Page 3 of 4 First 1234 Last
  1. #41
    Moderator
    BSOD Kernel Dump Analyst
    Windows Update Senior Analyst
    softwaremaniac's Avatar
    Join Date
    Oct 2014
    Croatia
    Age
    22
    • specs System Specs
      • Motherboard:
        ASUS MAXIMUS ROG HERO X
      • CPU:
        Intel Core i7-8700K 3.7GHz
      • Memory:
        Crucial 2x8GB DDR4 2666 MHz
      • Graphics:
        Gigabyte GTX 1080 G1 Gaming 8 GB
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
        WD Caviar Black 1TB SATA III 7200rpm, WD Caviar Black 6TB SATA III 7200rpm
      • Disk Drives:
        Samsung 960 Evo 256GB NVME PCIe
      • Power Supply:
        Corsair HX 750W 80+ Platinum
      • Case:
        Fractal Design Define R6
      • Cooling:
        Noctua NH-D14
      • Display:
        Philips Brilliance BDM4065UC 4K 3840x2160
      • Operating System:
        Windows 10 Pro 1803 x64
    Re: [7SP1 x64] BSOD on Ryzen Desktop. FIX: CHANGED MEMORY SPEED
    Yes, the missing drivers were the chipset ones. You don't have the latest BIOS update? Please flash it.
    If I haven't replied to your thread within 48 hours, please send me a Personal Message.
    • Ad Bot
      advertising
      Beep.
  2. #42
    xilolee's Avatar
    Join Date
    Dec 2013
    World, Europe, Italy
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
        Windows 10 Home/Standard x64
    Quote Originally Posted by ldeveraux View Post
    I don't have a setting for PSP, as it's just been authorized for AMD UEFI, and I don't have a new BIOS update for my X370. But the 3 other settings you mentioned are correct.
    Ok, let's see how it behaves...
  3. #43
    Quote Originally Posted by softwaremaniac View Post
    I'm pretty sure I have the latest, 3.40. How do I ensure my chipset drivers stay up to date, other than checking AMD's website periodically?
    Quote Originally Posted by xilolee View Post
    Running well so far, we'll see!
  4. #44
    xilolee's Avatar
    Join Date
    Dec 2013
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
    There shouldn't be any other problems about it.
    You can check it once a year.
    Or use a driver updater software to let you inform about new drivers updates.
    Just to inform you, but not use their links: go directly to the manufacturer website.
    It seems kcsoftwares dumo free is quite precise (about updates).
    Check this topic for more details (click).
  5. #45
    Re: [7SP1 x64] BSOD on Ryzen. TEMP FIX: changed ram speed.
    I've been using DUMO for a bit now; I find it difficult to find the newer versions of the drivers it references. Check the attached screenshot showing what it suggests I should still update. Which of these is the Chipset Drivers by the way?
    Based on your linked thread, I'm going to give the Iobit Driver Booster a shot too...
    [7SP1 x64] BSOD on Ryzen. TEMP FIX: changed ram speed.-untitled-jpg
  6. #46
    xilolee's Avatar
    Join Date
    Dec 2013
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
  7. #47
    Right, so I installed those and restarted, which reactivated my previously disabled built in WIFI. This caused the same BSOD with ntoskrnl.exe and pci.sys! I think I'm just going to leave the MOBO WIFI disabled, I have a feeling it's causing the problems.
  8. #48
    xilolee's Avatar
    Join Date
    Dec 2013
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
    Try previous Version: 20.0.2 (Previously Released) Date: 10/16/2017 Download Intel(R) PROSet/Wireless Software and Drivers for Windows 7*
    Reintroduced in newer version?
    Windows* stop error (BSOD) may occur while connected to a wireless network. Windows 10®, Windows* 8.1, Windows* 7
  9. #49
    So the BSOD doesn't occur in the 20.0.2 driver version? That's weird. I installed it, but the driver version for the AC 3168 still claims it's 19.10.9.2
  10. #50
    xilolee's Avatar
    Join Date
    Dec 2013
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
    Not sure if the BSOD should happen or not with that version, just try it (I can't try it in first person, because obviously I don't have your exact configuration).
    Latest Intel PROSet/Wireless 20.10.2: Driver version = 19.10.10.2 for Windows 7 for 3168 (16 Oct 2017)
    20.0.2: Driver version = 19.10.9.2
    19.70.0: Driver version = 19.10.6.2
    19.60.0: Driver version = 19.10.5.3
    19.50.0: Driver version = 19.10.4.1
    19.50.0: Driver version = 19.10.3.6
    19.20.3: Driver version = 19.10.2.1 (it seems you was using this)
    19.20.0: Driver version = 19.10.1.2
    19.10.0: Driver version = 19.10.0.9
    19.1.0: Driver version = 19.1.0.4
    19.0.1: Driver version = 19.0.1.1 (19 Jul 2016)
  11. #51
    Went to burn a bluray disc (heave forbid I try something like that!) and got another BSOD. I'm going to permanently disable the onboard WIFI to rule it out in the future. I attached the zip file from the Sysnative app, the dmp itself, and the txt explanation from BlueScreenView.
