Background;
Friend called me and asked me to take a look at his PC. He started having ATI Driver failure issues and random BSODs. He told me he tried doing a clean install and was unable to do so. I told him to bring me the PC so I could check it out. I found that the PC had been infected across all three drives and the result was a completely unresponsive PC that no cleaning or repairs could correct. I decided to clean the PC and CLEAN the PC. It was FULL of dust and full of viruses. So I tore it down and physically cleaned all of the components and reassembled it. I took each drive and secure wiped them using UBCD. After doing so, I installed Win7 x64 OEM Home Premium. I installed CCC and AMD Vision after that. Then installed MSE and MBAM and ran full scans to be sure that the wipes were successful. They, of course, were. There were no traces of Malware or Viruses. After doing that, I installed Macrium, imaged and also imaged and backed up with MS B+R. At this point CCC and AMD Vision worked perfectly. This was a pre SP1 install, so there were about 200 updates that occurred, including SP1 that day. I ran through the updates, only attending to the PC every hour or so to reboot and let the updates continue. After SP1 had installed, I then started checking everything on the PC, running Furmark and P95 etc, checking stability and temps. All was well. I then noticed that the CCC icon was not showing on the taskbar. I had previously not even looked for it and do not know when it disappeared. So, I right clicked on the desktop and selected AMD Vision, it did not respond. I went to the program menu and selected the CCC folder and tried running the various levels of CCC. When trying to do so I got a message stating that CLI.Implementation had failed. (????) Then tried the AMD Vision from the prgram menu and got MOM.Implementation had failed. (????)
What I have done;
Installed Microsoft .Net Framework 4 and ran full updates.
Installed Driver Sweeper and cleaned the AMD files.
Re-installed AMD files(CCC and AMD Vision.
Tried to run again, same results.
Did four more AMD un-installs and re-installs.
Same Result.
Thought .Net Framework might have been corrupt, so I uninstalled it and reinstalled it and ran all updates again. Before uninstalling it, I also swept the AMD files again.
After installing .Net Framework again, I reinstalled all the AMD stuff. Same results. Either the programs do not respond, or I get the CLI.Implementation failures or MOM.Implementation failures.
Check disk passes on all drives.
Stress tests pass on all hardware.
Memtest86 passed for 12 hours clean.
All other programs and games work flawlessly.
I did come across something I have not tried yet, only because I don't understand it.
http://msdn.microsoft.com/en-us/library/e74a18c4.aspx Which was linked from
http://support.amd.com/us/kbarticles/Pages/26494-Radeon-MOM-CCC-implementation.aspx
I don't currently have the PC as he was not at all concerned with this issue. All he was concerned with was that the PC was working(working in his eyes) and that his games worked. I, however, wanted to see if anyone could explain this to me so that I could, hopefully, resolve the issue.
Thanks,
James
