C ChuckR Well-known member Joined Nov 24, 2016 Posts 301 Jun 18, 2021 #1 I am using System Explorer 7.1.0.5359. It gives a LOT of information. The problem I am having is SECURITY SCAN option halts with an unknown error. I can't find any information on what it stopped on. Is anyone familiar with this product and problem? Thanks
Corday Moderator Staff member Joined Sep 27, 2017 Posts 1,251 Location South Carolina Jun 18, 2021 #2 The company is gone. Last website update 2017. You probably can find an appropriate app. See this from someone who had the problem 3 years ago.: System Explorer Error | PortableApps.com
x BlueRobot Administrator Staff member Joined May 7, 2013 Posts 10,234 Location %systemroot% Jun 18, 2021 #3 Why do you need System Explorer? There is the Sysinternals Suite of tools which you might find useful.
xrobwx71 Administrator Staff member Joined Sep 27, 2019 Posts 2,641 Location Panama City Beach, FL Jun 28, 2021 #4 MiTeC Homepage Task Manager Deluxe is a very good one that has everything System Explorer was offering. I've used it for some time without issue. x BlueRobot said: Why do you need System Explorer? There is the Sysinternals Suite of tools which you might find useful. Click to expand... I use it as a more robust option to Windows Task Manager. For me, it falls under the category of "I like to tinker"... :)
