OS: Window 7 Prof N; System 64-bit
Hardware: VMWare Fusion 10 (running Windows 7 as VM) under host MacBook Pro 2011 OS High Sierra
Hello,
This is my 1st post on this forum. Thank you in advance for helping.
I am able to create a system restore point on Window 7. However, if I try to restore a previous system report then I get an error "System restore did not complete successfully ...."followed by "Details: Incorrect function. (x80070001)".
I have also ran sfc /scannow and a few errors are reported. I attached the sfc report (sfcdetails) that identifies the errors. I then ran SFCFix (downloaded from your web site; thanks) and it also reported 10 corrupted files. I am not sure if these corrupted files are related to System Restore issue.
Otherwise, my Windows 7 appears to work well with all my applications.
I also note I am no expert in OS (PC or Mac), just an informed user.
Many thanks if you can help.
Balvant
Hello,
Balvant
