Page 4 of 4 First 1234
  1. #61
    Re: [7SP1 x64] BSOD on Ryzen. TEMP FIX: changed ram speed.
    Quote Originally Posted by softwaremaniac View Post
    I'd advise you to get it serviced because it's still under warranty.
    NEW ADDITION
    While not solved, I can trigger the problem easily now! I use TMPGEnc Authoring to author blurays. Whenever I author I get the BSOD with the same error on pci.sys. I believe it's related to the AMD video card and/or its drivers. Does this help fix the overlying issue?
    • Ad Bot
      advertising
      Beep.
  2. #62
    Moderator
    BSOD Kernel Dump Analyst
    Windows Update Instructor
    softwaremaniac's Avatar
    Join Date
    Oct 2014
    Croatia
    Age
    23
    • specs System Specs
      • Motherboard:
        ASUS MAXIMUS ROG HERO X
      • CPU:
        Intel Core i7-8700K 3.7GHz
      • Memory:
        Crucial 2x8GB DDR4 2666 MHz
      • Graphics:
        Gigabyte GTX 1080 G1 Gaming 8 GB
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
        WD Caviar Black 1TB SATA III 7200rpm, WD Caviar Black 6TB SATA III 7200rpm
      • Disk Drives:
        Samsung 960 Evo 256GB NVME PCIe
      • Power Supply:
        Corsair HX 750W 80+ Platinum
      • Case:
        Fractal Design Define R6
      • Cooling:
        Noctua NH-D14
      • Display:
        Philips Brilliance BDM4065UC 4K 3840x2160
      • Operating System:
        Windows 10 Pro 1803 x64
    Can you borrow another card to test with? Really, the easiest way is to get it serviced, because it's under warranty.
    Users needing assistance: If I haven't replied to your thread within 48 hours, please send me a Personal Message.
    Windows Update Academy Trainees: If I haven't replied to your CMF thread within 24 hours, please send me a Personal Message.
  3. #63
    Quote Originally Posted by ldeveraux View Post
    NEW ADDITION
    Try next steps:
    1) Update your BIOS to last version
    2) Go to AMD PSB
    3) Set up PCI version as 2.0
  4. #64
    There's nothing wrong with the board; I already exchanged it once, I'm not doing it again. I got completely fed up with the 398734 issues I was having so I tried another in-place upgrade. That really just made matters worse. So now I'm a not-proud member of the Windows 10 club. Once I upgraded the OS, I authored the bluray perfectly. I have no reason to believe the board or graphics card have anything to do with the underlying issue. Sounds like there's a reason they don't want you to run Windows 7 on a Ryzen part...
  5. #65
    Well, for me steps that i mentioned in prev post seems to be working just fine even with OC.
    Reason is simply , they don't wanna you to stay on something, that not sends everything you do by default
  6. #66
    Moderator
    Join Date
    Oct 2014
    Croatia
    Age
    23
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
      • Case:
      • Cooling:
        Noctua NH-D14
      • Display:
      • Operating System:
    I can believe that. The manufacturers and the MS are trying to get as many people as they can to use Win10.
Similar Threads
  1. Ryzen on windows 7 HELP! LATENCY GPU
    By x58haze in forum Windows 7 | Windows Vista
    Last Post: 12-25-2017, 02:09 PM
  2. [7SP1 x64] weird no-bugcheck BSOD's
    By Pablo in forum BSOD, Crashes, Kernel Debugging
    Last Post: 10-27-2017, 10:49 AM
  3. [Win8] High DPC by storport.sys. AMD Ryzen 7 1700 8Core, 16GB RAM.
    By defoliation in forum Windows 8 | Windows RT
    Last Post: 09-21-2017, 10:10 AM
  4. Replies: 12
    Last Post: 09-18-2017, 11:56 AM
  5. Internet Speed slow unless running Qualcomm Atheroes Speed test
    By WarlordEXE in forum Windows 8 | Windows RT
    Last Post: 08-11-2014, 03:05 AM
Log in
Log in
