Page 2 of 2 First 12
  1. #21
    Administrator
    Windows Update Instructor
    Security Analyst
    Join Date
    Oct 2014
    Re: Help! DLL problem.
    Hi David -
    Please do the following which should get you fixed up. You will have to download SFCFix.exe and SFCFix.zip to a USB flash drive or some other portable media and then copy these files to the desktop of your "sick" machine.
    Step#1 - SFCFix Script
    Step#2 - SFC Scan
    Items for your next post
    1. SFCFix.txt
    2. CBS.txt
    Attached Files Attached Files
    Corrine says thanks for this.
    • Ad Bot
      advertising
      Beep.
  2. #22
    Ok So im on the sfc scan and it is stuck at 18% this has never append before is this normal?
  3. #23
    Administrator
    Security Analyst
    Join Date
    Oct 2014
    It's not abnormal for this to take a little while to run. While this is running, would you be able to post the SFCFix.txt?
  4. #24
    Start time: 2015-10-21 20:38:25.803
    Microsoft Windows 8.1 - amd64
    Finish time: 2015-10-21 20:41:24.489
    ----------------------EOF--------------------
  5. #25
    Administrator
    Security Analyst
    Join Date
    Oct 2014
    It doesn't appear you did Step#1 properly. You need to ensure you drag and drop the zip file over the top of the SFCFix.exe file as follows.
  6. #26
    Let Me Do it again, is it possible for me to do it again while the sfcscan is still running?
  7. #27
    Administrator
    Security Analyst
    Join Date
    Oct 2014
    It's possible yes but the scan is invalid right now so I would stop it. Close the command prompt or worst case reboot if you need to. Let's just do step#1 first. Once we confirm that works we will move on.
  8. #28
    Ok so I'm doing that know when I dragged the winrar in the exe it prompted me to restart should that happen?
  9. #29
    Administrator
    Security Analyst
    Join Date
    Oct 2014
    Yes, if a file was in use then it would prompt for a reboot. Go ahead. Once reboot, please post the SFCFix.txt log. Thanks.
  10. #30
    Start time: 2015-10-21 20:59:56.273
    Using .zip script file at C:\Users\David's PC\Desktop\SFCFix.zip [0]
    Successfully took permissions for file or folder C:\WINDOWS\Winsxs\wow64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_a7e0cfc0f233a685\dnsapi.dll
    Successfully took permissions for file or folder C:\WINDOWS\Winsxs\amd64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_9d8c256ebdd2e48a\dnsapi.dll
    Successfully copied file C:\Users\David's PC\AppData\Local\niemiro\Archive\Winsxs\wow64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_a7e0cfc0f233a685\dnsapi.dll to C:\WINDOWS\Winsxs\wow64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_a7e0cfc0f233a685\dnsapi.dll.
    The file \\?\C:\WINDOWS\Winsxs\amd64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_9d8c256ebdd2e48a\dnsapi.dll is in use and must be replaced over a reboot.
    Successfully pended file for replace over reboot: \\?\C:\WINDOWS\Winsxs\amd64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_9d8c256ebdd2e48a\dnsapi.dll
    Successfully restored ownership for C:\WINDOWS\Winsxs\wow64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_a7e0cfc0f233a685\dnsapi.dll
    Successfully restored permissions on C:\WINDOWS\Winsxs\wow64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_a7e0cfc0f233a685\dnsapi.dll
    Reboot:: directive completed successfully.
    PostRebootCorruptionDetection::
    No hash verification failures detected.
    PostRebootCorruptionDetection:: directive completed successfully.
    PostRebootRestorePermissions::
    Successfully restored ownership for C:\WINDOWS\Winsxs\amd64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_9d8c256ebdd2e48a\dnsapi.dll
    Successfully restored permissions on C:\WINDOWS\Winsxs\amd64_microsoft-windows-dns-client-minwin_31bf3856ad364e35_10.0.10240.16384_none_9d8c256ebdd2e48a\dnsapi.dll
    PostRebootRestorePermissions:: directive completed successfully.
    Finish time: 2015-10-21 21:02:03.117
  11. #31
    Administrator
    Security Analyst
    Join Date
    Oct 2014
    That worked! Let's do the following now. You may have internet now. If not, just download this file to your USB drive and transfer.
  12. #32
    Ok, I will continue this tomorrow.
  13. #33
    Also one thing, after I did the SFC thing I did the next step sfc /snannow. Was it suppose to scan my computer or have a bunch of stuff and commands in the cmd?
  14. #34
    Administrator
    Security Analyst
    Join Date
    Oct 2014
    It would have started a scan on your computer. You would have seen something like the following in the command-prompt window until it was complete. I think that's what you are asking.
    Verification 4% complete.
  15. #35
    Yes! It pasted 24% when I left and looked to deem be working but I am currently nothing home right know.
  16. #36
    YES!!! It's working when I got home I was at 100% and it said it found corrupted files and it repaird them and everything is working!
  17. #37
    Administrator
    Security Analyst
    Join Date
    Oct 2014
    Excellent. If you have no other questions I'll go ahead and close this topic.
Similar Threads
  1. i have a few problem in my SFC
    By renji in forum Windows Update
    Last Post: 05-27-2015, 04:41 AM
  2. [C++] CodeJam Problem - 2010 (Problem B. Reverse Words)
    By AceInfinity in forum Programming
    Last Post: 03-23-2014, 08:31 PM
  3. CBS.log Problem
    By CosmicHIRO in forum Windows Update
    Last Post: 01-04-2013, 12:06 PM
  4. Hello the same problem
    By Yordan in forum BSOD, Crashes, Kernel Debugging
    Last Post: 12-27-2012, 06:48 PM
Log in
Log in
