1. #1
    High DPC Latency/External sound interfeace problems
    Hi everyone,
    First of all i'm italian so forgive me for my english.
    So i've recently bought a new laptop, an Asus Vivobook Pro. Intel i7 7700HQ,16gb Ram DDR4, 512gbSSD+ 1Tb Hdd and a Nvidia GTX 1050.
    I bought it for music production. I use a Focusrite Suffire 6 Usb.
    Since the beginning i had problem with my audio interface. When i recorded it crashed after 10 seconds, and even if i played an audio file.
    After contacting the assistence the suggested me to do a latency test, and i found out that there was an high latency. So i thought that was my audio intefece's fault, but also running the test with the sound card disconnected there still was an high latency. I tried to disconnect the wifi, and found out that there was less latency,but still to much. I read on latency mon's result that one of the driver that has more latency is HDAudbus.sys and the other one in wdf0100.sys. Whene i run the test with the wifi on the driver with the highest latency was the ndis.sys which i suppose is related to the wifi.Indeed when i turn off the wifi the sound interface doesn't crush and there are no crackels or anything. I updated the drivers of the intel dual band wirless, but still there is the problem. I'd use the Focusrite without Wifi, but still there is the problem that there is an high latenecy even if i don't connect both the sound card and the wifi. So i'd like to solve the problem.( i've already tried to change the power saving setting,and set them to High Performance)
    Following you'll find the LatencyMon results, the one with no wifi.
    I hope that someone can help me, let me know if you need further information.
    CONCLUSION
    LatencyMon has been analyzing your system for 0:01:19 (h:mm:ss) on all processors.
    SYSTEM INFORMATION
    Computer name: DESKTOP-VRU2NLC
    OS version: Windows 10 , 10.0, build: 16299 (x64)
    Hardware: X580VD, ASUSTeK COMPUTER INC.
    CPU: GenuineIntel Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
    Logical processors: 8
    Processor groups: 1
    RAM: 16265 MB total
    CPU SPEED
    Reported CPU speed: 2808 MHz
    Highest measured interrupt to process latency (Ás): 4043,857013
    Average measured interrupt to process latency (Ás): 4,095642
    Highest measured interrupt to DPC latency (Ás): 2405,746660
    Average measured interrupt to DPC latency (Ás): 1,456750
    REPORTED ISRs
    Highest ISR routine execution time (Ás): 1603,131410
    Highest reported total ISR routine time (%): 0,034938
    Total time spent in ISRs (%) 0,058972
    ISR count (execution time <250 Ás): 29367
    ISR count (execution time 250-500 Ás): 0
    ISR count (execution time 500-999 Ás): 13
    ISR count (execution time 1000-1999 Ás): 4
    ISR count (execution time 2000-3999 Ás): 0
    ISR count (execution time >=4000 Ás): 0
    REPORTED DPCs
    Highest DPC routine execution time (Ás): 2374,058048
    Driver with highest DPC routine execution time: Wdf01000.sys - Runtime framework driver modalitÓ kernel, Microsoft Corporation
    Highest reported total DPC routine time (%): 0,098443
    Driver with highest DPC total execution time: Wdf01000.sys - Runtime framework driver modalitÓ kernel, Microsoft Corporation
    Total time spent in DPCs (%) 0,189068
    DPC count (execution time <250 Ás): 334601
    DPC count (execution time 250-500 Ás): 0
    DPC count (execution time 500-999 Ás): 153
    DPC count (execution time 1000-1999 Ás): 2
    DPC count (execution time 2000-3999 Ás): 3
    DPC count (execution time >=4000 Ás): 0
    REPORTED HARD PAGEFAULTS
    Process with highest pagefault count: none
    Total number of hard pagefaults 0
    Hard pagefault count of hardest hit process: 0
    Highest hard pagefault resolution time (Ás): 0,0
    Total time spent in hard pagefaults (%): 0,0
    Number of processes hit: 0
    PER CPU DATA
    CPU 0 Interrupt cycle time (s): 3,712792
    CPU 0 ISR highest execution time (Ás): 1603,131410
    CPU 0 ISR total execution time (s): 0,372703
    CPU 0 ISR count: 29384
    CPU 0 DPC highest execution time (Ás): 2374,058048
    CPU 0 DPC total execution time (s): 0,831832
    CPU 0 DPC count: 293316
    CPU 1 Interrupt cycle time (s): 3,532590
    CPU 1 ISR highest execution time (Ás): 0,0
    CPU 1 ISR total execution time (s): 0,0
    CPU 1 ISR count: 0
    CPU 1 DPC highest execution time (Ás): 683,893519
