[SOLVED] [10v1703b15063 x64] Diagnostic tools stopped working. Upd. (v1709b16299) didn't help.
LXM
Well-known member
Hello; I hope I haven't missed anything relevant, looking thru the forum before posting this issue, as it is a variation of the trouble with (I guess) fdeploy.dll, fde.dll, gpedit.dll, gptext.dll covered in several threads already here and elsewhere. Most occurences got solved by repair installs (on older systems); more tenacious instances by per individualized applications of SFCFix, the beacon which drew me to this place. Sadly, I haven't been able to get SFCFix to do an analysis on my end; otherwise I would have already included the information provided by that.
Situation
After having messed up my system (details further below), I seem to have managed to get most of it back to working nominally per installation of the latest upgrade available from Access Denied - so far, so nice.
  • [*=1]DISM /Online /Cleanup-Image /Restore Health finished successfully after that according to prompt.
    However:
    [*=1]sfc /scannow still complains about corrupted files (which was part of what caused me to go thru the upgrade in the first place).
    [*=1]The corrupted files are the 4 listed above, according to cbs.log.
Observable effects (at least the ones I am currently aware of:)
  • [*=1]Windows diagnostic services are inoperable, coming back with the famous (German version of) "The problem cannot be diagnosed due to a problem" (potentially not translated verbatim here; my system runs in German). As far as I could ascertain so far, this affects all problem-solving subtools coming with Windows (under System/Settings > TroubleShooting or whatever it's called on English versions; you'll probably know which one/s I mean).
Where I'm stuck now
  • [*=1]Looking for help I found your forum and SFCFix and tried running it for analysis. But I must be doing something wrong, since I only get this as result:
    Start time: 2017-09-28 11:35:11.553
    Microsoft Windows 10 Build 15063 - amd64
    WARNING: Components hive failed load test and may be corrupt.
    WARNING: Components hive failed final reload test with error code ERROR_PRIVILEGE_NOT_HELD and may be corrupt.
    Finish time: 2017-09-28 11:35:41.947
    I have tried launching it from various locations (c:\ as well as C:\Windows\Logs\CBS), from an elevated cmd prompt as well as thru a "Run As Administrator" pointer; all to no avail. The CBS.log does exist tho, and I can provide it, if this should shed relevant light.
    How should I be running this to get meaningful results to share here?
    Thank you very much for your help in advance + kind regards;
    LX
Re: [W10STDv1703b15063 x64] Diagnostic tools stopped working. Updating didn't help.
Hi and welcome to Sysnative! Sorry about the delay. Are you still in need of assistance?
Hello + sadly, yes. Thank you for getting back to me. I'd appreciate what help I can get. Cheers.
SFC Scan
Retrieve Components Hive
4. The file will likely be too large to upload here so please upload toa file sharing service and just provide the link here.
What happens if you check for updates and try to install them?
Also, what updates are offered?
it appears this stopped working some time ago. :/ I'm seing a message informing me, that "there were problems but that Windows will keep trying"; the updates currently listed as queued are
  • 2017-06 Update für Windows 10 Version 1703 für x64-basierte Systeme (KB4022405) – Fehler 0x800706be
  • 2017-10 Kumulatives Update für Windows 10 Version 1703 für x64-basierte Systeme (KB4041676) – Fehler 0x800706ba
  • 2017-10 Sicherheitsupdate für Adobe Flash Player für Windows 10 Version 1703 für x64-basierte Systeme (KB4049179) – Fehler 0x800706ba
(where "Fehler" is German for "error" :/ ) I'm assuming the KB-codes will nonetheless inform you which update packages are concerned, right? Cheers -
Download the October Quality Rollup from this link, and try installing it. If it fails, please provide CBS.log
Hello, the MSU stopped after conducting a search for updates on my computer, giving the message: "The update is not apt for your computer".
As per your request, I ran SFC again after this attempt. Please find the latest version of CBS log attached. View attachment cbs-2017-11-12-(10-29).zip
Are you willing to try upgrading to the latest W10 build?
Please boot your computer into a Clean Boot state and do the following:
1. Download the Media Creation Tool to your desktop. Go ahead and run this. Note: Click the Download tool now button when you are at this link.
2. Accept the license agreement
3. Keep the default which is to Upgrade your PC and click Next.
4. Go ahead and run this through and let me know when complete.
Doing it this way will keep all your data and programs intact. As always though, make sure you have a backup of any critical data in case something unexpected happens.
Let me know how it goes.
Hello; i had done this before I came posting here; see initial post in which it a.o. says >>I seem to have managed to get most of it back to working nominally per installation of the latest upgrade available from Access Denied<< which .did. mitigate much of my plight, just not its entirety. That was around Sept 28th, tho. Has there been a newer release since? Do you think repeating will improve further?
A new windows 10 build has been released in the meantime. I think it's worth a shot.
OK, *sigh* ;) - I'll give it a go and let you know how it went. If you hear not back from me, we have imploded, my machine and I :-P Cheers!
OK, did that and survived :) Apparently a little somethign changed: When I check for Windows Updates now, only 2 remain failing:
  • 2017-10 Sicherheitsupdate für Adobe Flash Player für Windows 10 Version 1709 für x64-basierte Systeme (KB4049179) – Fehler 0x800706be (this one was failing earlier, too, see above)
  • Update für Adobe Flash Player unter Windows 10 Version 1709 für x64-basierte Systeme (KB4051613) – Fehler 0x800706ba (that's a new one)
The original observable effect >>Windows diagnostic services are inoperable, coming back with the famous (German version of) "The problem cannot be diagnosed due to a problem" (potentially not translated verbatim here; my system runs in German). As far as I could ascertain so far, this affects all problem-solving subtools coming with Windows (under System/Settings > TroubleShooting or whatever it's called on English versions; you'll probably know which one/s I mean).<<
persists.
Great, SFC is clean. Attempt the updates again, and when they fail attach CBS.log (Do not run SFC before sttaching!) Just try them, and attach if/when they fail!
