jcgriff2
Co-Founder / Admin
BSOD Instructor/Expert
Microsoft MVP (Ret.)
2022 Chevrolet Bolt SUV - Chevy Electric Vehicle Lineup: EVs & EUVs
Note: Look toward bottom for warranty on batteries.
This section really caught my eye -
BMW 760i V12 - starts at $157,800 - M760i xDrive Performance Sedan | BMW USA
LT • FWD
Starts from
$33,995
Interior
Standard
10 airbags
1 Always use seat belts and child restraints. Children are safer when properly secured in a rear seat in the appropriate child restraint. See the Owner's Manual for more information.
- Frontal airbags for driver and front passenger1
- Knee airbags for driver and front passenger1
- Seat-mounted side-impact airbags for all outboard seating positions1
- Head-curtain airbags for all rows in outboard seating positions1
- Includes Passenger Sensing System which automatically switches the front passenger seat frontal airbag and knee airbag on or off and illuminates a status light that indicates whether the airbags are on or off1
Standard
6-speaker audio system
Standard
- Speakers are positioned throughout the cabin for outstanding sound quality and an enjoyable listening experience
Cargo storage for charging cord
Standard
- Covered storage located in the cargo area
Wireless Device Charging
1 The system wirelessly charges one compatible mobile device. Some phones have built-in wireless charging technology and others require a special adaptor/back cover. For a list of GM wireless charging compatible mobile device click here. If your device is not on the list, please consult your carrier.
- Uses induction technology for select cell phones1
Standard
Lighting, interior, illuminated entry
Standard
OnStar® & Chevrolet Connected Services capable
Standard
- Terms and limitations apply. See onstar.com or dealer for details.
Front carpeted floor mats
Standard
- Helps protect your interior from road debris and the elements
- Engineered to fit your vehicle
Rear carpeted floor mats
Standard
Inside rearview manual day/night mirror
Standard
- Adjust the tilt of the mirror to help reduce glare during nighttime driving
Lane Keep Assist with Lane Departure Warning
1 Safety or driver assistance features are no substitute for the driver's responsibility to operate the vehicle in a safe manner. The driver should remain attentive to traffic, surroundings and road conditions at all times. Visibility, weather, and road conditions may affect feature performance. Read the vehicle's owner's manual for more important feature limitations and information.
- Uses a brief, gentle steering wheel turn to alert you when you may be unintentionally drifting out of detected lane lines, so you can steer to stay safely in your lane1
- If needed, you may receive additional Lane Departure Warning alerts
- System alerts do not occur if you're using your turn signal or it detects you may be intentionally leaving your lane
Standard
Driver Information Center
Standard
- 8" diagonal enhanced multi-color configurable graphic display
- View Battery status, Efficiency, and a selection of driver information screens
- Choose from 2 visual themes: Modern and Enhanced
- In addition, there's a confidence gauge for remaining EV range and a digital speed readout
Regen on Demand™ steering wheel paddle
1 Feature may be limited when the battery is cold or near full charge. Always use the brake pedal when you need to immediately stop. See the Owner's Manual for details.
- Activates regenerative braking on demand to capture otherwise lost energy even without using the brake pedal, and sends that energy to the battery pack1
- Pull and hold the Regen on Demand steering wheel paddle to slow down faster and send additional energy to the battery
