A are Well-known member Joined Aug 20, 2018 Posts 75 Dec 4, 2018 #1 hi, what can ı Attachments wed.JPG 32.4 KB · Views: 9
Corrine Administrator, Microsoft MVP, Security Analyst Staff member Joined Feb 22, 2012 Posts 12,073 Location Upstate, NY Dec 4, 2018 #2 Personally, I'd find a different application and not one that requires something that old -- especially when it comes to Java, which I absolutely refuse to install on my computer. JDK 6 has reached end of public updates with the last release of that plugin being 1.6.0_45. (Java SE 6 Update Release Notes)
plodr Sysnative Staff, Contributor Staff member Joined Sep 11, 2016 Posts 997 Location In front of a computer Dec 5, 2018 #3 From searching and translating Google Translate this looks to be a health care provider. Is that correct? If so, it might not be possible to use another program. Is there another way you can get the forms you need? Obviously installing an older version of Java will put your computer at risk. You need to contact your health care provider and tell them, forms should be available as downloadable pdf forms that do not require installing out-dated or for that matter ANY version of Java. Like Corrine, Java has not been on our computers at home for a long time.
