Corrine Administrator, Microsoft MVP, Security Analyst Staff member Joined Feb 22, 2012 Posts 12,077 Location Upstate, NY Jul 18, 2018 #1 Oracle released the scheduled critical security updates for its Java SE Runtime Environment software. The critical patch update contains 8 new security fixes for Oracle Java SE. All of these vulnerabilities may be remotely exploitable without authentication, i.e., may be exploited over a network without requiring user credentials. Update If Java is still installed on your computer, it is recommended that this update be applied as soon as possible due to the threat posed by a successful attack. Java SE 8u181 Java™ SE Development Kit 8, Update 181 Release Notes Java SE Runtime Environment 8 - Downloads Java SE 10.0.2 (x64-bit only) http://www.oracle.com/technetwork/java/javase/10-0-2-relnotes-4477557.html Java SE Runtime Environment 10 - Downloads Note: UNcheck any pre-checked toolbar and/or software options presented with the update. They are not part of the software update and are completely optional. Preferably, see the instructions below on how to handle "Unwanted Extras". Oracle Java SE Risk Matrix