- You must use your brake pedal if you need to stop immediately
Standard
Seat belts, 3-point driver and front passenger
Standard
Seat belts, 3-point, rear outboard and center position
Standard
Cabin air filter
Standard
- Helps keep your cabin air fresh
Rear Seat Reminder
1 Does not detect people or items. Always check rear seat before exiting.
- Helps to remind the driver to check the back seat(s) before leaving the vehicle1
- Activates when rear doors are opened and closed up to 10 minutes before or anytime while your vehicle is on
- Under certain conditions, once the vehicle is switched off, designed to sound 5 audible chimes and display a visual message within the Driver Information Center
- Activates only once each time the vehicle is turned on and off, and would require re-activation on a second trip
Standard
LATCH System
Standard
- Lower Anchors and Tethers for CHildren system helps make it easy to install and secure a compatible child restraint seat
Vehicle efficiency display
Standard
- Includes energy information screens with programmable charge times
Rear child security door locks
Standard
- When activated, prevents passengers from opening the rear doors from inside the vehicle
- Allow rear doors to open from outside of the vehicle only
Manual tilt and telescoping steering column
Standard
- Allows the driver to adjust the steering wheel up or down, and the steering column forward or back
- Provides extra comfort when entering or exiting the vehicle
Ambient instrument panel lighting
Standard
- LED light pipe accent on the instrument panel
- Theater dimming and delayed entry/exit lighting as you enter or leave the vehicle
Keyless Open and Start
Standard
- With the key fob in your possession, locks and unlocks your car's doors without having to use the key fob, increasing convenience
- With the vehicle in Park or Neutral, press the brake pedal and then press the start/stop button to start the vehicle; the button will illuminate
- Come to a complete stop and press the start/stop button to turn off the vehicle
Tire Fill Alert
Standard
- Provides visual and audible alerts outside the vehicle when inflating an under inflated tire to the recommended tire pressure
- Requires vehicle to be started and driver door closed
60/40 split-folding rear seat
Standard
- Can fold one or both sides down
- Adds cargo and passenger carrying versatility to your vehicle
HD Rear Vision Camera
- Shows you a high-resolution digital image of the area directly behind your vehicle when you're in Reverse at low speeds1
- Selectable dynamic guidelines laid over the display image assist in parking maneuvers by showing the vehicle's path
- This may help you park and avoid nearby objects
Standard
Remote panic alarm
Standard
Automatic climate control
Standard
- Automatically maintains a selected temperature
Remote Start
Standard
- Precondition your vehicle's cabin remotely and step into a comfortably warmed or cooled vehicle, depending on the weather and your preset preferences
- Locks doors and turns on parking lamps while the vehicle is preconditioning
- Activates automatic heated steering wheel and heated and ventilated front seats, if equipped
- With the vehicle plugged in, can draw available energy from the charger to conserve battery charge
Rear cargo cover
Standard
- Helps keep items out of sight
- Removable
Sport Mode
Standard
- 2 drive modes consisting of Normal and Sport
- Normal mode is for most everyday driving situations
- Sport mode gives the accelerator pedal quicker response and enhances steering feel
False cargo floor
Standard
- Allows for additional storage in your cargo area
- Provides a long, nearly flat surface for long items when the rear seats are folded down
Wireless Apple CarPlay/Wireless Android Auto capability for compatible phones
Standard
- Apple CarPlay vehicle user interface is a product of Apple and its terms and privacy statements apply. Requires compatible iPhone and data plan rates apply. Apple CarPlay is a trademark of Apple Inc. Siri, iPhone and Apple Music are trademarks for Apple Inc, registered in the U.S. and other countries.
- Android Auto vehicle user interface is a product of Google and its terms and privacy statements apply. Requires the Android Auto app on Google Play and a compatible Android smartphone. Data plan rates apply. You can check which smartphones are compatible at g.co/androidauto/requirements. Android, Google Play and Android Auto are trademarks of Google LLC.
Lighting, rear cargo compartment lamp
Standard
Tire Pressure Monitoring System
Standard
- Monitors the pressure in each tire and alerts you if there is a low-pressure condition in one or more of the tires
Teen Driver
Standard
- This configurable feature lets you activate customizable vehicle settings associated with a key fob to help encourage better driving behavior
- It can limit certain vehicle features, and automatically turns on certain safety systems if vehicle is equipped
- An in-vehicle report card gives you information on driving habits and helps you to continue to coach your new driver
Lighting, interior, dual reading
Standard
Rear seat heat duct
Standard
- Delivers warm air to rear seat passengers
Steering-wheel mounted controls
- Allow the driver to easily operate the infotainment system, phone interface, Driver Information Center and Regen on Demand™1controls
Standard
6-way manual driver seat
Standard
Remote Keyless Entry
Standard
- Allows you to lock and unlock doors of the vehicle with the key fob
- Driver's door or all doors unlock at the touch of a button
Driver and front passenger visors
Standard
- Include covered mirrors
- Extendable for enhanced shading coverage
Deluxe steering wheel
Standard
- Flat-bottom with Black Chevrolet bowtie
Chevrolet Infotainment 3 Plus system with 10.2" diagonal HD color touch-screen
1 Go to my.chevrolet.com/learnAbout/bluetooth to find out which phones are compatible with the vehicle. Full Bluetooth feature functionality varies by device, model, and software version.
- Multi-touch display and AM/FM stereo
- Bluetooth®1 audio streaming for music and select phones with two active devices
- Wireless Apple CarPlay™ capability for compatible phones2
- Wireless Android Auto™ capability for compatible phones3
- Cloud4 connected personalization for select infotainment and vehicle settings
- In vehicle apps capable
- Voice recognition and pass-through of voice commands to compatible phones
2 Vehicle user interface is a product of Apple and its terms and privacy statements apply. Requires compatible iPhone and data plan rates apply. Apple CarPlay is a trademark of Apple Inc. Siri, iPhone and Apple Music are trademarks for Apple Inc, registered in the U.S. and other countries.
