I have an HP Pavilion x360 that is not booting and goes to a Recovery screen indicating there's a problem with the SYSTEM hive, error code 0x000014c. I don't have a backup I can pull and when I load up that hive in regedit offline (using Hirens) it looks fine to me on the surface. I also tried to use "DISM /Image
:\ /Cleanup-Image /RestoreHealth" (D was the correct drive), and it failed with error 1009, saying the configuration registry database is corrupt.
The DISM log file had the following related entries:
2025-04-21 08:44:39, Info CBS Failed to load offline \\?\D:\Windows\System32\config\SYSTEM hive from '\\?\D:\Windows\System32\config\SYSTEM' into registry key '{bf1a281b-ad7b-4476-ac95-f47682990ce7}D:/Windows/System32/config/SYSTEM'. [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-04-21 08:44:39, Info CBS Failed to load offline registry: {bf1a281b-ad7b-4476-ac95-f47682990ce7}D:/Windows/System32/config/SYSTEM [HRESULT = 0x800703f1 - ERROR_BADDB]
2025-04-21 08:44:39, Info CBS Failed to load offline SYSTEM hive. [HRESULT = 0x800703f1 - ERROR_BADDB]
I'm attaching the SYSTEM hive. Hopeful a guru out there can maybe see what's wrong with it.
Thanks
Thanks
