Chocobit
- Nov 20, 2023
- 2
Hello everyone,
I'm going crazy here because I can't assess what's going on with the PC or whether its behavior is just normal. Sometimes, as mentioned above, I get spikes of up to 2,000 from the mentioned drivers. Sometimes it's Nvidia, other times DirectX, or classpnp. Right now, the PC has been running for over 4 hours. Of that, 2 hours idle and 2 hours gaming. Sometimes the spikes occur without any changes made to the drivers, etc. Sometimes after 2 minutes, sometimes, as seen in the pictures, not at all. The latest NVIDIA driver is the worst. With it, Nvidia is always at the forefront and constantly. I have uninstalled the Realtek sound driver, as it ALWAYS spikes with HDAD. What do you think is going on?
Operating System: Windows 11, 10.0, version 2009, build: 22631 (x64)
Motherboard brand and model: ASUS DARK HERO, 4602
CPU brand and model: AuthenticAMD AMD Ryzen 7 5800X3D 8-Core Processor
Graphics Card - Integrated or card band and model: ASUS TUF RTX 4090 OC
RAM brand, type, and number of sticks:2x16. Look at Pictures
Case brand and model: Fractal
PSU brand and model: BeQuiet 1000W
Main Drive(s): brand(s) and model(s): Samsung SSD 850 EVO.
CONCLUSION
LatencyMon has been analyzing your system for 4:25:13 (h:mm:ss) on processors 0,1,2,3,4,5,6 and 7.
SYSTEM INFORMATION
Computer name: GAMING
OS version: Windows 11, 10.0, version 2009, build: 22631 (x64)
Hardware: System Product Name, ASUS
BIOS: 4602
CPU: AuthenticAMD AMD Ryzen 7 5800X3D 8-Core Processor
Logical processors: 16
Processor groups: 1
Processor group size: 16
RAM: 32675 MB total
CPU SPEED
Reported CPU speed (WMI): 3401 MHz
Reported CPU speed (registry): 340 MHz
Highest measured interrupt to process latency (µs): 194,40
Average measured interrupt to process latency (µs): 3,825565
Highest measured interrupt to DPC latency (µs): 192,20
Average measured interrupt to DPC latency (µs): 1,180133
REPORTED ISRs
Highest ISR routine execution time (µs): 21,60
Driver with highest ISR routine execution time: ACPI.sys - ACPI-Treiber für NT, Microsoft Corporation
Highest reported total ISR routine time (%): 0,000477
Driver with highest ISR total time: Wdf01000.sys - Kernelmodustreiber-Frameworklaufzeit, Microsoft Corporation
Total time spent in ISRs (%) 0,000627
ISR count (execution time <250 µs): 1510010
REPORTED DPCs
Highest DPC routine execution time (µs): 612,390
Driver with highest DPC routine execution time: CLASSPNP.SYS - SCSI Class System Dll, Microsoft Corporation
Highest reported total DPC routine time (%): 0,051237
Total time spent in DPCs (%) 0,09060
DPC count (execution time <250 µs): 38141270
DPC count (execution time 500-10000 µs): 236
DPC count (execution time 1000-2000 µs): 0
REPORTED HARD PAGEFAULTS
Total number of hard pagefaults 47485
Hard pagefault count of hardest hit process: 27529
Number of processes hit: 56
PER CPU DATA
CPU 0 Interrupt cycle time (s): 155,822888
CPU 0 ISR highest execution time (µs): 21,60
CPU 0 ISR total execution time (s): 1,597125
CPU 0 ISR count: 1509624
CPU 0 DPC highest execution time (µs): 612,390
CPU 0 DPC total execution time (s): 28,151473
CPU 0 DPC count: 7080425
CPU 1 Interrupt cycle time (s): 37,393611
CPU 1 ISR highest execution time (µs): 1,550
CPU 1 ISR total execution time (s): 0,000273
CPU 1 ISR count: 386
CPU 1 DPC highest execution time (µs): 262,940
CPU 1 DPC total execution time (s): 0,386576
CPU 1 DPC count: 146170
CPU 2 Interrupt cycle time (s): 19,862061
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 89,940
CPU 2 DPC total execution time (s): 0,153830
CPU 2 DPC count: 73188
CPU 3 Interrupt cycle time (s): 635,619380
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 425,380
CPU 3 DPC total execution time (s): 201,704715
CPU 3 DPC count: 30702992
CPU 4 Interrupt cycle time (s): 23,687177
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 251,250
CPU 4 DPC total execution time (s): 0,052832
CPU 4 DPC count: 25978
CPU 5 Interrupt cycle time (s): 25,288743
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 243,780
CPU 5 DPC total execution time (s): 0,038636
CPU 5 DPC count: 22021
CPU 6 Interrupt cycle time (s): 27,117563
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 257,410
CPU 6 DPC total execution time (s): 0,112665
CPU 6 DPC count: 52973
CPU 7 Interrupt cycle time (s): 27,462775
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 264,90
CPU 7 DPC total execution time (s): 0,081966
CPU 7 DPC count: 37759
CONCLUSION
SYSTEM INFORMATION
BIOS: 4602
Processor groups: 1
RAM: 32675 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
CPU 2 ISR count: 0
CPU 3 ISR count: 0
CPU 4 ISR count: 0
CPU 5 ISR count: 0
CPU 6 ISR count: 0
CPU 7 ISR count: 0