    SysnativeFileCollectionApp.zip010618-15724-01.zipdump.txt
  12. #52
    xilolee's Avatar
    Join Date
    Dec 2013
      • Manufacturer:
        XILOLEE.com
      • Model Number:
        XILO
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
      • Case:
        Sharkoon VG4-S
      • Cooling:
      • Display:
      • Operating System:
    According to dumo, your system misses only the newer standard ahci 1.0 sata controller.
    Go to device manager, individuate it and right-click --> update driver.
    Other downloads (from intel):
    Intel Network Adapter Driver for Windows 7 v20.2 Jul 15 15, for Intel Ethernet Controller I211-AT (click)
    There's also this more recent one, but I211-AT isn't present between the supported products: Intel Ethernet Adapter Complete Driver Pack v22.10 Dec 7 17 (click)
    Intel Wireless Bluetooth for Windows 7 v19.70.0 Jul 18 17 (click)
    Other downloads (from asrock):
    Intel Bluetooth driver ver:19.10 2017/3/13
    Intel Lan driver ver:21.1 2017/3/13
  13. #53
    I'm far less concerned right now with getting the onboard WIFI working. I tried to auto-update in device manager and it claims it's recent. I have the PCIE Wifi that's better/faster/more reliable, so I could leave onboard disabled. I'm more concerned why this BSOD occurs with DRIVER_IRQL_NOT_LESS_OR_EQUAL. it happened again this AM on boot...
  14. #54
    Just for grins, I ran "sfc /scannow" which said it found corruption which it fixed. Check the CBS.log attached, hope it helps!
    CBS.zip
  15. #55
    Moderator
    Join Date
    Oct 2014
    Croatia
    Age
    22
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
      • Case:
      • Cooling:
        Noctua NH-D14
      • Display:
      • Operating System:
    Run it once again.
  16. #56
    Run it once again.
    It hasn't found any integrity violations. I have at least one BSOD a day at this point. Last it happened when I tried to play Call of Duty. The time before that, I was listening to Spotify. It's seemingly completely random, and nothing has fixed it. I've had the onboard WIFI disabled this entire time, so that's certainly not it. So with no changes making affect, I'm going to downgrade my BIOS to 2.50 and see if that does anything. I'm all out of patience and ideas.
  17. #57
    Moderator
    Join Date
    Oct 2014
    Croatia
    Age
    22
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
        Asus Xonar DSX
      • Hard Drives:
      • Disk Drives:
      • Power Supply:
      • Case:
      • Cooling:
        Noctua NH-D14
      • Display:
      • Operating System:
    I'd advise you to get it serviced because it's still under warranty.
  18. #58
    Which, the motherboard? I already sent it back once, this is the replacement. I'm guessing this is the reason they don't want Windows 7 installed on Ryzen parts.
  19. #59
    I guess the only fix was to roll back my BIOS to 2.50. Not a solution but whatever...
  20. #60
    Kindly interesting that this problem happened with me
    i tried
    • Change PCI-E slot
    • Change memory slot
    • Reset Bios
    • Update Bios
    • Overcloak everything to max (4 GHz CPU, 3 GHz memory 15-15-15-30)
    • Downclock everything to min (3 GHz CPU, 1.8 GHz memory)
    • Reinstall OS
    • Reinstall driver (LAN, chipset, video) via setup.exe
    • Install old video driver
    • Buy another video card
    Some kind of solution was to reset CMOS and delete Intel LAN driver (and app) and reinstall it via Device Manager (instead of setup.exe)
    Problem still happens if i start around 20-25 apps that parsers logs files, but until mid december i didn't encounter this problem (and i use Ryzen 1700x since Marth) and since then, until BSOD i didn't changed anything hardware wise
Similar Threads
  1. Ryzen on windows 7 HELP! LATENCY GPU
    By x58haze in forum Windows 7 | Windows Vista
    Last Post: 12-25-2017, 02:09 PM
  2. [7SP1 x64] weird no-bugcheck BSOD's
    By Pablo in forum BSOD, Crashes, Kernel Debugging
    Last Post: 10-27-2017, 10:49 AM
  3. [Win8] High DPC by storport.sys. AMD Ryzen 7 1700 8Core, 16GB RAM.
    By defoliation in forum Windows 8 | Windows RT
    Last Post: 09-21-2017, 10:10 AM
  4. Replies: 12
    Last Post: 09-18-2017, 11:56 AM
  5. Internet Speed slow unless running Qualcomm Atheroes Speed test
    By WarlordEXE in forum Windows 8 | Windows RT
    Last Post: 08-11-2014, 03:05 AM
Log in
Log in