3 Android Auto vehicle user interface is a product of Google and its terms and privacy statements apply. Requires the Android Auto app on Google Play and a compatible Android smartphone. Data plan rates apply. You can check which smartphones are compatible at g.co/androidauto/requirements. Android, Google Play and Android Auto are trademarks of Google LLC.
4 Requires Connected Access, active connected services or OnStar plan. Services are subject to user terms and limitations and vary by vehicle model. See onstar.com for details.
Standard
Cruise control
Standard
- Maintains a selected speed while driving
SiriusXM® with 360L 3-month Trial Subscription
1 If you decide to continue service after your trial, the subscription plan you choose will automatically renew thereafter and you will be charged according to your chosen payment method at then-current rates. Fees and taxes apply. See the SiriusXM Customer Agreement at www.siriusxm.com for complete terms and how to cancel. All fees, content, features, and availability are subject to change. ©2021 Sirius XM Radio Inc. SiriusXM, Automatic, Pandora and all related logos are trademarks of SiriusXM Radio Inc. and its respective subsidiaries.
- Enjoy a 3-month Platinum Trial Subscription and enjoy the full SiriusXM with 360L experience1
- This vehicle is equipped with SiriusXM with 360L. This advanced in-car technology will guide you to the most SiriusXM channels, shows and exclusive content for a ride that's uniquely you, with personalization features to make discovering your perfect soundtrack easier than ever before
- For the full SiriusXM with 360L experience, a Platinum Plan is required. If you subscribe to a lower package, certain features of 360L will not be available
- With the Platinum Plan you can listen when outside of your vehicle on the SXM App
- Some features, including streaming content and listening recommendations require GM connected vehicle services
Standard
6-way manual front passenger seat
Standard
Seat trim, Cloth
Standard
Charging-only USB ports
1 Not compatible with all devices.
- 1 Type-A and 1 Type-C USB ports1 located on the rear of the center console
- Allows access for rear passengers
Standard
Wi-Fi® hotspot capable
Standard
12-volt power outlet
Standard
- Located at the front of the center console
Lock control, liftgate, power remote lock/unlock
Standard
Power door locks
SHOW LESS
- Programmable
- Allows you to lock and unlock doors easily whether it's from the driver or front passenger seat, from outside using the key fob or exterior front door handle buttons
- Lockout protection helps you avoid locking keys in the vehicle
Exterior
Standard
17" Silver painted aluminum wheels
Standard
Signature LED daytime running lamps with sequential turn signals
Standard
- Provide a signature style, and increased visibility to other drivers
- Daytime running lights illuminate whenever your vehicle is on and not in Park
Solar-absorbing glass
Standard
- Helps minimize the effects of solar rays entering the cabin
- Assists in maintaining a more comfortable interior temperature
LED headlamps
Standard
- Help improve down-the-road visibility in low-light conditions
Automatic on/off headlamps
Standard
- Setting the control to "Auto" turns on the headlamps to normal low-beam brightness when sensors detect a certain level of darkness, along with the taillamps, license plate lamp and other exterior lights
LED tail lamps
Standard
- Help improve visibility in low-light conditions
- Includes LED signature lighting
- LED taillamps with LED stop lights
Roof-mounted side rails
Standard
- Enhances the appearance of your vehicle
- With the available cross rails, allows you to secure cargo directly to the top of your vehicle
Body-color accented heated power outside mirrors with integrated turn signal indicators
Standard
- Heated feature helps clear away ice and fog
- Integrated turn signal indicators help communicate your intention to change lanes
- Manual folding
Michelin® Energy™ Saver all-season tires with Selfseal® technology (P215/50R17)
1 Up to 1/4" diameter with a loss of less than 15 PSI per week.
- Offers low-rolling resistance, which helps maximize range
- Designed to self-seal in the event of a minor tread puncture, such as that made by a nail1
SHOW LESS
Safety
Standard
Standard
Standard
StabiliTrak, electronic stability control system with traction control
Standard
- Automatically helps enhance control, particularly during emergency maneuvers, by adjusting the brakes and drive motor torque to help you stay on your intended path
- Includes Traction Control that detects wheel slippage and applies brake pressure and/or reduces drive motor torque to help the driver maintain control when accelerating on wet or snow-covered roads
Pedestrian Safety Signal
Standard
- Automated external sound generated at low speeds to help alert pedestrians of an approaching electric vehicle
Tire Fill Alert
Standard
Standard
Teen Driver
SHOW LESS
Mechanical
Standard
Standard
Electronic parking brake
Standard
- Takes the place of the manual foot actuated parking brake
- Activated by the simple touch of a switch and can be operated even when the vehicle is turned off
- Brake is automatically set if the system senses the vehicle is parked on a steep incline
