[10v1709b16299 x64] BSOD when using two monitors
fadinzr
Hello all,
I am facing issue as I am using two monitor at same time to extend the screen.
I didn't have this Issue before, but I am not exactly sure what caused this issue. I am assuming windows 10, because I don't recall
having this sort of problem in previous windows.
I tried different versions of my video card drive, and this didn't fix it.
Now, I am using single display, which is working just fine.
I wonder what is the main cause for this issue(bad graphic card, drive incompatibility issues, or system conflict)?
Thanks for your helpView attachment SysnativeFileCollectionApp.zipView attachment Speccy report - FADI-PC.pdfView attachment Speccy report - FADI-PC.pdf
Re: BSOD when using two monitors
You are running a 3 year-old video driver from 2015 -
nvlddmkm.sys Fri Jan 30 18:44:08 2015 (54CC1748)
Have you tried the most recent version?
Driver Reference Table (DRT)
If the updated drivers don't fix the BSODs, it is likely that one or both of the video cards are bad. Try swapping out the card with a known good card.
Regards. . .
jcgriff2
Regards. . .
jcgriff2
I tried the latest and oldest available versions and had same issue. At this time I don't have a second graphic card. I guess I will operate with one display.
