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_287_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_287_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_287_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_287_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_287_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_288_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_288_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_288_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_288_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_288_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_288_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_288_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_288_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_288_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_288_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_288_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_288_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_288_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_288_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_288_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_288_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_289_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_289_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_28_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_28_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_28_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_28_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_290_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_290_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_290_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_290_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_290_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_290_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_290_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_290_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_290_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_290_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_290_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_290_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_290_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_290_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_290_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_290_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_290_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_290_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_290_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_290_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_290_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_290_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_290_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_290_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_291_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_291_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_292_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_292_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_293_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_293_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_294_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_294_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_295_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_295_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_296_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_296_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_297_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_297_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_298_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_298_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB3185330~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB3197868~31bf3856ad364e35~amd64~~6.1.1.5.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4025341~31bf3856ad364e35~amd64~~6.1.1.6.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4034664~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4038777~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4041681~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4048957~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4054518~31bf3856ad364e35~amd64~~6.1.1.2.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4056894~31bf3856ad364e35~amd64~~6.1.1.4.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_299_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_299_for_KB4074598~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_29_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_29_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_29_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_29_for_KB3181988~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB2972211~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB2972211~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB2972211~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB2972211~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB2973112~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB2978120~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB2978120~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB2978120~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB2978120~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3004361~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3004361~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3004361~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3004361~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3022777~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3022777~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3022777~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3022777~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3033889~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3033889~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3033889~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3033889~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3084135~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3084135~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3084135~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3084135~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3092601~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3092601~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3092601~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3092601~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3092627~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3092627~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3092627~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3092627~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3101722~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3101722~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3101722~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3101722~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3108670~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3108670~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3108670~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3108670~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3109094~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3109094~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3109094~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3109094~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3121255~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3121255~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3121255~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3121255~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3122648~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3122648~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3122648~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3122648~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3124280~31bf3856ad364e35~amd64~~6.1.1.1.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3124280~31bf3856ad364e35~amd64~~6.1.1.1.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3124280~31bf3856ad364e35~amd64~~6.1.1.1.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3124280~31bf3856ad364e35~amd64~~6.1.1.1.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3126446~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3126446~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3126446~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3126446~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3135983~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3135983~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Barry M\AppData\Local\niemiro\Archive\Packages\Package_2_for_KB3135983~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\Temp\CheckSur\Servicing\Packages\Package_2_for_KB3135983~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully restored ownership for C:\Windows\Temp\CheckSur\Servicing\Packages
Successfully restored permissions on C:\Windows\Temp\CheckSur\Servicing\Packages
Finish time: 2018-08-10 21:43:05.258
Script hash: BJ6KWu/WKlNwOSgeYWTss5UncVtMxu7/DVokJ1xxRXE=
FRST Registry Search 1. Click your Start button and choose Control Panel.
3. Select the Programs group. 4. Click the Turn Windows features on or off link. This will bring up the Windows Features dialog. Wait until this dialog populates with information. If this does not happen for some reason, please continue with the steps anyway. Note: This loads your components hive which is what we want. Please keep this dialog open while you perform the remaining steps. 5. Please download Farbar Recovery Scan Tool and save it to your Desktop. Note: You need to run the 64-bit Version so please ensure you download that one.
7. Copy and paste KB2952664;KB3102429 into the Search box and click the Search Registry button. 8. When the scan is complete a notepad window will open with the results. Please attach this to your next reply. It is saved on your desktop named SearchReg.txt. 9. You may close any remaining open windows now.
Step#1 - FRST Fix NOTICE: This script was written specifically for this user, for use on that particular machine. Running this on another machine may cause damage to your operating system
1. Please download Farbar Recovery Scan Tool and save it to your Desktop. Note: You need to run the 64-bit Version so please ensure you download that one.
2. Download attached file and save it to the Desktop. Note. It's important that both files, FRST64 and fixlist.txt are in the same location or the fix will not work (in this case...the desktop).