Electric drive unit
1 Based on initial vehicle movement.
- 200 hp (150 kW) of motoring power, 266 lb-ft (360 N-m) of motoring torque
- 0-601 in 7.0 seconds
Standard
4-wheel antilock disc brakes
Standard
- Help reduce wheel lockup and maintain steering control during hard braking on most slippery surfaces
Dual Level Charge Cord
1 Actual charge times will vary based on battery conditions, vehicle settings and outside temperature.
- Changeable attachment plugs for 120-volt (Level 1) and 240-volt (Level 2) charging capability
- Plug into a standard 120-volt three-prong outlet for Level 1 charging or change ends to plug into a 240-volt NEMA 14-50 outlet and charge at up to 7.7kW Level 2 charging
- About 4 miles of range per hour of charge1 for Level 1 charging2
- About 25 miles of range per hour of charge1 for Level 2 charging
2 Using Level 1 Cord Limit of 12 amps in vehicle Charging Settings.
Standard
11.5 kW capable onboard charging module
1 Actual charge times will vary based on battery conditions, output of charger, vehicle settings and outside temperature.
- About 37 miles of range per hour of charge1 with a 240-volt 48-amp charging unit2
2 Professional installation required. 11.5 kW charger not currently available through Chevrolet. Contact your dealer for more information.
Standard
DC Fast Charging capability
1 Actual charge times will vary based on battery starting state of charge, battery condition, output of charger, vehicle settings and outside temperature.
- Allows you to charge your Bolt EUV at publicly available DC Fast Charging stations
- Charges the battery up to 95 miles in 30 minutes1
Standard
Lithium-Ion Propulsion Battery
Standard
- Rechargeable Energy Storage System, includes liquid thermal management system with automatic activation
Keyless start, push-button
Standard
Electronic Precision Shift with One Pedal Driving mode
- Button and switch-based drive unit interface
- Includes a button that allows for One Pedal Driving that stays active between drives
- One Pedal Driving increases the regenerative braking effect and helps you capture energy and sends it back to the battery
- When you want to speed up, press your foot down like you normally would
- When you want to slow down, just lift your foot off the accelerator1
Standard
Recovery hook, front
Standard
Recovery hook, rear
SHOW LESS
Warranty
Bumper-to-Bumper Limited Warranty
3 Years/36,000 Miles
Battery and Electric Components Coverage /Available Courtesy Transportation
8 Years/100,000 Miles
Corrosion Limited Warranty
Rust-Through
6 Years/100,000 Miles
SHOW MORE
Dimensions
Front Head Room
40.0 in
Height, Overall
63.6 in
Length, Overall
169.5 in
Liftover Height
30.3 in
Track Width, Front
59.4 in
Track Width, Rear
59.4 in
Width, Max w/o mirrors
69.6 in
Front Hip Room
51.3 in
Second Head Room
37.80 in
Second Leg Room
39.10 in
Base Curb Weight
3,680 lbs
Second Hip Room
50.20 in
Cargo Volume with Rear Seat Up
16.30 ft³
Cargo Volume with Rear Seat Down
56.90 ft³
Wheelbase
105.30 in
Front Shoulder Room
54.60 in
Min Ground Clearance
5.60 in
Passenger Capacity
5
Passenger Volume
96.50 ft³
Front Leg Room
44.2 in
Second Shoulder Room
51.9 in
SHOW LESS
Fuel Efficiency
EPA MPG Equivalent - City
125
EPA MPG Equivalent - Hwy
104
EPA MPG Equivalent - Combined
115
Estimated Battery Range
247 mile
Warranty
No idea what items can go wrong on an EV vs. an internal combustion car - except for the battery [pack]. If the battery pack that drives the car is under warranty for 8 years/ 100,000 miles, that may be enough to change some diehard gasoline engine holdouts like me.
However, I still prefer the roar of a V12 Turbo found in vehicles like the BMW high-end 7-series or the Mercedes Maybach S580 (which only starts at $212,050 !)
Mercedes Maybach S580 - Mercedes-Maybach S-Class Luxury Sedan
