1. #1
    HELP. Very High Latency, Audio Clicking Problem, and Wlan also?
    Hello there guys!
    I run Latency Mon and it is showing up this HELP. Very High Latency, Audio Clicking Problem, and Wlan also?-cattura-jpg
    As u can see, it showing some problems.
    The first problem im noticing is when im playing audio, it will click before playing, while palyinh and be distorted sometimes.
    So i installed WPA and run this command
    "xperf -on PROC_THREAD+LOADER+PROFILE+INTERRUPT+DPC+DRIVERS+POWER+IDLE_STATES -stackwalk Profile -BufferSize 1024 -MinBuffers 256 -MaxBuffers 256 -MaxFile 256 -FileMode Circular"
    and done some web writing, audio listening and opening photosop.
    Then done this
    "xperf -stop -d C:\CPU.etl".
    Files are here attached as "Archive.zip" (CPU and KERNEL file from Folder C) Uploadfiles.io - Archive.rar
    Also if you can help me to verify if im missing something.
    System is really stable, but for me, just my impression, its draining too much battery!
    Plz help me guys
    • Ad Bot
      advertising
      Beep.
  2. #2
    writhziden's Avatar
    Join Date
    May 2012
    Colorado
    • specs System Specs
      • Manufacturer:
        Sony
      • Model Number:
        VPCF232FX/B
      • Motherboard:
        Sony Corporation VAIO
      • CPU:
      • Memory:
        8.00 GB Crucial CT2KIT51264BF1339 DDR3 1333
      • Graphics:
      • Sound Card:
        Realtek High Definition Audio/nVidia High Definition Audio
      • Hard Drives:
        TOSHIBA MK5061GSY 500 GB (465 GB actual)
      • Case:
        Laptop black matte case with backlit keyboard
      • Cooling:
        Air cooling via fan and heat exchanger heatsink
      • Display:
        Laptop display
      • Operating System:
        Windows 7 Home Premium 64 Bit
    Re: HELP. Very High Latency, Audio Clicking Problem, and Wlan also?
    Difficult to say what the issue is. What battery is being drained? Do you have a UPS? Is this a laptop. We have no idea what system you are using, how it is set up, software installed, etc. That makes it very difficult to offer any solutions.
    Please follow the POSTING INSTRUCTIONS for DPC/ISR latency, stuttering, cracks/pops.
    When you upload the files, please use a trusted site instead of the site you used. I recommend either
    or
    axel9546 says thanks for this.
    I am only a volunteer helping users on the forums. Please wait 72 hours before double posting or PMing for help. I appreciate your patience. :-}
  3. #3
    Quote Originally Posted by writhziden View Post
    or
    Oh im sorry! Ok now ive put all on the archive zip!!
    My pc is a Galaxy Book 12
    INTEL I5 7200U
    HD 620
    SDCA029
    ALC298
    2160X1440
    WACOM EMR
    Desktop.zip - Google Drive
  4. #4
    Up. . .
  5. #5
    writhziden's Avatar
    Join Date
    May 2012
    Colorado
      • Manufacturer:
        Sony
      • Model Number:
        VPCF232FX/B
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Case:
      • Cooling:
      • Display:
        Laptop display
      • Operating System:
    Quote Originally Posted by axel9546 View Post
    Up. . .
    Sorry, I haven't had a chance to investigate. I've been working double shifts for work, and I won't be done with that until the 31st. Maybe someone else will check in before then.
  6. #6
    Up. . .
    Oh no problem ill wait :). Thanks for your support and good work
  7. #7
    writhziden's Avatar
    Join Date
    May 2012
    Colorado
      • Manufacturer:
        Sony
      • Model Number:
        VPCF232FX/B
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Case:
      • Cooling:
      • Display:
        Laptop display
      • Operating System:
    Alright, I've had a chance to check your logs. The primary issue seems to be network related. Check for updates for your wireless/LAN network devices. Make sure both devices have updated drivers since they can interact with each other. If that does not work, try opening device manager and disabling whichever network device you are not using.
  8. #8
    Tried to disable Wlan putting in Aero Mode.
    Noe Latency mon show max 200 of peak just playing audio.
    If i disable aero mode and put wifi on, it will re show peak!
    Idk why but seems so the wifi card?
    How can i test more?
    All drivers updated
  9. #9
    Up :)
  10. #10
    writhziden's Avatar
    Join Date
    May 2012
    Colorado
      • Manufacturer:
        Sony
      • Model Number:
        VPCF232FX/B
      • Motherboard:
      • CPU:
      • Memory:
      • Graphics:
      • Sound Card:
      • Hard Drives:
      • Case:
      • Cooling:
      • Display:
        Laptop display
      • Operating System:
    So there are no issues if you connect to the internet via Ethernet?
  11. #11
    I cant its a Tablet! :)
    But yes i tried aereo mode and wifi off latency goes down
Similar Threads
  1. Replies: 2
    Last Post: 09-02-2017, 10:53 PM
  2. Very High DPC Latency - Audio Crackling
    By BestLux in forum Windows 10
    Last Post: 08-31-2016, 07:06 PM
  3. Audio stuttering maybe high DPC latency
    By greenman86 in forum Windows 8 | Windows RT
    Last Post: 07-21-2014, 04:27 PM
  4. High latency, audio stuttering.
    By ricktza in forum Windows 7 | Windows Vista
    Last Post: 07-01-2014, 11:25 AM
  5. High latency, audio stuttering.
    Last Post: 05-22-2014, 06:24 PM
Log in
Log in