    CPU 1 DPC total execution time (s): 0,008068
    CPU 1 DPC count: 1273
    CPU 2 Interrupt cycle time (s): 2,626569
    CPU 2 ISR highest execution time (Ás): 0,0
    CPU 2 ISR count: 0
    CPU 2 DPC highest execution time (Ás): 712,507123
    CPU 2 DPC total execution time (s): 0,107986
    CPU 2 DPC count: 12558
    CPU 3 Interrupt cycle time (s): 4,174517
    CPU 3 ISR highest execution time (Ás): 0,0
    CPU 3 ISR count: 0
    CPU 3 DPC highest execution time (Ás): 939,301638
    CPU 3 DPC total execution time (s): 0,019189
    CPU 3 DPC count: 2037
    CPU 4 Interrupt cycle time (s): 2,384006
    CPU 4 ISR highest execution time (Ás): 0,0
    CPU 4 ISR count: 0
    CPU 4 DPC highest execution time (Ás): 728,724003
    CPU 4 DPC total execution time (s): 0,109190
    CPU 4 DPC count: 11794
    CPU 5 Interrupt cycle time (s): 3,729948
    CPU 5 ISR highest execution time (Ás): 0,0
    CPU 5 ISR count: 0
    CPU 5 DPC highest execution time (Ás): 750,499288
    CPU 5 DPC total execution time (s): 0,006560
    CPU 5 DPC count: 883
    CPU 6 Interrupt cycle time (s): 2,132005
    CPU 6 ISR highest execution time (Ás): 0,0
    CPU 6 ISR count: 0
    CPU 6 DPC highest execution time (Ás): 730,987892
    CPU 6 DPC total execution time (s): 0,101271
    CPU 6 DPC count: 11577
    CPU 7 Interrupt cycle time (s): 3,617869
    CPU 7 ISR highest execution time (Ás): 0,0
    CPU 7 ISR count: 0
    CPU 7 DPC highest execution time (Ás): 696,841880
    CPU 7 DPC total execution time (s): 0,010818
    CPU 7 DPC count: 1321
    s
    • Ad Bot
      advertising
      Beep.
  2. #2
    Sysnative Staff
    BSOD Kernel Dump Analyst
    Contributor
    axe0's Avatar
    Join Date
    May 2015
    The Netherlands
    Age
    22
    • specs System Specs
      • Manufacturer:
        Custom build
      • Motherboard:
        Gigabyte B150-HD3P-CF
      • CPU:
        Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz
      • Memory:
        16GB DDR4 Crucial Ballistix Sport LT BLS8G4D240F
      • Graphics:
        Intel(R) HD Graphics 530
      • Sound Card:
        (1) Intel(R) Display Audio (2) Realtek HD Audio
      • Hard Drives:
        Crucial MX200 500GB &amp; 2x Toshiba DT01ACA300
      • Power Supply:
        Corsair RM550x
      • Case:
        Fractal Design Define S
      • Cooling:
        Cooler Master TX3 i
      • Display:
        24&quot; Liyama ProLite XB2483HSU-B2 &amp; 24&quot; Dell Ultrasharp U2414H
      • Operating System:
        Windows 10 Pro
    Re: High DPC Latency/External sound interfeace problems
  3. #3
    I did it.
    Here is the dropbox link for the zip file containing trace.etl, msinfo32.nfo and DxDiag.txt : Dropbox - Results.zip
    Here's the link of the speccy test: http://speccy.piriform.com/results/Y...nVw6OOzpTd4ocJ
    Thank you
  4. #4
    Sysnative Staff
    Contributor
    axe0's Avatar
    Join Date
    May 2015
    The Netherlands
    Age
    22
      • Manufacturer:
        Custom build
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
        Corsair RM550x
      • Case:
      • Cooling:
        Cooler Master TX3 i
      • Display:
      • Operating System:
        Windows 10 Pro
    Can't find the support page of ASUS for your laptop model.
    Check for Intel chipset (or Rapid Storage Technology) and NVIDIA display driver updates.
  5. #5
    I'll do that.
    Anyway i've both an onboard graphic card an Intel 630HD Graphics , plus a dedicated one, the GTX1050. Can this influence anything?
  6. #6
    Sysnative Staff
    Contributor
    axe0's Avatar
    Join Date
    May 2015
    The Netherlands
    Age
    22
      • Manufacturer:
        Custom build
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Power Supply:
        Corsair RM550x
      • Case:
      • Cooling:
        Cooler Master TX3 i
      • Display:
      • Operating System:
        Windows 10 Pro
    Not per se, if you have configured to use either with certain programs.
Similar Threads
  1. Replies: 29
    Last Post: 03-07-2017, 10:49 AM
  2. Replies: 37
    Last Post: 11-15-2016, 07:24 AM
  3. Replies: 8
    Last Post: 06-22-2016, 07:48 PM
  4. [SOLVED] Another high DPC latency issue with sound distortion
    By kallistibrc in forum Windows 7 | Windows Vista
    Last Post: 08-20-2015, 11:59 PM
  5. [SOLVED] Latency causing my sound problems?
    By Labrador in forum BSOD, Crashes, Kernel Debugging
    Last Post: 03-08-2015, 09:53 AM
Log in
Log in
