[10] Help with WU Error 0x80070246
angelarches
Been trying to update but this always comes up. Can anyone help me? I can't even install some apps because of this I also tried using the troubleshoot.
Re: Help with Windows Update Error 0x80070246 Windows 10
Hello and welcome to Sysnative!
Retrieve Components Hive
4. The file will likely be too large to upload here so please upload toa file sharing service and just provide the link here.
Download COMPONENTS.zip
2. Attempt to run DISM just like you have in the past.
3. Stop Process Monitor as soon as DISM fails. You can simply do this by clicking the magnifying glass on the toolbar as shown below.
Download Logfile.zip
Hi, I have reviewed both your hive and your captured log.
Your registry is very corrupt. This would be no quick fix and it would take days. Before I start preparing the first batch of fixes for you, I need to know how you want to proceed. Are you willing to do a repair install, which would be a quicker way of resolving this or do you want to try and fix this?
Thank you for your fast response! What would you suggest?
Well, the fastest way is a Repair Install, so I'd suggest you do that. Your data and programs will be kept intact.
